Drivetrain Not So Good Vibrations
Old Nov 20, 2009 | 06:15 PM
BlownWS6's Avatar
BlownWS6
Hello everyone, I have recently purchased my dream Mini. It is an 03 MCS Indi blue. It has only 18,000 miles on it. Recently I have noticed the car shaking under acceleration in 3rd and 4th gear around the 4000 RPM area. None in 1st and 2nd, and a little in5th and 6th. I am new to the front wheel drive car. Any help would be appreciated greatly. P.S. any Indi Blue clubs out there
Old Nov 20, 2009 | 07:39 PM
R53Warrior's Avatar
R53Warrior
Im guessing thats the bypass valve issue? There are some modifications you can make or purchase the Detroit Tuned replacement that eliminates it. Its caused by the valve not closing correctly or something like that
Old Nov 21, 2009 | 08:43 AM
BlownWS6's Avatar
BlownWS6
Thanks, Ill look into that. Why would it only do it in higher gears though?
Old Nov 21, 2009 | 01:03 PM
Driv3r's Avatar
Driv3r
it might be your wheel balancing, go to a tire garage and have your wheels balanced. Mine did the same when my balancing was out. When driving on the freeways..thats usually slightly higher speeds when driving in urban areas..the steering started shaking/shuddering
Old Nov 21, 2009 | 02:26 PM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
While you are getting your wheels balanced, have them take a look at the drive axle (CV axle).
It may be an outside chance because you have such low miles but my 03 started vibrating at around 85k miles. It would only vibrate while accelerating (under load) but not when I let off the gas and coasted. I had the same issue with my 02 Silver MC just before I sold it.
Hope it helps.
Old Nov 21, 2009 | 02:40 PM
tazio's Avatar
tazio
I got some vibration at speed under throttle in higher gears. My lower motor mount had gone bad. $30 and about 20 minutes to replace.
Old Nov 21, 2009 | 02:49 PM
onasled's Avatar
onasled
Hmmm, an '03 with only 18K on it. This means the car has been sitting for long periods of time and I might bet on original tires. Might have flat spots by now.
So hard to diagnose something like this without inspection as it could just be a bunch of things.
Old Nov 22, 2009 | 11:58 AM
BlownWS6's Avatar
BlownWS6
Thanks for the replys. I will have to look into these things one at a time. The one thing that makes this such a weird problem is that it doesn't vibrate at all in first or second. You can take it all the way to redline in 1st or 2nd and it is smooth as butter, third it starts @ 3800-4000 and by those rpms in 4th I am backing out for fear of tearing something up. Also, I have another problem now, someone rearended me on the way home from work. It only damaged the rear bumper cover. I hate to have to repaint on a car in this good of shape, but I guess this is a good time to look into adding an aero kit!
Kimolaoha
Dec 5, 2020 09:32 PM
maestro39
Oct 27, 2015 02:38 PM
h0micide
Aug 27, 2015 09:17 PM
h0micide
Aug 25, 2015 12:19 PM
Aug 21, 2015 10:41 AM
