Drivetrain HKS Super SQV Blow-off Valve
Old Oct 17, 2008 | 06:40 PM
diablito's Avatar
diablito
I was lurking around and saw this Bov for the R56 models
and JSCspeed hook me up with one right away, in black, which is the only color I would gone with. I looked further and found a video of the valve at work... and one more here with tubes from exhaust depot which is just down the street from me so I will see if I can have it done soon..
Mean while the BoV will be a subject for pictures...It looks really nice.
Old Oct 17, 2008 | 06:42 PM
diablito's Avatar
diablito
HKS Kit
Very pricey at Lohen
And a couple of my shoots, looks like a spaceship or something...
Old Oct 17, 2008 | 07:05 PM
MiniStupidfun's Avatar
MiniStupidfun
nice! I would guess it sounds awesome.
Old Oct 17, 2008 | 09:30 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
There extremely loud. Like rediculous. Who's gonna be first?
Old Oct 17, 2008 | 09:36 PM
diablito's Avatar
diablito
Look up, I have included links to video and sound
To each its own. There is already people with it so first would be a bit difficult at this point. The video on the link above sounds nice to my ears...maybe to loud for others.
Old Oct 17, 2008 | 09:38 PM
littlehandegan
It's not much a matter of to each its own. The SQV is one of the loudest blow off valves......
Old Oct 17, 2008 | 09:46 PM
diablito's Avatar
diablito
I can only go with the video and sound clip...on a MINI, for now.
Being loud or loudest its irrelevant, if I do not like it i will take it off. But thank you for pointing out the noise level. Loudest! Umm might be an added safety feature, others will hear me coming. Psst! Psst!
The FORGE on Zero7 sounds good...At first I was worry about the noise, but now is symphonic..
Old Oct 18, 2008 | 11:17 AM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
Take a good look at the BOV, if you notice every other screw is recessed in . If you remove the higher screws the housing will come off. You can then remove that plastic delta looking piece. This will change sound the ssq is known for and give you a more conservative sound.
Also if you notice the purple little piece, that valve comes off the seat under low boost conditions. Under heavy loads the black portion that says SSQ comes off the seat. So you have to valves there.
Old Oct 23, 2008 | 01:25 PM
VeganBrian's Avatar
VeganBrian
is anyone getting one to see how it is? im going to get one after winter.
Old Oct 23, 2008 | 01:42 PM
myminirox's Avatar
myminirox
This looks so cool!
I doubt I'm going to get one, but whoa!!
Old Oct 28, 2008 | 08:44 AM
Mini for life!'s Avatar
Mini for life!
im getting one for sure but u hav to block off the stock blow off valve but when u do that the ECU will go crazy.
so i dont really know what to do -_-
You will either have to drill and tap your intake manifold with the proper fitting, or purchase the ATP Vacuum/Boost Source Adapter which will install underneath your stock MAP sensor and give you a pressure source for your BOV.
Old Oct 28, 2008 | 05:18 PM
Exhaust Depot
U dont have to block off your stock bov, just leave it as is. No cel, no stumble.
Old Oct 28, 2008 | 07:39 PM
Mini for life!
awesomeeeeeee thanks xD
where can i buy a SSQV kit for my r56?
Old Oct 29, 2008 | 12:09 PM
Exhaust Depot
on my site. i just left fort lauderdale this week to orlando so it will be a week or so before my new location is 100% up and going.
Old Oct 29, 2008 | 03:09 PM
Mini for life!
damn man and its impossible to find a r56 kit around here in miami
cuz my last resort is ordering it off the internet.
mean while im gunna look around to see if i find anything.
Old Nov 2, 2008 | 05:23 PM
Exhaust Depot
I moved a week ago, wish you would hvae hit me up prior to my move. IM still stuck trying to set up shop.
You can always come and see mickey and have us install one for you once we are settled in.
Old Nov 2, 2008 | 08:06 PM
Mini for life!
where are you guys located at?
ad now i might just get a FORGE bov adapter. its only 67$!!! and the HKS ssqv kit for the r56 is 520$ x[[
Old Nov 3, 2008 | 07:56 AM
Exhaust Depot
IM literally located about 3 blocks down the block from FORGE in orlando. lol
Old Nov 3, 2008 | 10:37 AM
Mini for life!
aw man im all they way back in miami x[
but any ways im hopefully going to order my forge bov today xD
oh and whats ur site? il check it out mean while
Old Nov 3, 2008 | 08:05 PM
SlowB00st's Avatar
SlowB00st
http://www.exhaustdepot.net/minicooper.html
Old Nov 4, 2008 | 03:52 PM
Performance Angst's Avatar
Performance Angst
Nice stuff
Would this work on an '09 JCW?
Old Nov 4, 2008 | 03:56 PM
Mini for life!
most likely. i havent seen the engine yet but if its turbo then most likely it'll be the same engine as the 07', 08' models.
Old Aug 21, 2009 | 06:22 AM
danielo's Avatar
danielo
Are you guys having any trouble after fitment? I'm wondering if the engine stalls on the overun due to the lack of are as the air is no longer being recirculated back into the air intake.
Old Aug 23, 2009 | 11:10 PM
danielo's Avatar
danielo
Hi,
I too just purchased the HKS SQV Limited Black Edition for my R56. The shop just took measurements for fabricating the S/S hose (will powder coat it black). Should be ready in a few days.
Since you purchased the HKS kit, would you mind sharing the installation instructions? Thanks. Also, where and how did you tap the vacuum hose to?
Cheers.
Old Aug 23, 2009 | 11:15 PM
danielo's Avatar
danielo
Does this mean i'll need one of these to tap for the vacuum hose?
