Drivetrain Tuning options with R53?
Old Dec 4, 2008 | 02:30 PM
  #26
Mini_Joe's Avatar
Mini_Joe
Originally Posted by //MZero
Mini's typically dyno stock in the 150-155 range for an 05'-06' a pulley adds 15-20 hp as you are raising the boost from ~10.5 to 15-16psi. Put a JCW intake on there and go get a tune from Jan and you will see your numbers and a much larger area under the curve. And you'll be out less then $1k. If you end up wanting more throw the header, cam, injectors on there and get retuned and find about another 25-30whp.
Another plus one here for the pulley...
I took my 3k mile 2008 automatic CooperS in for a 17% pulley, cam, and header. Everything else is stock except for a K&N filter in the stock airbox.
It put down 208hp at the hubs after a tune... and it was about 188hp prior to the tune.
I went 17% instead of 15% since I had the automatic and wanted to make up some of the difference between the gearboxes... looks like I'll need injectors too, but a pulley on it's own most likely won't need em.
Old Dec 4, 2008 | 04:10 PM
  #27
soccerbummer1104's Avatar
soccerbummer1104
im confused, are the automatics still supercharged? i thought after 06 they all went to turbo's...
Old Dec 4, 2008 | 04:40 PM
  #28
Mini_Joe's Avatar
Mini_Joe
Hey Soccer Bum...
The convertibles stayed supercharged up until 2008 and didn't change body styles.
The '09s will be the turbo'd engine and new body style.
Old Dec 4, 2008 | 04:49 PM
  #29
andreivan's Avatar
andreivan
is any tune for a R 53 with a automathic trasmision.
Old Dec 4, 2008 | 05:28 PM
  #30
Mini_Joe's Avatar
Mini_Joe
Yes Andre Ivan... the R53 is the supercharged Mini Cooper S... automatic or manual... they can both be tuned.
I have one myself.
Old Dec 4, 2008 | 05:32 PM
  #31
andreivan's Avatar
andreivan
any tune in special.thank you for the info Iam new in minis
Old Dec 4, 2008 | 09:55 PM
  #32
drsilvermini's Avatar
drsilvermini
RMW Jan tune is the best imho...search the forum for either Jan or RMW or Revolution Mini Works
Old Dec 5, 2008 | 06:55 AM
  #33
frenchyjohnmini's Avatar
frenchyjohnmini
Hey Jan, how about my Shark? Did you manage to play with it. Got my car back. All I need is you!! LOL. Let me know when you head east.
Old Dec 5, 2008 | 08:35 AM
  #34
dL_EVO's Avatar
dL_EVO
Originally Posted by soccerbummer1104
agreed the pully is the best bang-for-your-buck mod out there for beginners
also, be careful when saying things like "much faster evo". you have to remember, not all mini's are created equally i may be overestimating jan's mini, but something tells me it could give the evo a run for its money on the track when he is finished with it
http://www.youtube.com/watch?v=xFVUvZG207A
Sorry, I didn't mean to sound arrogant with the "much faster evo" comment. I'm just saying going crazy with the modifications on the Mini is not important to me because my other car is already pretty quick and is only getting faster.
My EVO IX is pretty lightly modded, so I'm pretty sure Jan @ RMW would own me. But it's not about being the fastest, just about having fun.
Old Dec 5, 2008 | 12:43 PM
  #35
Some Guy's Avatar
Some Guy
I like your attitude!
A pulley will probably get you really close to what it sounds like you are looking for. The nice thing is that you can do just a pull and basically leave it like that indefinitely (although that holds true with a lot of other "bolt on" mods for the mini).
And if you havent thought about already look at getting some camber plates, the MINI has like no camber up front in stock form. Alternatively a larger rear sway bar is consider THE suspension mod to get by most people.
Old Dec 5, 2008 | 12:56 PM
  #36
miniman101's Avatar
miniman101
No matter what, there are a lot more tuning options for an R53 than an R50!!
Old Dec 5, 2008 | 02:13 PM
  #37
dL_EVO's Avatar
dL_EVO
How difficult is it doing a pulley swap on a Mini Cooper S?
I did one on my old Saturn Ion Redline with a Roots M45 SC. It was a pain in the *** because the snout on my S/C was deformed from the factory. It was rubbing on the pulley, so I had to file the snout down before I could install it.
Old Dec 5, 2008 | 02:33 PM
  #38
craigfsl's Avatar
craigfsl
I just had some one do the pulley swap for me (15%) with that cai and header back exhaust I keep up with my friends evo 9 thats modded with turbo back intake 21psi boost and a ecu tune so it will be quick enough.
Old Dec 5, 2008 | 04:05 PM
  #39
//MZero's Avatar
//MZero
Well, you wont have to break out the file to do the install. But it is not something you want to tackle alone...a buddy is almost a necessity the first time you do it. It took me 8 hrs with a friend, most people say 4 hrs. and I AM mechanically inclined. I've installed all my mods in my sig, I used to have an 99 Eclipse before my S2000 before my Mini. I did the whole big 16G, fmic, dsmlink, 660s, etc all myself. The problem with the pulley install was getting the stock one off, it just WOULD NOT come off for me...a torch would have helped a lot!
If you could do it with another Mini owner who has done it before it will be easy...but most shops charge 150-200 for install, if you have a good day job, its worth it to pay someone with experience.
Old Dec 6, 2008 | 10:31 PM
  #40
Some Guy's Avatar
Some Guy
The best way to tell will be to read a how to. Here is a good one,
https://www.northamericanmotoring.co...ey-how-to.html
Ignore the bit where he talks about heating up the Helix pulley with a torch, all of the pulleys you get not including the Helix use some sort of clamp on design.
Old Dec 7, 2008 | 02:46 AM
  #41
dL_EVO's Avatar
dL_EVO
Thanks for the how to..
Wow that looks really involved..
My old Ion Redline was simple..
Take off drive belt and pull the SC pulley off and put the new one on.
The MCS sure does involve a lot of steps.. LOL
Old Dec 7, 2008 | 12:37 PM
  #42
soccerbummer1104
haha, you didn't, i was just poking a lil fun .
+1 on the just having fun too btw
Old Dec 8, 2008 | 04:34 AM
  #43
oxtox's Avatar
oxtox
i was willing to pay for my leisure time. it took eric at helix an hour by himself while i played gt4 on their playstation....woulda taken me a lot more....so i was pleased. and there are plenty other diy's to do. my fav was coilovers, the easiest was the jcw intake. happy trails!
Old Dec 8, 2008 | 07:00 AM
  #44
broadwayline's Avatar
broadwayline
What exactly does Jan at RMW use to tune? I understand he burns a custom program, but I am curious the device he uses to do so.
Old Dec 8, 2008 | 07:12 AM
  #45
newbs49's Avatar
newbs49
Call Jan - He'll tell you.
Dimmsport - I believe. Not sure of the eguipment though.
Old Feb 8, 2009 | 04:53 AM
  #46
mcs_jcw's Avatar
mcs_jcw
A friend was measuring the R53's engine bay and he said that an EVO engine could fit in.
Old Feb 9, 2009 | 11:40 AM
  #47
AZblackOUT's Avatar
AZblackOUT
Why tune now when down the road you'll have to tune again? Stand-a-lone ECU.
https://www.northamericanmotoring.co...-play-ecu.html
Old Feb 9, 2009 | 12:00 PM
  #48
Revolution Mini Works's Avatar
I have our new stand alone here and the wiring harness almost complete
We will have it on a car by the end of week
Old Feb 10, 2009 | 05:21 PM
  #49
AZblackOUT's Avatar
AZblackOUT
Nice...do you have any specs on it your willing to let out?
Old Feb 10, 2009 | 06:40 PM
  #50
NOPE
