Drivetrain Bad O2 sensor at 12,000 miles?
Old Mar 11, 2009 | 09:25 PM
  #26
vwroom's Avatar
vwroom
Originally Posted by 1FSTMINI
not the one you posted but ive had 02 sensor faults before. never seen a p2270 before.
Was it a bad O2 in your case or leaks as you suggested?
Old Mar 12, 2009 | 06:20 AM
  #27
Mike87's Avatar
Mike87
I had a similar issue with my aftermarket header/cat. I kept getting lean bank errors. I was told it was due to the 'racing cat' not being as efficient as the stock. I changed back to the stock header and have had no problems since.
I am still using the same o2 sensors (that were stock and on the aftermarket header) at 40K miles.
Good Luck,
Mike
Old Mar 12, 2009 | 08:13 AM
  #28
vwroom's Avatar
vwroom
Good Luck,
Mike
So you ran the factory header with the aftermarket cat?
Bryan
Old Mar 12, 2009 | 08:23 AM
  #29
1FSTMINI's Avatar
1FSTMINI
he was using a header with aftermarket cat.
mine was b/c the welds on the cat flanges were leaking so i had to re-weld it and it fixed the problem. the gasket was also leaking on the back side of the converter.
Old Mar 12, 2009 | 08:47 AM
  #30
Mike87's Avatar
Mike87
Correct, it was a header with an aftermarket cat already attached.
Old Mar 12, 2009 | 10:32 AM
  #31
vwroom's Avatar
vwroom
Well that sort of tells me that I should expect this with my setup and I shouldn't worry about the O2 sensor being bad. I looked and listened for leaks around the intake manifold, intake pipe and looked to see if I had any loose vacuum lines. Although I do know that the engine will idle pretty rough if a vacuum line is loose and it is idling smoothly. I will report if I learn anything else or anything else changes.
Thanks for the help guys!
Bryan
Old Mar 27, 2009 | 10:52 PM
  #32
vwroom's Avatar
vwroom
I got a new code tonight after a few weeks of no problems this time the code is P2096.
Thoughts?
Bryan
Toolman
Jan 20, 2016 06:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
squawSkiBum
Oct 2, 2015 09:21 AM
David.R53
Sep 1, 2015 06:49 PM
