Drivetrain EML light and loss of power
Old Apr 14, 2009 | 09:30 AM
slegorretac's Avatar
slegorretac
I have a MCS 2002 with 65,000 Km. and been driving it. Sometimes the EML light comes out and the car loose power. To resolve the problem, the car is moving I press the accelerator all the way, press the clutch, turn the ignition key off and on will accelerating al the tome. And the EML light comes off and the car recovers the power. They chenge de manifull and its doing the problem agin.
Can anyone tell me what the problem is and what are the parts that I have to change?
Thanks,
Santiago
Old Apr 14, 2009 | 10:17 AM
Mike@Mynes's Avatar
Mike@Mynes
Thanks,
Santiago
what part(s) were changed prior to running into this problem?
What year is your car? what mods? the more info you provide, the easier it is for us to trouble-shoot and provide u suggestions. Also a spell check would help too
cheers.
mike
Old Apr 14, 2009 | 11:09 AM
slegorretac
Thank Mike
I´m from mexico, sorry for my spelling.
I change the band of the enging on november 2008, then the clutch on february 2009. On march started the problem and a week ago the acceleration manifull.
My car is a Mini Cooper S Chili 2002 with 65,000 km.
Thank for the interest.
Santiago
Old Apr 14, 2009 | 11:44 AM
Mike@Mynes's Avatar
Mike@Mynes
Thank Mike
Santiago
ok, let me get this right:
- "band of the engine"? =?
- changing of the Clutch in Feb 2009
=> EML light problem starts
- changing of the intake manifold (acceleration manifold?)
Did i get the order correct? Do you have any leaks in the intake manifold? can you do a leak test?
Old Aug 14, 2009 | 05:31 PM
mcs2nr's Avatar
mcs2nr
wow..i have an 06/02 mcs...i change clutch and the same thing...eml light comes on and it goes into limp mode.....did you get this resolved...they told me the troutle body was bad..i change it...same thing....
Old Aug 14, 2009 | 06:49 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
See if this is throwing a code or two. Get an OBD-II code reader for a read-out. "Change the band of engine"=Changed the serpentine belt? If so, you may not have the right size and it's slipping. If so, it can cause the symptom you're experiencing.
Old Aug 14, 2009 | 07:07 PM
mcs2nr's Avatar
mcs2nr
will check tomorrow...the code i was getting before is with the troutle body....i change it out and samething...
miniuy
Oct 7, 2016 12:09 PM
Dec 23, 2015 10:36 AM
one73ronin
Aug 19, 2015 12:36 PM
Super Coop
Aug 17, 2015 05:09 PM
