Drivetrain Bad O2 sensor at 12,000 miles?
Hello Everyone,
My 2002 MCS with JCW kit gave me a check engine light last night under a light throttle application driving around town. I have only owned the car for two weeks. I plugged in my code reader and it looks like its a O2 sensor low voltage code. I haven't had an O2 sensor ever go bad on a car partly because I never own them long enough to go bad! Ha! However, this Mini has a super sprint header and cat and a BB exhaust. The catch is that the car only has 12,350 miles on it.
Anyhow, I cleared the code and wanted to see if it would come back.
Was this a problem on '02 Minis? Has anyone seen this before on such a low mileage car?
Thanks!
Bryan
Thanks!
Bryan
The ambient temperature was 40 degrees when I got the CEL. The light has not come back on but I also haven't driven the car in that temperature since. I am wondering if the high flow cat isn't as efficient at such a low temperature.
Is anyone else running the super sprint high flow cat?
Bryan
Bryan
Most times a Oxygen sensor fault can be a calibration issue within the DME. Usually these types of complaints are solved with an update to the vehicles programming ( done at the dealer ) using a machine called an SSS ( software service station ) and the latest verion of Progman ( dealer software thats loaded into your vehicle to change how it bahaves ).
I hope that clearifys
NO 1FSTMINI a GT1 is the diagnostic machine. it used software called DIS CD verion... ( which will be gone by the middle of this year ) replaced by ISIS. the programming station is the SSS. This used software called PROGMAN. youve never heard of a software problem because your not paying attention. im not saying that this IS his issue but its a definate possibility.
Why would you try to discredit me when im trying to help someone? doesnt make any sense especially when you have no idea what your talking about?
matter of fact, let me make this even easier for you
This is the SSS
This is the GT1
and this is the ISIS there chief
IF IM BEING TOO HARSH HERE, I APOLOGIZE. I TOOK YOUR LAST POST AS AN ATTACK ON MY CREDIBILITY.
This is the SSS
This is the GT1
SIBS?
im sorry if you took my comment as an attack but its not like i know you or you have a sig saying " mini/bmw tech ". A lot of people on here like to read and answer people with the info they found on the net.
I just hate it when i think people are trying to blast me out of the water. I try to help where i can and get help when i need it, thats all.
I have no beef with you my good sir and i extend my apologies.
So the temperature was lingering around 40 degrees today and I got the CEL again. This time it was a different code but from the same O2 sensor.
P2270
I am really starting believe it is a relationship between the temperature and the aftermarket catalytic converter.
Bryan
P2270
Bryan
Are you running an aftermarket cat?
Bryan
