Drivetrain Dyno Disappointment.
Old Sep 2, 2009 | 01:04 PM
AkFarina's Avatar
AkFarina
I got my car dynoed today and it blew my mind. numbers sucked.
161hp
181tq
4th gear
sport on
dsc off
it was a dynojet winpep 7
run type: RO, 79 f, 30.00 in-HG, humidity 27%, SAE0.97
Old Sep 2, 2009 | 01:19 PM
MotorMouth's Avatar
MotorMouth
Are you completely stock? How many pulls did you do? What boost peak did you hit? I remember you mentioning you had a gauge.
If you are completely stock those aren't bad numbers for at the wheel.
Old Sep 2, 2009 | 03:52 PM
AkFarina's Avatar
AkFarina
just an exhaust and intake 3 pulls peak boost was 14ish and it held there. the shop guys were saying that my car was starving for fuel and i need a tune bad.
Old Sep 2, 2009 | 04:06 PM
MotorMouth's Avatar
MotorMouth
sounds like you didn't hit over boost if you've seen 17lbs boost before.
very unlikely your car was starving for fuel since you are basically stock.
Old Sep 2, 2009 | 04:18 PM
countryboyshane's Avatar
countryboyshane
Sounds like he needs some RMW magic.
Old Sep 2, 2009 | 04:32 PM
MotorMouth's Avatar
MotorMouth
all of us need that!
Old Sep 2, 2009 | 04:57 PM
old81's Avatar
old81
M6
First we ned to know some things, Dyno type? How hot was the bay/garage area? Are you at sea level?
Did they do the pull in 4th gear or if an auto in 3rd? Did they turn off DSC? etc.
Not bad numbers. What intake, what exhaust. Any boost leaks due to loose tubes, etc. How clean was the intake filter?
Don
Old Sep 2, 2009 | 05:10 PM
not-so-rednwhitecooper
Dyno numbers are worthless when compared to other cars. You need to compare your baseline to whatever future pulls you make, on the same dyno. There are too many variables. All you should care about is the delta number, nothing else.
1/4 mile times are a better indication of true power.
Old Sep 2, 2009 | 06:53 PM
AkFarina's Avatar
AkFarina
Alta CAI, straight pipe from dp back.
4th gear
sport on
dsc off
Old Sep 2, 2009 | 07:11 PM
old81's Avatar
old81
M6
So, not 2nd cat, no resonator and no muffler. Is this a 3 inch pipe?
Alta's CAI should be at least 6 to 10 over base HP, what boost was noted by the dyno guy or on your gauge during the run?
@not-so, dyno runs can be useful, as you said it is the delta that shows the power, torque curve looks good on this graph. I would have expected better, but I suspect the open pipe might be an issue.
Don
Old Sep 2, 2009 | 07:17 PM
AkFarina's Avatar
AkFarina
2.5 inch pipe. and there are no cats 2.5 turbo back 14lbs was noted. the only thing i have over stock is i spool faster
Old Sep 2, 2009 | 08:18 PM
slinger688's Avatar
slinger688
Now you need to put all the Mini stuff back to get another dyno for comparison. Then you will really know if all this after market stuff is worth anything. In my track experience, I have a feeling that many of these bolt ons do not do that much except add some sound.
As not-so suggested, go to the drag strip for some real world tests. You should be looking at 0-60 mph around 6.2 - 6.5 seconds.
Old Sep 2, 2009 | 08:35 PM
AkFarina's Avatar
AkFarina
oh i can tell it is was quicker over a stock mini. And if i drag a stock mini i kill it. but the numbers were just so low.
Old Sep 2, 2009 | 08:46 PM
ThumperMCS's Avatar
ThumperMCS
They're not that low...torque might be a little low...but your car is essentially stock, so I'm not seeing the issue.
What year is your car?
Overboost might not have engaged either....
And what kind of shop was it...Like what kind of cars do they normally see? If they're not used to seeing the A/F curve of our DI motor, it will surely make them cringe at how lean it is. But you have stock software...its normal.
AkFarina's Avatar
AkFarina
its 09
Old Sep 2, 2009 | 09:19 PM
chakraj's Avatar
chakraj
Hmmmm, maybe they are tuning lower each year to prevent damage.
I was just at the dealer for a service light. But it wasnt a oil change after all it was a scope test?? Then they made note of my intake, exhaust, and suspension upgrades. I swear that they de tuned me for a second time. Once when they detuned the 08s, on a service visit before I knew not to let them. Then this time when I think my car may have thrown a service light related to my mods and they de tuned me again.
Either that or I am just crazy, I give it 50 50 chance either way
Old Sep 2, 2009 | 09:39 PM
JIMINNI's Avatar
JIMINNI
I agree, whats happening here on NAM is that everyone is expecting over inflated numbers.
Old Sep 2, 2009 | 09:45 PM
chakraj's Avatar
chakraj
Ya my Scangauge II says I have 230HP. Sweet!!
JK, of course, I mean it does say that. But I know it cant be real with out a tune.
Old Sep 2, 2009 | 10:47 PM
You don't understand. The numbers are relative ONLY to your car.
You didn't make a baseline run bone stock, so you will probably never be able to get a true delta to see what kind of improvement you made.
Old Sep 2, 2009 | 11:18 PM
MotorMouth's Avatar
MotorMouth
I'd bet on crazy. They do not "detune" your car. There is a set map that ALL the same model/year MINIs have. If you come in with mods they do not have a special map to put on to make your car slower.
In 07 they did have a new map which regulated boost more "efficiently". The newer cars since then have the same map.
Old Sep 2, 2009 | 11:22 PM
chakraj's Avatar
chakraj
well there was a ECM upgrade the first few months I had my car. It was a new map, a detuned map. Now I dont know what they did this time??
NYMADMINI
Dec 14, 2016 02:33 PM
slash695
Apr 26, 2016 06:27 AM
USA-RET
Nov 9, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
