Drivetrain Question about fitment - ALTA Boost Port Adapter and AGS-R
Old Apr 15, 2009 | 12:55 PM
dtsoccer6's Avatar
dtsoccer6
Does the placement of the boost port adapter interfere with the placement of the AGS-R over the engine bay when installed? Will they touch or will they not even fit together? Anyone know?
Thanks in advance.
Old Apr 16, 2009 | 08:24 AM
iwashmycar's Avatar
iwashmycar
just put an ags on last night... seems to fit. intake was used so the foam pad was smushed and it does hit the firewall as i start driving... i need to go take a closer look around it, but seems sound overall
going to break out the clay
Old Apr 16, 2009 | 08:31 PM
dtsoccer6's Avatar
dtsoccer6
i have the ags-r, alittle different in the design...thanks for the info though!
Old Apr 17, 2009 | 04:10 AM
iwashmycar's Avatar
iwashmycar
ohh woops. i somehow thought the bottom pan was the same. way off lol
Old Apr 17, 2009 | 05:37 AM
dtsoccer6's Avatar
dtsoccer6
no biggie!
Old Apr 17, 2009 | 06:29 AM
uggbird's Avatar
uggbird
you have to trim out the bottom of the Ags-r if not you can't run the strut
brace and it will vibrate or buzz under heavy load. if you run the m7 strut brace i also had to trim out for the little brow or snail looking protrusion
on the back side of the valve cover,
Old Apr 21, 2009 | 04:17 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
dtsoccer6:
Sorry I wasn't able to answer this question for you. Sounds like others have had more problems with the intake itself, let alone combining the two.
If you do get a clear answer, PLEASE let me know and I will add it to the compatibility note.
Thanks again!
Old Apr 21, 2009 | 05:32 PM
dtsoccer6's Avatar
dtsoccer6
Yeah, unfortunately, it's a great intake system, but poorly designed - it does make too much noise in the engine bay.
Adam, I will let you know. Over time, I have come to realize that the rattling and constant modding of the intake is more troublesome and annoying than anything. I wish you made a RAM air style intake!
Old Apr 21, 2009 | 08:43 PM
ADAMSALTAMINI
stay tuned my friend, stay tuned! Working on some new stuff for summer / fall release! We do listen to clients i SWEAR!
Old Apr 22, 2009 | 04:43 AM
iwashmycar's Avatar
iwashmycar
FWIW (later searchers) it doesnt fit too well with the Super AGS either... i simply cut 2" of 1" dia coolant-type hose, then cut down the side and blanketed the boost port and wrapped a zip tie around in case. The sound is gone and im happy
edit: I should say the AGS doesnt fit to well with the boost port, not the other way lol
Old Apr 22, 2009 | 05:29 AM
dtsoccer6's Avatar
dtsoccer6
Thats too far away! With Jan's tune, I need to be able to get the best results possible and I'm seriously contemplating the DDMworks now, with a GTspec strut bar. Is it summer? PM me if possible.
Agreed, its not the boost port, its the ags-r. Hmmmm, DDMworks is looking better these days, I wonder how much I could get for my m7 ...we shall see..Thanks for the info iwashmycar!
Old Apr 22, 2009 | 08:48 AM
dtsoccer6's Avatar
dtsoccer6
Wait, does the DDMWorks RIS work with the boost port adapter?
Old Apr 22, 2009 | 09:00 AM
ADAMSALTAMINI
I will try to work faster!
Old Apr 22, 2009 | 09:18 AM
dtsoccer6's Avatar
dtsoccer6
Will it be a DDM style system that fits correctly with no issues with strut bars and misc engine components?
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
