Drivetrain Anyone try this intake?
Old Feb 17, 2009 | 09:22 AM
  #51
killasha's Avatar
killasha
so over all you guys would take the ddm ris over the super ags... even tho the ris doesnt do much more than the super ags....
Old Feb 17, 2009 | 09:36 AM
  #52
fronjoni's Avatar
fronjoni
not me, i would not take any of those systems that channel air to your intake....
i said it once, just do an open air intake, and open your scoop, theres plenty of cold air coming in...my intake temps are always 10-20 degrees above ambient with this setup, and thats pretty good imo
Old Feb 17, 2009 | 10:01 AM
  #53
SomethingNew71's Avatar
SomethingNew71
So...... Just so everyone knows
I got the DDM Street Intake(easiest, cheapest, plus local to me)
I am going to get the DDM RIS scoop system
I have dremmeled out the holes in the plasstic grill of the scoop. (Because I just like the look of the grille too much)
I will also be testing the nm engineering strut brace with all the items to see if it fits(I will be working with namotors on that one)
My main motive was being able to hear the turbo spool.
Old Feb 17, 2009 | 10:16 AM
  #54
fronjoni's Avatar
fronjoni
i would add a scangauge to your order, just to see what kind of help its doing if there is any help
Old Feb 17, 2009 | 10:34 AM
  #55
SomethingNew71
I'm getting my car Dynoed at 4 this afternoon at Stock and I will be doing it again after I get the intake, then after I got the scoop system. If you'd like I'll send you the results. I will also be posting them on this forum.
Old Feb 17, 2009 | 11:04 AM
  #56
fronjoni's Avatar
fronjoni
yeah post thats good...
but still if u can shell out for a scangauge that way you can monitor ur intake temps.....
im curious to see what they are
Old Feb 17, 2009 | 04:29 PM
  #57
Tsar's Avatar
Tsar
I wanna see the numbers, go go go.
Old Feb 18, 2009 | 03:59 PM
  #58
accordselux's Avatar
accordselux
it just makes me laugh when i see it.....bigger is not always better....., and when it comes to intakes, none of htem make any real power....and im sure there are a 1000 ppl that will chime in and say oh its good oh its this, but thats just good marketing...its unecessary, its too big....
Intakes DO make power, and especially on turbocharged cars, where the amount of air it can suck in is increased due to the forced induction.
Yea, an intake on a Honda NA 1.5 will be negligible, but say, on a new EVO or Mazdaspeed3, you'll see people getting between 10-20hp at the WHEELS with just an intake.
I wouldn't be surprised with ANY intake on a MINI making at least 3 more whp, conservatively. Probably more like 5-10 depending on the setup.
Old Feb 19, 2009 | 08:03 AM
  #59
fronjoni's Avatar
fronjoni
maybe 3-5 up top, a slightly noticeable difference...but im pretty sure if you put some ear plugs in, drive it, compare the open intake with the stock box and a drop in filter....you wont be able to tell which car has the intake and which doesnt.....that noise factor of pulling in air and hearing your wastegate squeal plays a huge role in the 'damn this thing is fast' scenario....
this is why i say get the cheapest intake, they all are the same, those large awkward intakes arent any better, neither is the scoop set up....the only reason people question all these intakes is because there are like 5 different kinds with different options and huge prices, being expensive doesnt always make it good.
Old Feb 19, 2009 | 09:38 AM
  #60
SomethingNew71
Got the numbers. I will be posting them tonight. Mind you these numbers are the car before any mods.
Old Feb 19, 2009 | 10:40 AM
  #61
Tsar's Avatar
Tsar
just tell us
Old Feb 20, 2009 | 04:59 PM
  #62
SomethingNew71
These are Dyno sheets of my car at stock. I just installed my DDMworks Street intake yesterday and will be getting it dynoed soon. At least when I get some money. My car is an automatic so they told me the dyno will show about 25% less on paper than the car actually has. But here you guys go!
File Type: pdf
File Type: pdf
Old Feb 20, 2009 | 07:20 PM
  #63
old81's Avatar
old81
M6
A couple of things. On the dyno results, do these folks measure SAE and WHP? Seems low for the three runs. SAE dyno?
A data point for you, our recent runs measuring 4 R56s, one a 09 JCW.
Data with details over in the MINI5280 area.
Stock R56 MCS, 191 WHP
My MCSa (DDM WORKS Street Intake, stock exhaust, stock ecu) 205 WHP
Other MCS (ALTA CAI), stock exhaust, stock ecu) 205 WHP
09 JCW (DOS CAI), JCW WORKS Exhaust, 09 JCW ecu) 215 WHP
My MCSa made the same WHP on two different DYNO days, since I want to check for consistancy. DYNOJET Dyno.
All pulls done in 4th gear for the 6 speeds and 3rd gear for my MCSa. No overboost numbers, straight HP. 3 or 4 runs per MCS.
Only one point to be made, the CAI on the R56 will make horsepower.
Don
Old Feb 21, 2009 | 12:34 PM
  #64
Lil Blue Coop/Mini Rose's Avatar
Just had the DDMWorks RIS install by DDMWorks. Had a 90 min. drive home and had some time to play. There was a noticeable SOP difference in engine response throughout the range but from 50 mph up under acceleration you can really feel it. A little bit of intake and BOV noise. Great fit and finish and great guy's to work with. Look forward to more products from them.
Old Feb 21, 2009 | 11:38 PM
  #65
SomethingNew71
I dremmeled out my hood scoop so I could keep the "grill" look.
Here's the pix of the install and that little dremmel action.
Old Feb 22, 2009 | 06:25 AM
  #66
Tsar's Avatar
Tsar
Um.. I wonder if I could stick a bigger air filter on there
Old Feb 22, 2009 | 07:08 AM
  #67
Bigger filter would be a good idea. I would get the longest that would fit.
Old Mar 13, 2009 | 06:50 PM
  #68
FON's Avatar
FON
Originally Posted by Tsar
That looks nice! but not $1400 nice... DDM works has essentially the same thing for 1/3 of the price.
Why is it so $$$?
Apparently, in their website, it is stated it will not fit a factory jcw...
Anyone has a clue why not?
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
