Drivetrain Is it possible for an ECU to raise the MCS power by 40 HP?!?
Old Jul 3, 2009 | 08:30 AM
bssiesmth's Avatar
bssiesmth
I was looking at this page...
http://www.delriopower.com/productos...motor_chip.htm
40 HP / 50 lb/ft from just an ECU upgrade.
Is this even possible? Every ECU upgrade maybe raises the power by 10, 15 HPs. Would such an upgrade be safe / possible?
Old Jul 3, 2009 | 08:37 AM
Oxybluecoop's Avatar
Oxybluecoop
Anythings possible in Mexico
Old Jul 3, 2009 | 09:23 AM
bssiesmth's Avatar
bssiesmth
Yeah, I thought about it, too. And apparently, those guys are using the "turn the screw twice and you'll get more power" trick (modifying the actuator's travel).
I don't think so..
I like warranties, so Santa will probably bring me a JCW Stage 1 kit instead. :D
Old Jul 3, 2009 | 10:11 AM
ThumperMCS's Avatar
ThumperMCS
To get a peak gain of 40 hp and 50 ft lbs...not likely.
However, it could be possible to see gains of that magnitude in certain parts of the rev range...
Old Jul 3, 2009 | 11:53 AM
Ottoman_FD3S's Avatar
Ottoman_FD3S
since the ECU controls boost.. another 5-6 Psi could achieve 40hp
yeah I think it's possible..
it's an Ecu reflash.. why not?
Old Jul 3, 2009 | 01:44 PM
bssiesmth's Avatar
bssiesmth
I don't know.. the thing is, I haven't seen such kits offered anywhere else.
I called those guys and they told me they just interfaced through the OBDII port, made a backup of my software and uploaded the new one.
They do claim 40 extra HP. I don't know if it's peak or not (I suspect not). And they are one of the most respected tuning companies around here.
I really don't know whether to risk my car. Apparently, the JCW Stage 1 kit is far too expensive for what it does, anyway.
Old Jul 3, 2009 | 07:06 PM
MotorMouth's Avatar
MotorMouth
40hp - no. 40 lbs torque - yes.
Some person might say yes to 40hp gain, but if you did a dyno before and after you'd see it doesn't.
30hp wouldn't be out of the question.
Old Jul 3, 2009 | 08:23 PM
ThumperMCS's Avatar
ThumperMCS
As I said earlier, you might see upwards of 40-50 horsepower AND ft-lbs of torque at certain parts of the rev range. Below is an example of an RMW tuned car....almost 50 hp gain near the redline...but only 30 hp gain in peak hp. That extra 50 near the top end makes a world of difference...let me tell ya.
Originally Posted by Revolution Mini Works
this is the dyno of the bone stock R56 S
gains at 6300 are 43ft lbs of torque and 49.8 hp
Old Jul 3, 2009 | 08:30 PM
MotorMouth's Avatar
MotorMouth
not bad thumper!
Old Jul 3, 2009 | 08:33 PM
Porthos's Avatar
Porthos
Do it and find out.
Old Jul 6, 2009 | 08:49 AM
bssiesmth's Avatar
bssiesmth
Those graphs look awesome.
Coming from a Civic Si, I really miss the top end power (I'd trade it again and again for the low end torque of the Mini, though). How many mods did it take to achieve those gains? (Sorry, I think it has been discussed before, but I can't remember).
Old Jul 6, 2009 | 09:12 AM
ThumperMCS's Avatar
ThumperMCS
That dyno sheet is stock, with RMW Tune only.
Old Jul 6, 2009 | 09:28 AM
bssiesmth's Avatar
bssiesmth
Wow... I'll search for info on that! I'm now thinking that the tune that these guys are selling me is similar to the RMW. If so, I'll definitely go for it (at $600, I think it's fairly priced).
Old Jul 6, 2009 | 09:29 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
It'd be interesting to see what they can get out of your car. Especially since you apparently have a non us spec car. When I tune an R56 the 40lbs of torque is pretty typical, the HP numbers vary depending on mods. But torque is what moves it. Good luck
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jul 7, 2009 | 05:27 AM
bssiesmth's Avatar
bssiesmth
Yes, it's non-US spec. Although the only difference I can see is that I don't have the tiny reflectors on the fender protectors.
I'm sure there are more differences, though.
Old Jul 7, 2009 | 06:32 AM
iwashmycar's Avatar
iwashmycar
its at least a lot quicker!
While im sure the 5 lbs i added w/ a PnP didnt net 40hp, its a lot more fun to drive
iggi
18
Feb 9, 2026 01:00 AM
HaveATank
Sep 4, 2015 08:04 AM
Aug 21, 2015 11:18 AM
Lschneider
Aug 21, 2015 02:21 AM
minipopkart
Aug 13, 2015 05:22 AM
