Drivetrain Need a BOV?
Old May 17, 2009 | 09:01 AM
iporkgoats's Avatar
iporkgoats
Need a BOV?
I was looking to replace the boot tubes and turbo inlet. With the less restrictive pipes am i going to need a BOV?
Old May 17, 2009 | 10:08 AM
yellowbritishrocket's Avatar
yellowbritishrocket
u sure ur in the right section?this is the 1st gen section
Old May 17, 2009 | 10:21 AM
Malcon's Avatar
Malcon
I'm sure his not.
Try the 2nd gen...
We dont like to talk about BOV's over here...
haha
Old May 17, 2009 | 10:46 AM
MUShadd's Avatar
MUShadd
whats turbo?
Old May 17, 2009 | 10:49 AM
iporkgoats's Avatar
iporkgoats
thanks, i didn't realize where i posted this thread
Old May 17, 2009 | 02:24 PM
MUShadd's Avatar
MUShadd
im sure one of the mods will move this for you when they see it. i'd help if i could...only thing i know about blow off valves is that they sound cool
Old May 18, 2009 | 08:34 AM
Motor On's Avatar
Motor On
Moved, to where you'll get a more educated answer than us Supercharged gearheads can provide
Old May 18, 2009 | 08:39 AM
iwashmycar's Avatar
iwashmycar
i know that you do not, but i dont know exactly why. technically there is still a stock recirculator valve that takes care of the pressures generated, and by just upgrading the tubes its not a necessity. and yeah, they sound cool.
Old May 18, 2009 | 10:20 AM
dunphyj's Avatar
dunphyj
yeah... when you're on the cold side boost tubes, that little pipe that comes off the cold side tubes is exactly what it's called.... a noise maker... it takes the excess boost and does the VTA style giving you a little sound at the limit...
something that actually has to do with the BOV or stock recirculating valve is the forge motorsport adaptor... and any of the stock block plates like Alta has.... that's located basically right behind the turbo inlet part, and is controlled by the car's computer (to my knowledge anyway.... i'm not exactly sure how it works...) but i also know that if you have DSC on and you have forge's BOV, the engine supposedly cuts power by venting boost and you'd hear that...
another reason i'm sure that the noise maker isn't exactly a BOV is because NM Engineering is working on their cold side boost tube which deletes that... mainly because that noise maker has NOTHING to do with actual boost control... it's just a noise maker :P sounds nice ya know? i'm actually planning on selling my Helix13 BOV and alta cold side boost tube once NM comes out with their boost tube. anyway, i hope that helped a little bit ...
rtk90
Aug 29, 2019 09:08 AM
jdinh504
Dec 18, 2016 11:08 AM
MAGICIAN
Oct 13, 2015 09:29 PM
GAT
Oct 4, 2015 07:27 PM
TifosinDel
Sep 28, 2015 10:45 AM
