Drivetrain USA Ragazzon DP owners... chime in
Old Mar 28, 2009 | 12:27 PM
MiniPOLACK's Avatar
MiniPOLACK
ok i need to see who installed the Ragazzon DP and was driving their car for about 2 weeks , and didnt get the check engine light.....I wish i could start the list :(
Old Mar 28, 2009 | 12:38 PM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
You WILL get a cel. Even with a fouler on it. The fouler just causes the CEL to come on a little later.
This week ill have a DP with a resonator built in ready for you guys. Ill add a fouler on it too so the cel wont come as often.
Old Mar 28, 2009 | 01:19 PM
a96bimmerm3's Avatar
a96bimmerm3
This thread is useless without pics
Old Mar 28, 2009 | 02:39 PM
AkFarina's Avatar
AkFarina
i have one and im going to take a trip to ny 400 miles or so and if it doesnt come on during that then i think we are good
Old Mar 28, 2009 | 05:33 PM
Exhaust Depot
https://www.northamericanmotoring.co...ml#post2716069
Old Mar 28, 2009 | 05:34 PM
Exhaust Depot
Take your fouler and stuff some steel wool in it, it will make it work even better.
Old Mar 28, 2009 | 08:53 PM
got.pho?'s Avatar
got.pho?
what happens if you plug up a fouler? sealing it off from the exhaust gas but not temp?
or a 90 degree elbow fouler?
Old Mar 28, 2009 | 09:22 PM
Exhaust Depot
you cant. The second 02 sensor has to read sometype of exhaust. You cant just remove it and have it read clean outside air etc. This will cause the o2 to give you a constant output were as the output has to be varied. I use to make electronic simulators back in the day that will just give you a constant swing of voltage.
On the newer cars it does not work to good because the emissions are much more strict.
YOu need to see correct temps and correct samples so you dont trigger a cel. You need to hit x amount of temp in x time , this is why you cant always put a 90 and have the sensor be far away.
Old Mar 29, 2009 | 04:02 AM
coopman7's Avatar
coopman7
Ive had mine fitted for almost 6 months and NO CEL No spacers etc fitted either.
So thats 1 for ZERO CELs.
Old Mar 29, 2009 | 06:37 AM
MiniManiac74's Avatar
MiniManiac74
I answered my own question after the post
Old Mar 29, 2009 | 06:43 AM
MiniPOLACK's Avatar
MiniPOLACK
coopman: so are you or are you not using a fouler?
first i was using a fouler, and check engine light came on in about week and a half . then when i looked at the code i noticed it said that its readings are too low (P1036). so i decided to redrill the small hole in a size where more exhaust gases could come in ( 1/2") , now i get the check engine light in like 2 days. i hate new cars, big pain in the butt to tune ( or to lie to , LOL)
Old Mar 29, 2009 | 07:08 AM
coopman7's Avatar
coopman7
I plugged my O2 sensors back in as normal, no spacers, foulers or anything.
Old Mar 29, 2009 | 08:05 AM
Exhaust Depot
Whats this? "Cooper S P-Torque Stage 1 ECU Remap" in your sig? The mopar stage 1 ecu on the sr-4 neon and caliber inhibit the CEL from triggering on. Also on VW the ecu flash do the same. o2 cel that is
Old Mar 29, 2009 | 08:20 AM
coopman7's Avatar
coopman7
That is very plausible and sounds like it could be the factor in not triggering cels however my mate has the same remap and he was running your full 3" turbo back exhaust (no resonators or silencers) and he got a cel every so often, im not sure if it was o2 related or not though - futureal33 might beable to shine some light on this.
Damn ecu
Old Mar 29, 2009 | 09:47 AM
MiniPOLACK's Avatar
MiniPOLACK
coopman, i just realized, are you in USA?
Old Mar 29, 2009 | 09:49 AM
AkFarina's Avatar
AkFarina
if i remember, no he is not. he is the one doing the turbo swap in eu.
Old Mar 29, 2009 | 11:48 AM
Exhaust Depot
Damn ecu
he had a fouler in his setup. Im pretty sure it was o2 related. Whats odd is that what works for one car does not always work for another. On my caliber market, my car has gone a year with no cel. My buddy 2 days, others 2 months. Same identical setup.
Old Mar 29, 2009 | 03:13 PM
got.pho?'s Avatar
got.pho?
sucks that other cars are so much easier to do stuff with =/ like the ams test pipe for my buddy's evo plugged right up =[ stupid mini....
Old Mar 29, 2009 | 05:03 PM
Exhaust Depot
Yup! I had a ralliart this past week come in and the fouler works with no issues.
http://srt4tech.com/exhaust/evox/rallyart/
Pker
Apr 11, 2017 12:14 AM
barthayes
Oct 1, 2015 05:22 PM
nashvillemini
Sep 30, 2015 10:26 PM
audio131
Sep 28, 2015 02:21 PM
donniedarko
Sep 25, 2015 09:02 AM
