Drivetrain Is the intake tube from the grill necessary?
Old Aug 21, 2009 | 09:43 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
My car was just in the shop to get a replacement throttle housing. I have a DDM intake box and a blue Alta silicone tube. When I got my car back they left off the black plastic tube that goes from the grill to the bottom of the intake box. The tech said that the Alta tube fit too tight and he could not get the black plastic one back on properly and that it wasn't needed. I know the aftermarket intakes pull most of the air from the cowl, but won't it also pull in hot air from the engine now? Is that tube necessary, or should I just leave it off?
Old Aug 21, 2009 | 10:35 AM
not-so-rednwhitecooper
I really doesn't matter, but it does fit with an aftermarket intake and silicone tube.
Old Aug 21, 2009 | 11:20 AM
Mike S's Avatar
Mike S
They were just lazy to put it back. Mine fits without anything pushing on it with loads of room.
Old Aug 21, 2009 | 12:34 PM
MrCooperS's Avatar
MrCooperS
Moderator
Yeah, mines fit there too.. I would rather have them complete the job.
Old Aug 21, 2009 | 12:56 PM
iwashmycar's Avatar
iwashmycar
if it goes to the air box and CAN be functional id put it back on.
on my intake (i know different but still) the stock tube would have just had air going to nothing so its gone
Old Aug 21, 2009 | 03:16 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
There has been evidence posted here on NAM, some years back, showing that at higher speeds there is a positive air flow in that duct to the airbox. It also seals the hole at the bottom front of the airbox, which in your case is currently allowing a whole lot of hot engine air directly into the airbox (bad!)
You'll see in my case, that I removed the Helmholtz resonator and moisture catch tubes from the duct, but that's just 'coz I'm a loony...
Old Aug 21, 2009 | 05:42 PM
Camthewookie's Avatar
Camthewookie
Do you by any chance have an automatic? Not sure whether it matters or not, but the engine is about 1/2" closer to the passenger side of the car and a little higher than one in a manual transmission car. Might make a difference in clearance.
Old Sep 21, 2009 | 08:47 PM
dustinhxc's Avatar
dustinhxc
mine fit with alta silicone no problem!
rtk90
Aug 29, 2019 09:08 AM
molala
Oct 2, 2015 01:53 PM
tag1260
Sep 2, 2015 07:42 PM
Sep 2, 2015 09:05 AM
