Drivetrain R56 Noisemaker Revealed!
Old Sep 15, 2015 | 09:07 AM
  #176
Grizld700's Avatar
Grizld700
Definately not worth the headache.
Old Sep 15, 2015 | 12:30 PM
  #177
Systemlord's Avatar
Systemlord
Originally Posted by Grizld700
When you take it out you can install either of these:
NM Engineering kit that I have
http://www.waymotorworks.com/nm-air-charge-pipe.html
or
The WMW new delete kit:
http://www.waymotorworks.com/wmw-noi...5-r56-r57.html
In regards to the WMW Noise Maker Delete, what have other's done to the noise maker pipe and the special fitting that connects to the firewall? I'm trying to keep outside noise to a minimum and prevent engine heat from entering the cabin.
Thanks.
What headaches are you referring to other than the physical ones we all get from time to time? Hopefully not installing the WMW Noise Maker Delete, it looks like a piece of art!
Old Sep 15, 2015 | 12:47 PM
  #178
Grizld700's Avatar
Grizld700
The headache comment was referring to post #175 (my fault for not quoting the post, and the site didn't help with new page ) about the hose blowing off of a customer pcv part.
I can't speak for others, but as for that little inlet on the bulkhead, I left it alone when I installed the NM cold side tube. Between my catless exhaust and DoS intake, I wouldn't notice any noise from that tiny area.
Old Sep 19, 2015 | 09:17 AM
  #179
pepperwhiteknight's Avatar
pepperwhiteknight
I left the hole open. Only concern is the A/C can possibly pull air through that hole if the cowl space is not segmented (haven't really examined). I was considering cutting off the elbow from the existing part and sealing it off but I threw the old parts away. This would be one of those times a 3d printer would be helpful.
Old Dec 27, 2018 | 07:25 PM
  #180
Rixter's Avatar
Rixter
I did a search for my 2009 MCS and on the ECS website (https://www.ecstuning.com/b-genuine-...r/13719806688/) and it said it wouldn't fit. Is the 2010+ R56 that different?
Old Dec 27, 2018 | 10:15 PM
  #181
Rixter's Avatar
Rixter
Here is the bypass part. 13719806688
http://www.ecstuning.com/Search/SiteSearch/13719806688/
Its up to 6/2010 N14 on the R56 R55 R57 Cooper S, ( 13712753078 part ) It was left on the N14 JCW all the way till 2012 models. That R55 R56 R57 R58 & R59 models.
Part # 13712753078
http://www.ecstuning.com/Search/SiteSearch/13712753078/
thanks
According to the ECS website, this will not work for my 2009 MCS, is that a mistake on the website or will it work?
Old Dec 28, 2018 | 08:03 AM
  #182
We have it as a fit on our site, not as a mod part. On here we tell people about the mods unless noted as people on our site don't always use the forums. We can update it on our site to inform, thanks for pointing it out.
Old Mar 20, 2019 | 08:14 PM
  #183
MWMWMWM's Avatar
MWMWMWM
I used a home depot plug with the threads filed off and it fits very well.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
