Drivetrain Mynes Headers Throwing Codes, Say It Ain't So
Old May 2, 2009 | 07:58 AM
big howe's Avatar
big howe
https://www.northamericanmotoring.co...07-post70.html
Quote:
Originally Posted by oxtox
greetings from the dragon! my car is pullin like mad
if you know someone at the dragon ask them if they heard the brg cabrio. i am the loudest car here....but have received many compliments.
a slight fitment issue with the milltek can...fixed. and in the interest of absolute truth (sometimes a novelty on nam) i got a p0420 code after cruising about 200 miles @ 75. a friend cleared the code and it has not occurred....and i have been doing at least 3 runs a day....and i have not been gentle.
Old May 2, 2009 | 08:43 AM
discodan's Avatar
discodan
OH SNAP!!!
Old May 2, 2009 | 08:51 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Despite stating the obvious that all this is quite funny, I'd like to report here that after 2 years or so of running my CMC header with race cat, I have passed emissions tests and never pulled an exhaust related code.
If you guys would simply call up Juston and stop messing around with these other headers it would all stop.
...or not.
Good luck with the Mynes header.
btw, might the problem not be with the header--but rather the interaction of the header with the catback system being run?
Old May 2, 2009 | 09:34 AM
//MZero's Avatar
//MZero
ROFLLMFAO!!!!!!
Thats all I can say.
Old May 2, 2009 | 11:25 AM
Revolution Mini Works's Avatar
...or not.
that's the funny part, we have race headers running for 2-3yrs with no codes too.... the more you make... the more chance that one will go bad. Not to mention there was like 6 or so of these that were made... what's the failure rate on that?
it's not the catback
Old May 2, 2009 | 11:26 AM
Longboard Mini's Avatar
Longboard Mini
Stuff happens!
Longboard
Old May 2, 2009 | 11:35 AM
I'll post up some instant classics.... this will be good
https://www.northamericanmotoring.co...0-post253.html
04-30-2009, 04:05 AM
ez1putt vbmenu_register("postmenu_2751660", true);
Gallery
If he had done the proper testing on his header, which it is obvious that he didn't, he would not be in this mess. You should not sell a product and depend on your customers to be beta testers it's not right.
Old May 2, 2009 | 12:50 PM
ez1putt's Avatar
ez1putt
Hey I know....Let's wait see how they handle it. THEN we can compare.
Old May 2, 2009 | 01:17 PM
You went from the kettle straight into the fire
Karma is a killer
Old May 2, 2009 | 01:50 PM
muladesigns1's Avatar
muladesigns1
What would make a header throw codes in the first place if you placed all the 02 sensors and such back where they belong?
Is the computer sensing to much air and not compensating?
Old May 2, 2009 | 01:58 PM
ez1putt's Avatar
ez1putt
Karma is a killer
And what do you mean by this???????
Old May 2, 2009 | 02:32 PM
//MZero's Avatar
//MZero
The P0420 code is simply a catalytic converter efficiency code...meaning the cat is not cleaning the exhaust enough.
http://www.obd-codes.com/p0420
The code that some got afterwards with the RMW header:
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
Is likely not related to the header or cat at all, but to the sensor itself. The sensors have wires that heat up the element to get them operating are reading correctly faster. If they are not heating up...P0036 becomes your friend.
Old May 2, 2009 | 02:37 PM
muladesigns1
So I assume that placement is fairly critical in order to get the rite temp and air flow readings then.
Old May 2, 2009 | 02:53 PM
//MZero's Avatar
//MZero
Placement of the sensor or placement of the cat? The 2nd sensor should be able to be placed anywhere after the cat except for below the horizontal position so that condensation can't accumulate on the sensor. Most companies put it back in the stock location though as wiring length is limited. The heating of the sensor isn't complicated at all, just a power wire and ground wire go to the sensor (4-wire sensor) and power the heating element internal to the sensor itself. As for airflow readings...well, in a round-a-bout way of saying, thats how a lot of people get away with having a less efficient cat. They take it out of the direct airflow and the sensor doesn't see all the same dirty air, thus thinking the cat is good.
Placement of the cat does matter as it does need to reach operating temp to work correctly, but again, the companies that make aftermarket headers typically put one in the same location.
The thing that is funny about this whole situation is that I remember reading some of Mynes posts bashing RMW because their header design wouldn't throw codes. In the end all companies will have a few hiccups. Its how they handle them that matters, I still respect Mynes, I just hope this humbles them ever so slightly because boy do they need it. Does this mean Mynes design is bad? No. But maybe it will make some people on here put on some fresh underwear to get their panties out of a bunch. Good luck Mynes, I'm sure you wont have many of these P0420's and that you will help out your customers
Old May 2, 2009 | 03:03 PM
muladesigns1
I meant placement of the sensor. Thanks for clarifiying it up for me.
as far as the "southwest war of the minis" goes, I'm switzerland
I met the guys from mynes a few times at some mini events, and they have been very friendly with me, there wrenching capabilities are superior to mine, so with that said.
I will stick to the cosmetics end of the industry. I like to repair and customize. I'll leave the "go fast" products to the pros!
Old May 2, 2009 | 05:08 PM
davisflyer's Avatar
davisflyer
I can't help but chuckle a little bit about this, given all the hype that the Mynes peeps gave to their header being code free.
Old May 2, 2009 | 05:19 PM
JIMINNI's Avatar
JIMINNI
What does this mean? They aren't humble enough for you? Also, I just checked the RMW code thread, and you know what........I see no posts from Mynes in there.........I already see 2 posts from RMW in this thread.....whats that tell you
Old May 2, 2009 | 05:47 PM
the platform's Avatar
the platform
Uhh oohhh!
I read the initial post last night....but refrained from zapping.
Looks like the story has broke now
After all the ***** slung towards RMW.
karma is a bizatch...aint it?
Old May 2, 2009 | 11:56 PM
Longboard Mini
Yes it is
LB
Old May 3, 2009 | 12:22 AM
//MZero's Avatar
//MZero
On the internet...no they sure aren't humble (and I didn't say that Jan is ). But I've never met the Mynes guys in person, and I honestly do give them the benefit of the doubt. They are trying to break into a market selling performance parts during hard times and have a great guy to compete with. Its not their motives I question, but their methods. I also never said the posts I read were in the "RMW code thread" simply that I read them.
As a person who has not a single RMW or Mynes part on his car, I believe I'm the market both parties are looking for. I've wanted RMW parts for quite some time, as they have been the best. Now with Mynes new to the game I CAN be swayed to the dark side, or is it the light side . But honestly this pissing match over the past few months is not how to win potential customers like myself over.
Anyway...I'm tired, and waking up for an autoX in Marina at 4:45AM. Good night
Old May 3, 2009 | 12:25 AM
//MZero's Avatar
//MZero
Oh, one more thing. This "throwing codes" thing really would NOT be a big deal AT ALL if certian RMW customers and Mynes didn't make it a big deal. It would have been handled.
Hence the overzealous joy for karmatic retribution by other members.
Old May 3, 2009 | 05:55 AM
Mini_Joe's Avatar
Mini_Joe
Originally Posted by Longboard Mini
Stuff happens!
Longboard
Not to mention... OBDII happens as well!
I remember when the Nissans went to OBDII in 1996 I believe... it made it very hard to remap the ECU, touch anything computer related, etc. back when they first came out.
Silly emissions!!!
Old May 3, 2009 | 06:58 AM
big howe's Avatar
big howe
Old May 3, 2009 | 11:01 AM
the platform
I usually comment when I've read my share of pedantic verse.
I don't post enough around here to be labeled overzealous.
I do however have copious amounts of zeal for driving my car .
Old May 3, 2009 | 02:15 PM
oxtox's Avatar
oxtox
big deal?
i posted the code because i've said a lot of good things about the mynes header, heck, i did a vid so that people could see/hear for themselves. in my posts, i said several times that i had no cel. i've had plenty pm's asking me about the header before and since the cel. surprisingly, people seem pretty interested in what the guy with one of the first mynes headers is experiencing.
anyhoo, since i had said at least twice in other posts that i had no code, i felt compelled to post about the code that occurred on my way to the dragon. it is not a big deal to me....but obviously is to others. i respect and like jan....has never been too busy to answer questions or help me. on the header, i decided to try mynes, they have also been very responsive. i suspect i'll be dealing with both in the future....so i was kinda bummed that my post turned into this thread.....the kind of stuff that will ultimately kill off nam if the bs continues to overshaddow the information!!
i'll keep everyone up to date in the mynes header thread.
