Drivetrain Please can someone upload a video of their boost gauge readings
Old Nov 24, 2008 | 10:12 AM
futureal33's Avatar
futureal33
Hi all,
I have taken a video of my boost readings on my Cooper S after the following modifications:
ECU Remap
DDM CAI
3" De-cat Turbo Back
Im a bit disappointed because Im sure some of you guys over in the US are getting 21psi on overboost with the Alta PnP ECU, whereas I am only getting about 16... Can someone please post a video of their boost gauge
This was done in 3rd gear on a level stretch of road with full foot to the floor acceleration with Sport Mode ON and DSC OFF. Temperature was around 1.5degrees celcius
Please post up your vids
http://uk.youtube.com/watch?v=GeM-qwkQtq4
Old Nov 24, 2008 | 11:55 AM
JAceMin's Avatar
JAceMin
Are you throwing a CEL there as well?
Old Nov 24, 2008 | 12:16 PM
futureal33's Avatar
futureal33
Certainly am
Old Nov 24, 2008 | 07:35 PM
donuttang's Avatar
donuttang
i have max 15....no ECU remap yet....but with the following addon parts - listed in signature...
Old Nov 24, 2008 | 08:46 PM
lxjose9xl's Avatar
lxjose9xl
I posted a quick vid on my youtube page when briefly tested the Alta PnP...we had sporadic readings upwards of 20...but ended up sending back the unit due to cels, car sputtering, turning off, you name it.
Now thinking about it, 21 lbs is a lot of boost to be running on the stock S, that small turbo and stock wastegate. Goodness we only had it on for less than 1 hour.
Old Nov 24, 2008 | 09:06 PM
SlowB00st's Avatar
SlowB00st
I think the 20-21 psi is with the upgraded intercooler tune.
Old Dec 5, 2008 | 07:24 AM
fernflex's Avatar
fernflex
I installed my boost gauge last night I am still checking that everything is conected the right way and that I don't have any leeks and I am still programming the gauges but so far I have seen 19 psi - 19.5 psi or 1.31 if I am not wrong
Old Dec 5, 2008 | 10:47 AM
minipete07's Avatar
minipete07
Running 16.5psi peak on 93 octane.....and at the track, 17.5psi peak on 98 race unleaded octane....
Old Dec 5, 2008 | 11:49 AM
scott48's Avatar
scott48
I hit 21
Old Dec 5, 2008 | 01:03 PM
fernflex's Avatar
fernflex
I think I am loosing boost throught my hot side boost tube, I think it got a small hole!!!
Old Dec 5, 2008 | 01:58 PM
scott48's Avatar
scott48
^^fix it!
Old Dec 5, 2008 | 02:28 PM
fernflex's Avatar
fernflex
Confirm, During the day 19 psi @ night ???? Tell you tomorow.
Now I remember that I bough my pnp used and its only tuned for intake and exhaust!!!
Ecu+ Fedex + New Tuning= 215 or 220whp???
Old Dec 5, 2008 | 04:26 PM
scott48's Avatar
scott48
^^but does it jump straight to 19 or hit like 15 then climb to 19 if you stay in it?
Old Dec 5, 2008 | 04:55 PM
fernflex's Avatar
fernflex
I have to record it but I think its spike to 19 but stays between 15 and 19
Old Dec 7, 2008 | 04:19 PM
fernflex's Avatar
fernflex
Hi
My car is crazy, when my car is cold it doesn't boost more than 15 psi but once it get to it normal temperature the beast comes out. Today for the first time I saw a 21 psi spike racing with a new mustang V8 and 06 Sti.
Old Dec 7, 2008 | 05:30 PM
scott48's Avatar
scott48
All of em don't build full boost when the engines cold, safety feature.
Old Dec 8, 2008 | 08:01 AM
futureal33's Avatar
futureal33
This is well annoying, is 21psi safe??
Mine wont go above 16.5psi!! and thats with overboost! Once that has gone it goes back to between 14 and 15!!
Old Dec 8, 2008 | 07:27 PM
SlowB00st's Avatar
SlowB00st
I think the alta defeates the over boost feature and runs the max psi allowed by the map and the turbo.
Did you get it tuned for the current mods? Was the map tuned at a dyno for your car? If so time for a re-map... since i think you added the intercooler later.
Old Dec 8, 2008 | 10:09 PM
lxjose9xl's Avatar
lxjose9xl
Well 20-21 psi is what I was getting on my wife's car with just a turbo-back exhaust and intake...
Originally Posted by fernflex
Hi
15 psi on a cold engine, Ouch!! Doesn't sound too good for the longevity of the engine.
Old Dec 8, 2008 | 11:12 PM
ThumperMCS's Avatar
ThumperMCS
I agree.
Old Dec 9, 2008 | 05:26 AM
fernflex's Avatar
fernflex
The car boost 10 psi and get a 15 Psi spike, I dont think that is going to hurt the engine or the turbo.
Also when I tell you "cold engine" im talking about starting my engine in the morning with a outside temperature of 80+ degrees. Not compare to you in the states with cold weather and the snow.
Old Dec 9, 2008 | 01:17 PM
lxjose9xl's Avatar
lxjose9xl
While I am in the states. I don't experience any cold weather or snow (Miami). By cold engine I don't mean freezing temperatures outside, I mean the engine is not up to operating and optimal temperature. Running 10lbs with a 15 lb spike is not the healthiest for an engine that has not been warmed up yet. But anyways the original question for the thread was overall boost level readings with upgraded ECU's.
Old Dec 10, 2008 | 05:41 PM
richi0207's Avatar
richi0207
My boost gauge seems to be reading instant to 15 and as the revs go up it slowly goes to 19, but for some reason it sometimes doesn't pass 17 on time days, wonder where that 2 psi is? Seems like people getting 21 psi are those with downpipes.
Old Dec 10, 2008 | 06:18 PM
scott48's Avatar
scott48
one cold evening.....
Old Dec 11, 2008 | 08:39 PM
richi0207's Avatar
richi0207
Im jealous =( jk at least its another LB owner
