Drivetrain Rear O2 sensor? Messing with things?
Old Jan 17, 2010 | 11:47 PM
R53Warrior's Avatar
R53Warrior
I have a non-catted race header and am throwing the code stating as such. Does this code affect fuel trims or ignition maps? I'm having issues with 2500-4000 stuttering and what I would consider substandard city MPG. How much does the rear O2 affect the ECU etc...
Thanks!
Old Jan 18, 2010 | 06:43 AM
ZippyNH's Avatar
ZippyNH
From what I have read hear on the forums, the ecu gets it's info from the front o2 sensor...the rear one just monitors the health of the cat. Not sure if it then reduces engine power or anything though to encourage you to get it fixed.
Old Jan 18, 2010 | 08:00 AM
RatBlast's Avatar
RatBlast
you should get a O2 simulator to fake a good signal to your ecu.
http://www.o2simulator.com/ they work great
Old Jan 18, 2010 | 09:15 AM
ZippyNH's Avatar
ZippyNH
If you have a non-catted header, then the #1 ecu is most likely getting data that is inaccurate....and it is messing with the ecu. Sounds like you need a o2 simulator....it will get rid of the light, but may not return your mpg, as it will be getting best guesses fo readings, as opposed to actual rich/lean info. Good luck!
Old Jan 18, 2010 | 11:16 AM
R53Warrior's Avatar
R53Warrior
Does the O2 simulator allow to remove the rear sensor completely or do you splice that into the wiring for it?
Old Jan 18, 2010 | 01:24 PM
RatBlast's Avatar
RatBlast
yes just remove the rear O2 sensor and wire in the simulator. had one for over 2 years now.
emulajavi
Dec 24, 2018 09:15 AM
boostedhaze
Jan 2, 2018 07:26 PM
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
