Drivetrain scangauge question
Old May 30, 2009 | 06:06 PM
Malcon's Avatar
Malcon
scangauge question
I just got a ScanGauge II.
I'm trying to clear my check engine light.
I had a cylinder 4 misfire. But everything is ok now...
I go into the scangauge and clear the codes... but it doesnt turn off my light.. and then right after that if I rescan for codes. the same ones pop back up... I drove the car for a while and its not misfiring.
I'm getting code P0304, and P000C
I cant figure out what the P000C is.. anybody have an idea?
is there something else I need to do to clear the codes???
thanks again for the help..
-Malcon
Old May 30, 2009 | 06:31 PM
Eric_Rowland's Avatar
Eric_Rowland
A google says:
P000C "A" Camshaft Position Slow Response, Bank 2
As for solutions, start with checking spark plugs and wires, and go on from there.
Old May 30, 2009 | 06:40 PM
Malcon's Avatar
Malcon
Dah... Camshaft position slow response? .. that sounds serious. Yes I'll go check plugs and wires etc... thank you very much..
Old May 30, 2009 | 06:56 PM
kapps's Avatar
kapps
I'm not sure how MINI does it but cam position sensors are usually used to determine which cylinder is firing for sequential ignition systems. A slow responding sensor might trigger a misfire.
Old May 30, 2009 | 07:09 PM
Malcon's Avatar
Malcon
well.. what happened is I got some water on the engine.. I had to open the bonnet and it had been raining and all the water that had collected in the crill etc got all over the valve cover and spark plug wires. Then when I cranked it It was only running on 3 cylinders.. once it dried out everything went back to normal...Or so it seems... I guess some water leaked in the spark plug wire or something...I'm going to replace the wires.. I just put the plugs in a few months ago...
thanks for all the input.
Old May 30, 2009 | 08:47 PM
Intense's Avatar
Intense
252whp 200trq RMW style
When reseting your codes do you have your key in the acc #2 posistion?
Also there are some codes that only the dealer can clear. I don't have a list of those tho, sorry
Old May 31, 2009 | 07:09 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
malcon: sometimes my SGII doesn't clear the code. It's to do with the sequence. Turn off the car, turn on to position 2, clear the code. Turn off, turn on the car till it runs. You may have to wait a cycle--drive around the block or two. I think that should do it.
Phil
shorenetworks
Nov 4, 2019 06:18 PM
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
