Drivetrain Boost Tubes - Silicon vs Hardpipe
Old May 9, 2009 | 06:30 AM
guitfiddler's Avatar
guitfiddler
What's the real performance difference? If any...
Old May 9, 2009 | 06:51 AM
PA-MCS's Avatar
PA-MCS
both are better then the factory rubber. Hardpipes might be more proned to heatsoak.
Old May 9, 2009 | 07:53 AM
dtsoccer6's Avatar
dtsoccer6
Depending on what you are doing with your car...silicone are great for moving air unrestricted, but hardpipes perform much better under higher boost because there is no expansion or collapse.
Personal experience, I had silicone before hard pipe was an option. If I were you, I would get hard pipes and save yourself the grief of possibly wanting them after you purchase silicone. Not that silicone is bad, but hard pipes will benefit you more...
my 0.02
Old May 9, 2009 | 08:06 AM
ThumperMCS's Avatar
ThumperMCS
Hardpipes or stock!
Old May 9, 2009 | 09:00 AM
n1tr0's Avatar
n1tr0
Hard pipes work equally well under boost and normal engine vacuum. They're not always as easy to make or to install. Hard pipes can also transmit a bit more noise. At least on the 'suction' side of the turbo, you need to have a hardpipe, that's why the stock intake has all the ribbing to keep it from collapsing and the JCW pipe is more rigid yet (dealing with higher boost).
Old May 9, 2009 | 09:49 AM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
Silicon is easier to install, you can bend it to get over some tight spots etc.
Silicon Is lighter than hardpipes.
Silicon hoses that have sensors and BOV flanges have been known to pop off the silicon under good boost, it comes off even easier when residual oil works its way in the silicon and into the connections. Yes boost generates residual oil and its normal.
Silicon at times is to short because the oem rubber piece when you remove it slings back into position so if thats used as a sample to make the silicon,they will make it based on the slinged back length of the OEM piece vs the extended length of the oem piece.
Pipe has more gentle turns vs silicon.
Old May 9, 2009 | 12:29 PM
masterd78's Avatar
masterd78
MANIAC
My ED pipes should be here Monday!! WOOT!
Old May 9, 2009 | 08:10 PM
Porthos's Avatar
Porthos
You can reinforce the silicone ones if you are that worried about them bulging
Old May 9, 2009 | 10:24 PM
PoktRokt's Avatar
PoktRokt
How??
Old May 10, 2009 | 03:41 PM
Porthos's Avatar
Porthos
My idea would be taking 1/2" plastic strips and and wrapping them around the tubes about 1" apart. That should cause a ribbing which should reinforce it. You can glue them on or figure another way to attach them. Now I haven't done this or know of anyone that has done this so it might or might not work. This is something that has been done to other piping in various forms to help.
Old May 11, 2009 | 09:56 AM
Exhaust Depot
For that you just use duct tape around it, its strong too.
Old May 11, 2009 | 06:50 PM
n1tr0's Avatar
n1tr0
ya that's the classy setup for a nice new car
or you could just start w/ hardpipes & not give it a second thought.
Old May 11, 2009 | 07:01 PM
DNadar's Avatar
DNadar
hard pipes are sexier, and we all know sexier = 30 hp
Old May 11, 2009 | 11:06 PM
PoktRokt's Avatar
PoktRokt
What about some spaced out zip ties or something similar??
Old May 12, 2009 | 01:04 AM
Porthos's Avatar
Porthos
Zip ties would be an awesome idea especially if you get the 1/4" type you could leave the lock part under the intake so that you wouldn't see.
The problem with duct tape is that the heat would melt the glue and it would end up falling off. On top of looking ugly as hell the zip ties would be a better idea especially if you color match it.
The last part is, I highly doubt that you will be pushing enough boost that you are going to see any kind of bulging in the pipe. The piping is pretty strong as is. Not as hard as metal but it will hold its own. Its personal opinion on you want they both have their pros and cons you just got to look at what you need in your car.
Old May 12, 2009 | 08:45 AM
PoktRokt's Avatar
PoktRokt
^^^^agree'd - I don't think we'll reach boost level pressures that could distort that piping.
Old Jun 8, 2009 | 05:58 AM
guitfiddler
Not enough boost to distort the silicone or hardpipe?
Old Jun 8, 2009 | 06:55 AM
dtsoccer6's Avatar
dtsoccer6
If your goal is to get a bigger turbo and upgrade the performance of the car on a more serious level, the hard pipes are better for 3 important reasons.
1. The hard pipes are not going to expand or collapse under high boost.
2. They are just as smooth as the inside of the silicone and fit much better in the engine bay. They do not rub up against anything and the install is so much easier. I had previous pipes rubbing against other areas of the engine bay which made it much harder to install.
3. The way the hard pipes are built are much better. The stronger clamps and flanged edges of the pipes ensure that the pipes/couplers won't come flying off under WOT situations or higher boost.
I had a silicone pipe blow off at the track and it was the first time I had the car at its limits. This was before my tune and my boost levels were around 14 to 15psi. Not a huge number, yet they blew off. And regardless of what anyone says, the pipe fit just fine, not too long or too short.
I been running my new hard pipe setup and though I haven't seen any gigantic gain, the butt dyno tells me the car is more powerful. My recent dyno day showed that to me as well. The safety and peace of mind is far greater now and I have more confidence in my driving at the track not having to worry about blowing a pipe and loosing boost in the middle of a race. Not very safe!!
Again, my opinion is that if your not going to go crazy with performance, they aren't worth the money. The stock pipes are setup perfectly for what you got, although restrictive, they are strong enough to handle stock boost levels.
If you are looking for better air flow, get the silicone. Looking for performance, get the hard pipes. Neither setup alone will net you big HP/TRQ gains, its what they contribute to the rest of the components.
My .02 - I have owned and used both.
Old Jun 8, 2009 | 11:43 AM
countryboyshane's Avatar
countryboyshane
Hearing a boost tube blow off must be quite a sound!
Old Jun 8, 2009 | 11:47 AM
dtsoccer6's Avatar
dtsoccer6
Yeah! Especially with the windows down, sounds like an explosion. I got so scared when it happened, I thought it was something in the engine at first.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Qik420
Oct 4, 2015 08:19 PM
Oct 1, 2015 12:13 PM
Qik420
Oct 1, 2015 12:02 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
