Drivetrain Putting a Mini SC into an Alfa Romeo
Old Aug 29, 2009 | 06:37 PM
scbody's Avatar
scbody
Hi folks
I'm considering supercharging my 91 Alfa Romeo Spider using a Mini supercharger.
I don't want/need the water pump setup at the back. Has anyone heard of, or thought about, what would happen if I blocked of the back of the unit by removing the back plate with its gear and replacing it.
Also, any other thoughts from those more experienced than I would be very gratefully received.
Regards
Simon
Old Aug 29, 2009 | 06:45 PM
not-so-rednwhitecooper
You would be better off getting a supercharger thats a bit more universal.
The MINI supercharger has brackets and bolt holes cast into it for use on the MINI specifically.
http://www.thefang.co.uk/eaton.htm
This is more of what you would want.
Old Aug 30, 2009 | 06:11 PM
scbody's Avatar
scbody
Nice package
Perhaps true Rick, but its a well designed and compact package that actually fits the Alfa and isn't toooo expensive.
Thanks for the comment
Old Aug 30, 2009 | 08:35 PM
Some Guy's Avatar
Some Guy
You shouldnt have any problems taking out some of the parts and putting a plate over it. This is what you do when you convert the car to an electric water pump and still want to keep the supercharger.
Old Aug 31, 2009 | 04:17 AM
scbody's Avatar
scbody
Perfect
Thanks Some Guy
That's what I needed to know.
Simon
Old Aug 31, 2009 | 05:01 AM
onasled's Avatar
onasled
Simon,
Really don't even need any plate. I just removed the water pump.
Here is a mercedes 190 16V with one.
Old Aug 31, 2009 | 05:34 AM
Dr Obnxs's Avatar
Dr Obnxs
My FIAT mechanic
is thinking about doing the very same thing. Really, it's a question about how much it costs to get the SC and will it fit where you want it to go.
Have at it and let us all know how it works out!
Matt
Old Aug 31, 2009 | 05:32 PM
scbody's Avatar
scbody
Yep
Greg
Both of those setups look pretty good. I think I will take the back plate off and fab a blank plate, as the water pump gears were shot.
How did you get the intake to stay on? That throttle body looks like it is not supported but it might just be the angle of the pic.
Many thanks for the encouragement from you and Dr. Obnxs
Simon
09R56
Nov 16, 2022 10:49 AM
maestro39
Oct 27, 2015 02:38 PM
bc219
Aug 10, 2015 11:22 AM
kvnadriano
Aug 10, 2015 08:48 AM
