Drivetrain Exhaust vibration w/RMW Street Header?
Old Nov 3, 2008 | 01:22 PM
  #76
Mini_Joe's Avatar
Mini_Joe
Any correlation between types of intakes you folks are running, who have the vibration?
Old Nov 3, 2008 | 01:36 PM
  #77
BlimeyCabrio's Avatar
BlimeyCabrio
I don't think so. Seems to be many types. I'm running a JCW. But I can't see how that's gonna make a difference...
Old Nov 5, 2008 | 07:55 AM
  #78
davisflyer's Avatar
davisflyer
I removed the upper heat shield today and it didn't seem to stop the mild buzzing above 6k. Next, I will try the area around the resonator....
Old Nov 5, 2008 | 07:57 AM
  #79
davisflyer's Avatar
davisflyer
BTW, it's amazing how quickly you adapt to something. The first couple of days, it felt uber quick, now I'm used to it. Also, the header, which seemed so loud to me the first few days, doesn't seem as loud anymore.
Old Nov 5, 2008 | 09:13 AM
  #80
BlimeyCabrio
Yep... same here...
Old Nov 5, 2008 | 10:07 AM
  #81
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Actually this phenomenon is well researched. It is very common and explains a lot of "placebo" effects as well as "butt dyno" assessments. I guess it's why people like measurements and the experimental method--and why people get PhDs.
Old Nov 5, 2008 | 11:55 AM
  #82
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
As to my earlier post, would one or two of these benefit the vibration? It's the piece attached to the side of the right pipe. This is a BMW 328 muffler-
Old Nov 5, 2008 | 12:53 PM
  #83
the platform's Avatar
the platform
This is why an Aston Martin DB9r would cure everything!I promise not to get used to it. ...sorry,off topic.
Old Nov 5, 2008 | 02:34 PM
  #84
BlimeyCabrio
Sorry - pic isn't there anymore...
Old Nov 5, 2008 | 05:39 PM
  #85
ClintTheMiniOwner
Weird it shows up on my computer.
Here is another approach-
Old Nov 5, 2008 | 06:04 PM
  #86
BlimeyCabrio
Hmmm... harmonic damper... might do the trick... wonder where I can get something like that.... I could weld it on and try it...
Old Nov 5, 2008 | 06:28 PM
  #87
MINIMAX 1's Avatar
MINIMAX 1
Originally Posted by duvinclunk
Hoping to have my shorty header on with a Magnaflow this week. I'll let ya know...
>> Good info Duvinclunk
>> Thanks,
>> MINIMAX
>> 2003 S
>> Unstock
Old Nov 5, 2008 | 06:33 PM
  #88
duvinclunk's Avatar
duvinclunk
>> Thanks,
>> MINIMAX
>> 2003 S
>> Unstock
Hey now. It'll be on this Saturday. Buzz away!
Old Nov 5, 2008 | 06:36 PM
  #89
MINIMAX 1's Avatar
MINIMAX 1
>> I'm happy for you. I'm thinking of replacing my Cam with one form Jan, just can't get him to reply to my phone message. I'll e-mail him maybe that will work.
>> MINIMAX
>> 2003 S
>> Unstock
Old Nov 5, 2008 | 06:54 PM
  #90
MINIMAX 1's Avatar
MINIMAX 1
>> I'don't BUZZ!!!
>> MINIMAX
>> 2003 S
>> Unstock
Old Nov 5, 2008 | 10:58 PM
  #91
custard's Avatar
custard
Big improvement!
Although it was a pretty big (and spendy) change, I replaced my Milltek with a JCW exhaust today. Huge difference Not only is it, much, much quieter, but the resonance is gone. I still get a tiny “roughness” @ around 2.2k through 3k, it’s nothing like the vibration and rumble in the seat that I had previously. It still sounds “authoritative” when I get on it, but much more civilized. Now I can actually enjoy the header!
Old Nov 6, 2008 | 05:15 AM
  #92
davisflyer's Avatar
davisflyer
I found a loose screw/washer on holding together two heat shields right next to the collector and thought for certain that was the culprit of my buzz.....nope. Check all the heat shields around the resonator and center brace and everything was tight and rattle free.......the search continues.
Old Nov 7, 2008 | 09:26 AM
  #93
BlimeyCabrio
I just stopped by my local GREAT custom exhaust shop and talked with the guru there. He agreed that adding a small resonator to the mainpipe will probably do the trick. He's ordering a small magnaflow and I'll hopefully get it installed next week. We'll see what happens. If this doesn't solve everything, I may get him to build me a full custom one-sided cat-back.
Old Nov 8, 2008 | 07:30 PM
  #94
duvinclunk's Avatar
duvinclunk
Shorty header installed today with a Magnaflow exhaust. I am getting the same vibration. I don't have anything to compare it to except Intense's vibration and mine isn't harsh at all but you can feel it.
Old Nov 9, 2008 | 06:09 PM
  #95
BigShow's Avatar
BigShow
So what's Jan said about this?
Old Nov 9, 2008 | 06:25 PM
  #96
BlimeyCabrio
Basically that it's tough for him to diagnose if he can't find a car locally that has the issue - which he can't so far...
To be fair... I'm not sure everyone here is having the *same* issue... there's likely a whole spectrum of rattles and vibrations that get unleashed when you put a free-flowing equal-length header on... I think it's just finding the resonant frequency of some of these exhausts, which wasn't really getting pushed with the OEM header... We'll see if my added resonator makes a difference...
Old Nov 9, 2008 | 06:28 PM
  #97
BigShow's Avatar
BigShow
Fair play... presume he's tried it on his car then as that was gonna be my next question.
Has anyone tried running it de-cat to see if the problem goes away or is it a one piece manifold and cat?
Old Nov 9, 2008 | 06:57 PM
  #98
Revolution Mini Works's Avatar
they are on cars all over Orange county.... I'm trying to find one that does it....so far.......nada
bizarre
Old Nov 9, 2008 | 07:34 PM
  #99
BlimeyCabrio
No worries... if adding a magnaflow resonator to the mainpipe doesn't kill it... I'll have an excuse to get the dude build me a sick one-sided custom exhaust...
Old Nov 9, 2008 | 08:48 PM
  #100
duvinclunk's Avatar
duvinclunk
I am getting the same vibration as you describe, and the same vibration that Intense is getting. I wonder if the Magnaflow resonator is going to make the difference. Intense installed a 21 inch Magnaflow resonator to his Invidia exhaust and it didn't cure it. I have a 19 or 20 inch Magnaflow resonator on mine and it sure doesn't cure it. It'll be interesting to see...
