Drivetrain Home made R56 CAI system
Old May 12, 2009 | 03:28 PM
miniminime's Avatar
miniminime
Here's my home-made CAI system for my R56
It definately feels more responsive than my old filter fitted on the standard intake pipe.
Hope you like it
Old May 12, 2009 | 03:41 PM
got.pho?'s Avatar
got.pho?
looks great are you euro spec?
Old May 12, 2009 | 05:21 PM
slinger688's Avatar
slinger688
miniminime,
How did you anchor the filter box down? What is the think blue pipe and where does it go?
Old May 12, 2009 | 05:30 PM
miniminime's Avatar
miniminime
thx got.pho
yes it is euro spec!
slinger688
i drilled hole on the box and screwed it into the brackets for the
stock box. only 2 of the screws could be fitted though.
and i have NO IDEA what the thin pipe is, just covered that for some random reason.
Old May 12, 2009 | 07:22 PM
vmk82's Avatar
vmk82
its the vacuum line for the brake booster
Old May 12, 2009 | 07:57 PM
ThumperMCS's Avatar
ThumperMCS
Indeed...I'm not seeing a MAF...
Old May 12, 2009 | 10:08 PM
richi0207's Avatar
richi0207
Looking good! Good job Only opening is to the cold air source?
Old May 12, 2009 | 11:18 PM
ThumperMCS's Avatar
ThumperMCS
Looks like it uses the stock front cold air source, in addition to two tubes leading in from what looks like the rear cowl vent by the windshield. (can sorta seem em in pic 2)
Good work!
Old May 12, 2009 | 11:40 PM
Sketch's Avatar
Sketch
Thats pretty impressive man. Nice work.
I bought a cheap filter at Autozone about a month ago, wow does it sound nice! Didnt gain an HP, but that was my goal. Im not alowed to add HP to my car till after I graduate :D
Old May 13, 2009 | 07:44 AM
miniminime's Avatar
miniminime
Yes my R56 is euro spec. so the battery position should be the other way round.
The intake sources are indeed from the original intake tube, and two more from behind the "firewall", or whatever you call it.
This turned out to be pretty good because i still get a fair amount of COLD air for intake (and trust me, it makes a hell of a diff), and the sound also comes out from the windshield intake.
Question guys, i had to have my own breather pipe installed to fit into my 3" intake pipes, but the oil doesnt seem to be going back to the system.
it doesnt travel all d way down the pipe instead it runs backwards and sort of leaks out from the engine side of the pipe.
ANY SOLUTIONS??
David.R53
Sep 1, 2015 06:49 PM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
Aug 12, 2015 01:24 PM
