Drivetrain Plasma coils worth the cost?
Old Aug 7, 2009 | 05:19 PM
unclemeat's Avatar
unclemeat
Anybody check out the latest vendor announcements? One vendor seems to now be selling aftermarket ignition coils for the R56. I wonder if that is a weak point and relevant area of the car to modify.
Here's the NAM link to the vendor's post...
https://www.northamericanmotoring.co...-cooper-s.html
Best regards
Old Aug 7, 2009 | 05:57 PM
MotorMouth's Avatar
MotorMouth
I doubt it actually increases hp or torque but who knows?. Guess we need a someone to test it.
Pretty sure the first gen people debunked them long ago.
Old Aug 7, 2009 | 05:58 PM
vmk82's Avatar
vmk82
not for $600...
Old Aug 7, 2009 | 08:43 PM
Porthos's Avatar
Porthos
Those ones no. The Okada Projects yes.http://www.dragsport.com/issue/2007/0707_tech.shtml
Old Aug 7, 2009 | 10:14 PM
countryboyshane's Avatar
countryboyshane
We've got a long way to go for the prince engine to get high numbers like the tritec can bust out...
Old Aug 8, 2009 | 12:00 AM
MotorMouth's Avatar
MotorMouth
define high. HP or torque?
hp no, but try to get a tritec to 250lbs torque atw
Old Aug 8, 2009 | 10:00 AM
Porthos's Avatar
Porthos
Hey it's all about hp/lbs then just hp. Drop some weight and tell me that you don't notice the difference.
Old Aug 8, 2009 | 10:14 AM
ricbow's Avatar
ricbow
thanks for the thread , had same questions . answered
Old May 1, 2010 | 01:23 AM
donuttang's Avatar
donuttang
recently, got 2nd hand ones for half the price.....can feel more power...throttle is a bit lighter, 3k rpm does feel more pick up...more sensitive when step on it...
Old May 1, 2010 | 06:09 AM
ENGINE 58's Avatar
ENGINE 58
I say we need a group buy on them . Get them down to about 300 bucks . Id be in.
Old May 3, 2010 | 02:53 AM
czar's Avatar
czar
Definitely worth the cost, and when combined with a colder heat range (8) plug, then it's a win win situation.
www.okadaprojects.com/usa/applications.htm
Old May 3, 2010 | 02:54 AM
czar's Avatar
czar
Old May 7, 2010 | 01:56 PM
tvrgeek's Avatar
tvrgeek
There is so much snake oil in the spark plug/coil domain it is very hard to identify what is real. "Back in the day" ignitions were so weak, a lot of these techniques had noticeable improvements. ANYTHINIG would help the ignition in an original Mini! In the days of super emissions, the OEM is forced to fire every cylinder every time. Actually the ECU will throw a code if you don't.
We see stickers on serious high dollar race cars. Problem is, you don't know if it is because it goes faster, or does no harm and provides sponsorship money.
All that said, there is some science behind some of it. The goal is to ignite all of the charge at the correct time, every time. You can't do better than that. But that is really difficult. For me, I would need to see real dyno numbers, and not from some weekend tuner mag. As we have COP already, I suspect there is not much to gain. If something as simple as a new design coil or new design plug really provided that big an improvement, I assure you , every OEM would put it on. (COP is a good example. Much more expensive, but works much better) Show me the tests!
Filmy
15
Jun 6, 2023 06:27 AM
iclancy82
Jan 2, 2021 08:59 PM
minimofo
Sep 20, 2015 05:17 PM
muddflapp
Sep 20, 2015 03:55 PM
voip-ninja
Sep 16, 2015 01:50 AM
