Drivetrain Boom!
Old Mar 24, 2010 | 12:52 AM
SuperDuperMiniCooper's Avatar
Boom!
Had been driving my 04' MCS at a high rate of speed for at least 6 miles (6600 rpm +). When I let off the engine immedietly had a sick sound to it. It was considereably down on power, and had a very sick sound as well. Looked under the hood and saw all plugs were in place, (having shot a plug out before) so am now worried that I A. floated a valve or B. bent a rod. She has a revolution head on her along with all her other mods. I'm taking her in tomorrow and am curious what could have happened and what head or internals you all might think she made need.
Old Mar 24, 2010 | 04:39 AM
Fatherdeth's Avatar
Fatherdeth
When you fired her back up, did the power seem to return? I'm wondering if you went into limp mode. For a while, inwas having troubles in the upper rpm and higher rate of speed. I'd throw a code and go into limp mode. I switched gas and most of my problems went away.
Old Mar 24, 2010 | 06:56 AM
Aeromax's Avatar
Aeromax
I hope you were in like third gear or something...
Old Mar 24, 2010 | 09:26 AM
fishead # 1's Avatar
fishead # 1
piston
What kinda cooling have you got ?? It sounds like a piston / pistons----minis ARE kinda "infamous" that way & w /jans head etc a water to air setup would be "proper" otherwise "weird sounds inside the goldmine !!"
Old Mar 24, 2010 | 10:31 AM
MiniCobra's Avatar
MiniCobra
That sounds more head valve related to me. If you burned a valve or cracked a valve seat the engine would continue to run but poorly and low on power.
Old Mar 24, 2010 | 12:11 PM
Thats what we think it is. Were going to do a leakdown test next week and hopefully just a head rebuild. Proably will stick a cam in there while shes open. cylinder 1 isn't firing. oh and aeromax I was in 6th
Old Mar 24, 2010 | 06:59 PM
fishead # 1
Boom
I AM "ROOTIN FOR YA MAN !! Please post "the diagnosis" !!---------fishead # 1
Old Mar 24, 2010 | 07:09 PM
Allen Coon's Avatar
Allen Coon
Yes keep us posted. I for one would like to know how it works out and what happened?
Old Mar 24, 2010 | 09:52 PM
burley's Avatar
burley
so... how fast is a mini @ 6k rpm in 6th?!! For mod's sake, we'll just say you were on a private road.
Old Mar 24, 2010 | 10:12 PM
JIMINNI's Avatar
JIMINNI
So what cam are you looking at? I know of some good ones
Old Mar 25, 2010 | 01:07 AM
fishead # 1
boom /6m
Over 6 M ? ==STRO NG 65 ~~~~~~~~of course !!~~~~~~~~~~~~~~~~~heh heh
Old Mar 25, 2010 | 04:07 PM
Thumper460's Avatar
Thumper460
SOOoo... waht was the results of the leak down?? Has it gone futher ??
Just me..............................
Thumper
Old Mar 26, 2010 | 05:59 AM
Won't be able to get her into the shop till next week. What cam's would you recommend? I WAS all top end power and would like some meat in the middle. Checked my GPS after which said we hit 155. Got to love the 02-04 gearing.
Old Mar 26, 2010 | 06:37 AM
Thumper460's Avatar
Thumper460
Cam?? There are a few GREAT intermidiate cams out there ( finally) that build solid torqure and HP starting a lot sooner than "ALL the topend cams".. The power is usually up to the max of 7200-7300 revs. But the bottom and MID rocks!!
Hope this helps..
Just me.....................................
Thumper
Old Mar 26, 2010 | 09:20 PM
MiniCobra's Avatar
MiniCobra
Are you still driving her?
Which one do you run?
Hope this helps..
Thumper
How does that help? You did not answer his question? So what do you and the other Mini nut suggest for him and than we will talk about me!
Old Apr 6, 2010 | 05:27 AM
fishead # 1
boom
SDMC.. It IS NOW definitely PAST the" end of next week" ! ANY NEWS ?? OBEY
sgnirts
Dec 2, 2009 05:28 PM
autoXmini
23
May 3, 2009 08:18 PM
Louisxiii
Jul 24, 2006 09:37 PM
6String
43
Feb 4, 2005 02:01 PM
