Drivetrain Craven speed pulley
Old Jan 18, 2009 | 01:21 PM
Minibiker11's Avatar
Minibiker11
Craven speed pulley
Can anyone tell me if the Craven 15% reduction pulley works well, and if it has a lip on it that helps prevent the belt from walking off? if there is a better pulley that can be suggested, please do tell.
Old Jan 18, 2009 | 01:43 PM
minimarks's Avatar
minimarks
Great pulley, been running one for a couple years with zero problems!
Old Jan 18, 2009 | 01:46 PM
Minibiker11
Craven and Spark Plugs
Did you need to go to a spark plug that was one grade cooler?
Old Jan 18, 2009 | 01:53 PM
Luys's Avatar
Luys
You need to cooler spark plug.
Old Jan 18, 2009 | 01:56 PM
minimarks's Avatar
minimarks
I did, one heat range cooler.
Old Jan 18, 2009 | 03:28 PM
daflake's Avatar
daflake
For a 15% you can run regular plugs. I know many folks that are using stock with no problems.
Old Jan 18, 2009 | 04:24 PM
Eric_Rowland's Avatar
Eric_Rowland
If the pulley is aligned properly, you shouldn't have to worry about the belt walking off. Both stock and -1 ranges work fine - the best choice for you depends on your driving habits.
Old Jan 18, 2009 | 06:15 PM
astrochex's Avatar
astrochex
Might also depend on what gas you use. I've got stock plugs and generally use Arco gas, I get pinging under heavy loads. I am currently running Chevron to see what happens with the pinging. My long term solution will be colder plugs (Brisk).
Old Jan 19, 2009 | 06:12 AM
Suzanne's Chili Red S's Avatar
Had ours for a year now with no problems and it does fine with the stock plugs. Nice improvement!
Old Jan 19, 2009 | 01:20 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
Minibiker-
Our stainless steel pulleys do not have a lip, but if you request a black pulley, it will have the lip.
Old Jan 29, 2009 | 06:14 PM
tc4653's Avatar
tc4653
Just installed mine, with the cooler plugs - absolutely LOVE IT!
Old Jan 29, 2009 | 07:39 PM
Minibiker11
Mine just came in. Yahoooo. Went to get the belt today that's a tad shorter, plus the Iridium plugs one step cooler. Will do this Saturday early AM.
Minibiker11
Hey, is the pulley a tough job to do ?
Old Jan 30, 2009 | 12:17 AM
Eric_Rowland
An hour for the pros, 1/2+ day for shadetree.
See Randy Webb's How-to https://www.northamericanmotoring.co...8-how-tos.html
Old Jan 30, 2009 | 01:39 PM
daflake's Avatar
daflake
I got it down to about 1.5 providing that I have the tools ready. For someone that hasn't done it, give yourself 3 + hours.
Old Feb 1, 2009 | 06:04 PM
Minibiker11
Actually waiting until next weekend now. All my tools will be ready. Are there any Stars head tools required? Or all just metric hex bolts? Oh yea thanks to all NAMmers for the help !!
Old Feb 1, 2009 | 10:35 PM
silversmoke06's Avatar
silversmoke06
Uhh you really need to go to a colder grade least i did with the 15%
I mean you can run it but I found the car alot smoother and more driveable with the Brisk cold plugs.
Just my personal deal you know?
the cravin is a good pulley i know danny from mini corsa reccomends it.
I personaly have the Alta V1 and dont have much of an issue with it.
Old Feb 2, 2009 | 05:10 PM
daflake's Avatar
daflake
Metric hex, cross tip screws and special tools (jack stands/puller and such).
Spank
11
Apr 9, 2020 02:23 PM
blackie
Jan 18, 2017 09:56 PM
gmonde
Sep 8, 2015 06:37 AM
David.R53
Sep 1, 2015 06:49 PM
