Drivetrain Problems with Alta boost tubes, check yours!!
Old Nov 13, 2009 | 03:36 PM
  #76
R55lover's Avatar
R55lover
Originally Posted by Kirkland
alta's position is that you buy their parts and keep quiet when they break!
Do cracks like this really help the community?
Old Nov 13, 2009 | 03:51 PM
  #77
sir5150's Avatar
sir5150
After waiting for 3 weeks to get a call tag then two weeks to get back to me once they got it back they have no more black intake tubes and will no longer be making them.... offered a red one or wait for the new hard tube to come out in another month or so at least. they look like crap, will not give refunds on used items. I guess i have to wait some more.
Old Nov 23, 2009 | 05:33 PM
  #78
baboon7's Avatar
baboon7
NM now have this
Old Dec 21, 2009 | 04:57 PM
  #79
scottab36's Avatar
scottab36
So I repaired my ALTA hot side boost tube on Louise today. It's was rubbing on a heat dissipation coil bracket which is mounted to the back of the fan shroud housing. I again used the wide natural rubber electrical wrap. I then used black zip-ties to cover the electrical tape. It is the same repair I did on the ALTA cold side to intake boost tube that was rubbing against a bolt head on the valve cover.
Also the heat dissipation coil bracket appeared to be broken and loose so I zip-tied it back to the fan shroud assembly.
So is is another opinion about the oil catch can:
At almost 46,000 miles there was no detectable oil residue in the hot side boost tube coming off of the turbo.
IMHO, with no neglicable amount of oil residue coming in from the inlet boost tube, which has a feed feeds off of the valve cover, it is worthless to mount the oil catch can where recommended.
The oil catch can should be mounted where the PCV valve hose comes off of the valve cover.
Additionally, this also indicates that there is no significant oil blowing by the turbo bearings.
The pictures are below:
This is what the boost tube is/was rubbing against:
Here is the damage to the ALTA hot side boost tube:
Old Jan 3, 2010 | 07:27 AM
  #80
Arnel's Avatar
Arnel
Crap. I've been away from the forum since the summer (had a baby back in Aug). Now i have to check my hoses. I don't put alot of miles on the Mini, so we'll see.
Old Jan 6, 2010 | 03:18 PM
  #81
Noegel's Avatar
Noegel
I just replaced my cold with NM-Engineering hard pipe and I also had a hole rubbing in my ALTA Tube. The inlet hose also had a hole being rubbed in from the coolant bottle.
Old Jan 6, 2010 | 03:24 PM
  #82
JamesHunt's Avatar
JamesHunt
Boost tubes are a waste of money on the mini
Old Jan 7, 2010 | 05:07 AM
  #83
MT Don's Avatar
MT Don
I have a new, unused hot side hard pipe Exhaust Depot boost tube for sale. With this mandrel bent hard tube, there will be no more need to worry about abrasions in the hot side tube.
PM me if interested
Old Jan 23, 2010 | 02:30 PM
  #84
LedRobster's Avatar
LedRobster
Hey guys, checked my tubes today and found a pretty easy fix for some if the rubbing issues. I just grabbed a couple of the old hose clamps from the OEM setup and wrapped the tubes where there was rubbing. On the small rubs the metal from the clamps protect the tubes and hopefully the clamp can seal up any small perforation. Hopefully it holds out.
Old Jan 25, 2010 | 04:34 PM
  #85
krim's Avatar
krim
I put a dab of silicone bathroom sealant under the clamp, just in case. Helps hold the clamp in place as well.
Old Jan 26, 2010 | 05:20 PM
  #86
hogrules's Avatar
hogrules
I came across this product.
Thermo-Tec Thermo-Shield Hose & Wire Protectant Tape
This may help in the areas where the hoses rub. Any Thoughts?
http://www.autobarn.net/thhowiprta.html
Old Jan 27, 2010 | 08:56 AM
  #87
slinger688's Avatar
slinger688
I don't think this product will help much...
Old Feb 14, 2012 | 12:42 PM
  #88
ThatCooperS's Avatar
ThatCooperS
Sorry to bring this back from the grave
Sorry to bring this back from the grave. I just recently bought the hot side boost tube for my 2011 cooper s. after I purchased this I found this thread. I want to find out if this issue has been resolved before I install it, and if this is even an issue with the 2011's. Thank you!
silence2-38554
98
Sep 21, 2016 02:52 PM
AWOL
Mar 28, 2016 10:51 AM
wkp1219
Nov 13, 2015 07:52 AM
stierzy34
Sep 15, 2015 04:40 PM
