Drivetrain RMW Tune in Dallas OCT 17/18
Old Oct 13, 2008 | 09:12 AM
  #126
poskey's Avatar
poskey
OK Gnatster. I see I am down for 11:00 am on Friday. I'll be there in plenty of time. Can I use credit or debit to pay or is this cash only? Looking forward to this and meeting all you fellas. Poskey
Old Oct 13, 2008 | 09:25 AM
  #127
gnatster's Avatar
gnatster
Cash works best, Check is ok but if it bounces I'll have Jan send a kill code to the car!! I'm not really set up for CC/Debit but can do it through paypal with a fee.
Old Oct 13, 2008 | 11:39 AM
  #128
daegerter's Avatar
daegerter
quick last minute thought:
i have stock fuel injectors
is it really VITAL for me to upgrade them pre-tune?
not really wanting to fork over another lump sum,
but any idea what they run and where i can get them on short notice?
Old Oct 13, 2008 | 11:44 AM
  #129
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
My understanding is that with a stock head you will do fine with stock injectors. I think people put 380s in to provide a little wiggle room for extreme conditions (redline revs, poor fuel like in CA, etc.) You should still realize some nice gains from a RMW tune with your mods and stock injectors.
Old Oct 13, 2008 | 11:56 AM
  #130
PRattenbury's Avatar
PRattenbury
I'm no expert by any stretch. But I would say while it isn't vital, if you decide a few months or a year from now you want to upgrade your injectors, you'll also need to get re-tuned. So if it were me and I wasn't going to kill myself financially over it I would upgrade. Jan can hook you up with the injectors if you choose to get them, at least that's where I got mine.
Old Oct 13, 2008 | 06:19 PM
  #131
chuckt's Avatar
chuckt
Vital... No, but BMW feels you need them with the JCW pulley. Yours is even smaller so if you want to make the highest HP numbers that you can then you should go for it.
On the other hand, if you will never be running your car up to redline, then it might be a waste of money. When Jan tuned mine up there last Dec. I was mainly doing it for peace of mind after installing my 16%. The car made 198wHP and only needed a small timing tweek to clean it up. The JCW injectors would have put it over 200wHP because it was running out of fuel at the top. Yeah I wish I would have had them, but like you I didn't want to drop the extra $$$.
Old Oct 13, 2008 | 09:14 PM
  #132
mini_racer's Avatar
mini_racer
Too much hole showing?
Originally Posted by Intense
Here's the pre tune checklist. After our tuning day we found that the NAPA Belt# 060535 belt was the best for all reduced pulley applications. 15%, 17% and 19%
Jan recommends the Following:
1. Over half the hole showing in the tensioner
2. New plugs , if running more than 17% use NGK -7s or 8s
3. 91 octane gas, Chevron is usually the best
4. make sure your boots on intercooler are not worn/torn/old
5. Make sure you have no check engine lights
6. make sure your exhaust is NOT leaking
7. Clean air filter
8. Enough oil and coolant
9.Non slipping clutch
10. 380cc injectors if 19% or 15/3% or 15/2 or 17/2 etc
If you plan on running your car on the track it's always better to have 380cc injectors over the stockers
Specific to item #1................
Is it possible to have too much hole showing???
I went from just barely a sliver of a hole with my JCW belt and a Madness 15%, to ginormous hole with the Napa 060535 and the same Madness 15%.
I am guessing that after I run it a little and it settles-in that I will have a little bit less, but likely still way more than a whole hole.
Is this too much?
Will I shred the belt?
Can the tensioner do it's job if the spring is compressed this much?
etc., etc.??
Thanks...
Old Oct 14, 2008 | 04:24 AM
  #133
DrPhilGandini
That looks pretty good to me, mini_racer. I have a little less, but this could just be normal variation. I have the same setup as you (535 belt, 15% pulley, stock crank).
Old Oct 14, 2008 | 04:41 AM
  #134
mini_racer's Avatar
mini_racer
Thanks for the quick reply Dr. Phil. I will drive it a little today and then snap another pic after the belt has settled-in a bit.
while I do not know if it was slipping before as it is hard to tell if just a little, there is no way that belt will slip now.
Thanks Again...
Old Oct 14, 2008 | 05:55 AM
  #135
Revolution Mini Works's Avatar
Is this too much?
etc., etc.??
Thanks...
Dead sexy
Old Oct 14, 2008 | 07:43 AM
  #136
mini_racer's Avatar
mini_racer
Hey Jan,
That is not exactly the response I was expecting, but I got the message just the same.
Thanks......
Old Oct 14, 2008 | 11:00 AM
  #137
k-huevo's Avatar
k-huevo
Assuming the belt is routed correctly over all grooves, here's what the tensioner stop will look like with a NAPA 060535 after the belt has been in operation and relaxed some.
A JCW belt over a 15% reduction pulley will have less tension and be more likely to slip.
Old Oct 14, 2008 | 11:16 AM
  #138
mdbsat's Avatar
mdbsat
for some reason the above pic looks very familiar
Old Oct 14, 2008 | 12:00 PM
  #139
gnatster's Avatar
gnatster
Just changed my belt today, full hole still showing but was at 15k miles. Belt was cracked and ribs were missing chunks.
Old Oct 14, 2008 | 03:43 PM
  #140
chuckt's Avatar
chuckt
Your car is a beast!
Old Oct 14, 2008 | 04:08 PM
  #141
mini_racer's Avatar
mini_racer
A beast indeed, Gnatster how did you chew that belt up so much in only 15K miles? The JCW belt I just replaced at 14K miles looked virtually new. No cracks, and certainly no missing chunks.
Old Oct 14, 2008 | 04:30 PM
  #142
gnatster's Avatar
gnatster
I drive my car....
Old Oct 14, 2008 | 09:02 PM
  #143
mini_racer's Avatar
mini_racer
535 belt settled on 15% with std crank
Well after only ~20 miles after the belt swap, all seems to be much more settled and now have just barely more than a whole hole.
I think I will have to concur with the experts on the Napa 060535 selection.
Old Oct 15, 2008 | 01:49 PM
  #144
daegerter's Avatar
daegerter
i cant wait!
Old Oct 15, 2008 | 05:45 PM
  #145
please send me an email if you need BRISK plugs for the tune
thanks
Old Oct 15, 2008 | 08:22 PM
  #146
gnatster's Avatar
gnatster
thanks
Bring extras anyway. local folks may not see this.
Old Oct 17, 2008 | 07:10 AM
  #147
Intense's Avatar
Intense
252whp 200trq RMW style
Well I just happen to be in Dallas today for a convention. Looks like I'll have time to run by and say hello and watch some magic happen!
Old Oct 18, 2008 | 06:28 PM
  #148
PRattenbury
Well, just rolled in a couple hours ago from the tune. I must say even though something is still wrong with the car, the seat of the pants dyno indicates improvement was made. Drove home without a hitch. Gnatster, Jan, Intense, Mini-Racer, and Dr. Phil, it was nice to meet all of you. It was a freakin blast riding back from dinner Friday night. Minis ruled the road, for sure. I'd like to put out a BIG THANK YOU to Jan for coming to Dallas and hooking us all up with a tune, and to Gnatster for making it all happen. I hope it was enjoyed by everyone else as much as it was by me. Good times.
Old Oct 18, 2008 | 09:17 PM
  #149
Intense's Avatar
Intense
For me it's always a pleasure to meet fellow mini enthusaists! It was a pleasure meeting everyone Friday, I wish I could have stayed longer and hung out Sat too. Always a good time hanging out with Jan and everyone at these events.
I would love to give Gnatster a huge shout out for all your hospitality! Thank you for the good times and I hope that I can join you on the track sometime
Old Oct 19, 2008 | 06:01 PM
  #150
cucho's Avatar
cucho
Jan,
I know I left on Friday with no grin on my face because there was not enough road around the shop for a proper test drive and also the Dyno reading low (or at least lower than what I was expecting).
However as soon as I hit a little bit of open road I was in for a huge surprise...the car was running great...no more choking at high RPMs and the throtle response had improved significantly.
The 9 hrs drive was well worth it. Thanks!!.
And thanks to Nate for making it happen!.
