Drivetrain Horrible noise coming from pulley/engine
Old Oct 4, 2009 | 05:42 AM
super c00pers's Avatar
super c00pers
I've had a 15% pulley fitted and new belt which originally I had a belt fitted which was too big and so there was a horrible clattering noise coming from the belt tensioner.
I have now had the recommended small belt fitted and when I picked it up it was fine.
I drove the car for about 100miles and everything was great. When I got home I left the car for about 5hrs to then start up to this noise.
http://www.youtube.com/watch?v=EQLUOb11tgA
I've had a new tensioner fitted so it can't be that.
Please can anyone explain to me what this noise is??
Old Oct 4, 2009 | 06:19 AM
stevecars60's Avatar
stevecars60
Is the noise the same, before & after the belt & tensioner change?
It sounds like a piece of the belt seperated and it's slapping. If this is NOT the problem, it's not good.
Old Oct 4, 2009 | 07:18 AM
moreorless's Avatar
moreorless
I think you're correct.....belt slap.
Old Oct 4, 2009 | 07:28 AM
stevecars60
Lets hope so.................
Old Oct 4, 2009 | 09:06 AM
firenewt's Avatar
firenewt
I agree on the belt. Noise doesn't have the metal on metal sharp clack. Sure hope that's the problem. Keep us informed.
Kevin
Old Oct 6, 2009 | 05:50 PM
mininuke's Avatar
mininuke
Any updates?
Although it could be a belt flap as mentioned above, how would the separated/broken belt go through the upper pulley and the tensioner arm since the gap is very small. I may be wrong but it could also be internal. It sounds exactly the same as pontiac fiero I had with a bad crankshaft bearing. I hope not this is not the case for you. Good luck!
Old Oct 6, 2009 | 09:34 PM
MrCooperS's Avatar
MrCooperS
Moderator
Could it also be a bad crank pulley? (Pulley separating from the harmonic damper?)
Old Oct 7, 2009 | 06:25 AM
checkmate2006's Avatar
checkmate2006
It sure is. I had a lightweight crank pulley shatter on me . It started out to be like bad pulley bearing then it came off center causing it to wobble and clank . Get yourself a new ATI Super Damper Crank Pulley
Old Oct 7, 2009 | 07:09 PM
Silkworm's Avatar
Silkworm
Im going through this right now. The tensioner dampner has two bushings on each end that suck a big donkey (lets just call it a pancake) my spring is all good I can see almost the full hole. its not just sound though the lack of those bushings are undermining your dampner and making the belt skip im sure and this will make it have wear spots and prematurely fail. Im about to try powerflex replacements for the two bushings on the tensioner to see if it helps.
Old Oct 14, 2009 | 07:27 AM
TunaMini's Avatar
TunaMini
Any Updates.
My car has the same issue. I took it in for service after the car started eating the side of the belt. The dearlership ended up replacing the pulley and crank pulley. Eveything was fine initially then started with this noise that you have a few days later.
I had a mechanic look at it and he said that the pulley may not have been aligned correctly. He aligned it for me and it worked good for a little while and now the problem is back.
Old Oct 21, 2009 | 06:01 PM
Silkworm's Avatar
Silkworm
pop the hood and look at the tensioner if its shaking a bunch thats the problem it will do this even if you have a full hole showing. Have you had any non dealer work done that required the belt off mabye they didnt have the tool and messed up the dampner on the tensioner? Id like to think the dealer would catch a bad tensioner though.
Old Oct 21, 2009 | 07:28 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Well it could be any one of the parts touching the belt. But I'd first check to make sure the pulley is on correctly. Then I'd check those bushings on the tensioner, if they are cracked or mushroomed I'd replace them with the powerflex supercharger damper bushings.
Then I'd check the damper, make sure it's not coming apart, and also clean the belt grooves. If you end up needing a damper the ATI damper is the way to go.
Getrieben
Sep 12, 2024 07:03 AM
Melvinyip
Apr 17, 2020 09:28 AM
maestro39
Oct 27, 2015 02:38 PM
damncajun
Aug 17, 2015 08:25 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
