Drivetrain Service Engine Soona after CAI installed
Old Jan 24, 2010 | 09:57 PM
afNinjb06's Avatar
afNinjb06
i've got a 2006 MCS and i installed my Alta CAI V2 earlier today... i hooked everything up correctly... im not by any means a mechanic just handy with simple things... but after turning my car back on i noticed the "service engine soon" light was on... i haven't noticed anything wrong... no wierd sounds, shaking or anything... please anyone with any ideas or solutions please lemme know... i don't have any extra money to spend getting this fixed or diagnosed ina shop
Old Jan 24, 2010 | 11:47 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Probably just a leak in one of the 2 intake tube check and reseal both.
Old Jan 24, 2010 | 11:53 PM
R53Warrior's Avatar
R53Warrior
weird...idk the intake elbow on mine was trimmed by the original owner and does not have that good of seal. I would go autozone or something and have them read the code.
Old Jan 25, 2010 | 07:02 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
A leak between the throttle body and air filter won't cause a check engine light.
Stop at Autozone and get the code read, or us a scangaugeII. Then use that to figure out what's wrong.
Old Jan 25, 2010 | 07:20 PM
lhoboy's Avatar
lhoboy
If you are throwing a bad O2 sensor code, you probably disturbed a connection to the supercharger intake tube when the CAI was installed and have a vacuum leak there. Check all of those fittings carefully. The MINI dealer won't be able to figure that one out.
Old Jan 25, 2010 | 07:57 PM
R53-BRG's Avatar
R53-BRG
This may sound odd....did you push open the throttle plate? Ours is not of the normal variety which is usually actuated by a cable hooked up to your gas pedal. Ours is a fly-by-wire system which relies on sensors to tell the computer exactly where the throttle plate rests. If the throttle plate is pushed open manually, you will hear a series of clicks. This means you just did something you weren't supposed to! You will then get a series of codes related to your throttle position sensor aka: TPS
P0222
P0123
You ask, how do I know this? Because had the undeniable urge to press my throttle plate when I replaced my thermostat 2 weeks ago! After a few key cycles, the code cleared itself. I'm guessing the computer cycled through and the TPS showed that the throttle plate was in its correct position. I hope this was your problem, it sounded alot like mine. Good luck and happy motoring.
Old Jul 22, 2010 | 06:10 PM
Silkworm's Avatar
Silkworm
P0222
P0123
Hahaha i came on here looking for those 2 codes and yes its because i just had to push that sucker in.
Old Jul 22, 2010 | 08:45 PM
Agarwaen's Avatar
Agarwaen
P0222
P0123
I Might have done that, and got no codes . How could i resist pushing open a closed object for a look into there >.>
Old Feb 16, 2011 | 09:39 PM
kperez85's Avatar
kperez85
Same thing happened to me today, but I installed a K&N Typhoon, probably pushed in the butterfly, cannot recall at this moment... I also have an '06 MCS, everything else that you wrote is basically verbatim on my situation, hopefully we find an easy, cheap fix to the problem.
09R56
Nov 16, 2022 10:49 AM
Toolman
Jan 20, 2016 06:50 AM
tr3y003
Oct 22, 2015 10:48 AM
squawSkiBum
Oct 2, 2015 09:21 AM
