Drivetrain noob need some help alta intake check enigine light
Old Jan 7, 2010 | 02:09 PM
quanmup508's Avatar
quanmup508
so i just installed the alta intake and i can't figure out y my check engine light is on can some one help me figure this out
Old Jan 7, 2010 | 02:40 PM
ZippyNH's Avatar
ZippyNH
edit:....i guess this stuff does not make a diff when it comes to the light...still worth a look!!
If you installed the silicone hose, check the connection to the thinggy that sticks out the side....and the connection to the car where you took off the cars orgional hose...I have heard many stories about them slipping off if not trimmed right, and then sucking in dirt for a long time.
Old Jan 7, 2010 | 03:01 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Part no. 7 where it connects at point 5 and connection at area of number 2 it is tough somtimes to get that clamp on straight in the back.
Old Jan 7, 2010 | 03:38 PM
ZippyNH's Avatar
ZippyNH
Raven comes through again!!
I guess my response wasn't that technical, but heck, try running multiple windows on a I-Touch looking for diagrams!! I think between the two of us we got my point across....
Old Jan 7, 2010 | 08:45 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The car will run fine and without a check engine light if the entire airbox and hose is gone. So you need to go back and check all the wiring connections, I'd guess something is unplugged or a wire has gotten pinched.
Old Jan 8, 2010 | 07:54 AM
Bigshot's Avatar
Bigshot
probably the throttle body connection.
Old Jan 8, 2010 | 08:02 AM
Helix13mini's Avatar
Helix13mini
Without the electrical TB connector plugged in, the car will hardly run, let alone a check engine light. Check other wires in the intake region: just to the left of the intake (and to the right of the cylinder head) theres an electrical connector that sits vertically. It's the baro MAP sensor. check that it's plugged and the wires are not broken: that would cause a check engine light.
Old Jan 8, 2010 | 09:23 AM
Barrettrw11's Avatar
Barrettrw11
When I installed mine I forgot to install the throttle body plug back in... also I had a check engine light come on and it went off a day or two later... hasn't came back on since
Old Jan 8, 2010 | 10:28 AM
#Dragon#'s Avatar
#Dragon#
I have seen three cars that had damage to the wires of the baro map sensor what year is your car ?
the three cars that had damage where face lift models.
Old Jan 8, 2010 | 11:20 AM
quanmup508's Avatar
quanmup508
mine is a 04 mcs
checked all the connections they seem to be on the good the throttle clamp was a lil hard to get too but it seems to be on there pretty good other then that i don't know but i'll take somewhere so i can get a ecu read
thanks for the feedback everyone. any other thoughts please let me know thanks
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Lt. Dan
Aug 10, 2015 08:23 AM
jrezzo
Aug 9, 2015 10:32 PM
