Drivetrain MINI Madness R56 Software Tuning and Performance Packages
Old Dec 5, 2008 | 09:26 AM
  #151
MINI-Madness's Avatar
MINI-Madness
Originally Posted by Bigshot
MINI Madness,
are these dyno tunes or just a new map?
They are maps based on dyno tunes we have done here locally using different mod configs
Old Dec 8, 2008 | 07:24 AM
  #152
Bigshot's Avatar
Bigshot
So they are a "best guess" canned tuned.
Old Dec 8, 2008 | 09:45 AM
  #153
MINI-Madness
I would call it a "highly educated guess".
So far on the dyno we have been able to gain 1-3 more HP versus just the reflash on an R56. Obviously there is dyno time cost to consider so were very pleased with the reflash at this point.
Old Feb 3, 2009 | 10:26 AM
  #154
ThumperMCS's Avatar
ThumperMCS
Originally Posted by MINI-Madness
In the next 3 weeks we will be testing 3 different cam grinds. Each one will have a different software version to go with it.
What ever happened with these cams??
Old Feb 3, 2009 | 12:22 PM
  #155
D-Unit's Avatar
D-Unit
+1
Old Feb 5, 2009 | 09:57 AM
  #156
YakiMini's Avatar
YakiMini
George is installing cams today.... I'll post info once it's available.
Old Feb 5, 2009 | 10:23 AM
  #157
ThumperMCS's Avatar
ThumperMCS
Fantastic...keep us posted!
Old Feb 5, 2009 | 11:12 AM
  #158
cartar452's Avatar
cartar452
...and the turbo kit?
Old Feb 5, 2009 | 11:21 AM
  #159
YakiMini's Avatar
YakiMini
He is at the Dyno right now testing and "Tuning" (the Turbo)
Old Feb 15, 2009 | 10:45 AM
  #160
richi0207's Avatar
richi0207
How did the test and tune go? I might consider evotech over my unichip. What are the boost levels that evotech tunes are running?
Old Feb 17, 2009 | 11:02 PM
  #161
YakiMini's Avatar
YakiMini
15psi is the boost level to expect on a tune. George is still working on a tune for a Turbo and Cams...
Old Feb 18, 2009 | 09:30 PM
  #162
richi0207's Avatar
richi0207
Very impressive considering it claims to make more power than a unichip with lower boost levels.
Old Mar 10, 2009 | 12:42 PM
  #163
M3This's Avatar
M3This
Any offerings for the R56 JCW ??????
Old Mar 10, 2009 | 01:20 PM
  #164
Bigjoeski08's Avatar
Bigjoeski08
How easy is it to take out the ECU.
Old Mar 20, 2009 | 12:31 PM
  #165
YakiMini's Avatar
YakiMini
We have not done any work on a JCW yet but you will see a gain in Boost.
Removing the ECU.... There are a couple of plastic clips holding it in. You'll need patience but it's not much harder than pulling an R53 ECU
Old Apr 3, 2009 | 10:19 AM
  #166
ThumperMCS's Avatar
ThumperMCS
Update on cams??????????????????
God, you really have to stay on all these tuners to keep giving updates about all their hype
Old Apr 3, 2009 | 12:22 PM
  #167
dtsoccer6's Avatar
dtsoccer6
Originally Posted by Dead Ringer
OK, time for me to chime in here........ I am the other one that Thumper is referring to who had Dynocomp custom tune my chip on the dyno.
You may remember about a few months ago I posted my dyno results for the unichip. Since then I have had issues with the unichip (kept on getting limp mode, you have probably seen my posts). Since then ALTA STEPPED UP TO THE PLATE and got me a refund (and won back a customer!!)
Anyways I had the new evotech tune installed (the same one that mini madness has) but mine was actually installed and dyno tuned by dynocomp. They were on the phone with the company in Germany doing the tuning while on the dyno and making it custom for my car. The install went on for about 45 minutes with them running the dyno, getting the results and taking to the tech, they would then tweak the ECU and rerun the dyno etc....The results are pretty impressive +25hp & just over 30tq. NO CEL's or ANY problems at all (going on a month now!) Plus it’s totally transparent to the dealer, so no issues if I have to take it in for service. Just thought you might like to know about it. It definitely needs to be installed by a company that can tune it on a dyno to get max performance!
BTW I have being shipped to me Alta's intake, boost tube & inlet tube. As soon as I get them I will be stopping by Dynocomp to install, and if possible do some before/after dyno runs..
Just so I get this straight, you can get this software and then have a local shop tune it? I have a very good relationship with my mechanic and he's been wanting to do it for awhile. So if I called Mini Madness and asked for it, I can get it flashed by someone else?
Old Apr 3, 2009 | 12:57 PM
  #168
ThumperMCS's Avatar
ThumperMCS
If they are a EvoTech dealer...
Mostly a west coast thing though...DynoComp in AZ is their main distributor I believe. You can try calling them and see what they can do for you.
http://www.evotech.de/index.php?article_id=46&clang=0
Terry J
Aug 11, 2015 09:39 AM
joelcseymour
Aug 7, 2015 12:43 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
