Drivetrain Intercooler Cooling Tests
Old Oct 5, 2008 | 08:09 PM
  #301
Intense's Avatar
Intense
252whp 200trq RMW style
Ah yes my friend I just installed these goodies yesterday! Very very excited about them The car pulls like a sonofa motherless goat!
It seems that my Invidia exhaust has a blown resonator and possibly mufflers. The car sounds like a raspy trombone playing 757 when I rev it. I called Jan and asked him "does this sound normal" then put the phone down and revved it. When I picked the phone back up all I heard was laughter on the other end! Seriously, the car is so loud right now I'm surprised you haven't heard a distant "trombone" tone when you go outside
I new it has gotten louder since I bought it, adding these better flowing parts has just made me very very aware that the exhaust is in need of some serious help
Old Oct 5, 2008 | 08:57 PM
  #302
big howe's Avatar
big howe
Jan is very helpful that way You learn to read the depth of the laughter.
Have fun, don't get it trouble. Seems like I have a homing beacon on my car right now.
Old Oct 5, 2008 | 09:39 PM
  #303
pberry51mini's Avatar
pberry51mini
No Fear Gear
Originally Posted by stevecars60
They're shocking. Maybe no one wants to know
Jan - maybe I am reading the wrong thing but my temps read usually about 7-10 degrees above ambient whenever I'm driving around town. On the highway I may be as low as only 5 degrees different.
Scangauge gives me the readings.
I'm guessing that's not too bad.
Paul
Old Oct 5, 2008 | 11:29 PM
  #304
NewMINI2's Avatar
NewMINI2
Very nice thread but unfortunately you didn't try any water to air system. It would be very interested to se the difference with that sistem.
Old Oct 6, 2008 | 06:17 AM
  #305
big howe's Avatar
big howe
Give him a break. No one else is donating their car/time /money for this testing. If you want to buy a W2A and give it to Intense for a few weeks during his next testing schedule I'm sure he'd be happy to test it.
Old Oct 6, 2008 | 06:18 AM
  #306
gnatster's Avatar
gnatster
Ah yes...no good deed goes unpunished.
Old Oct 6, 2008 | 06:50 AM
  #307
BlimeyCabrio's Avatar
BlimeyCabrio
Paul
I wish I saw temps like that... I'm running stock IC and 15%.... just cruising on the highway I typically see about 15 degrees above ambient (comparing the scangauge intake temp to the MINI thermometer) - when around town I commonly see 20 degrees above ambient. Would love to know why mine are significantly higher than yours...
Old Oct 6, 2008 | 06:54 AM
  #308
Revolution Mini Works's Avatar
Blimey, don't think yours are higher I think Paul's are just reading lower.
The only M45 charged car to be that was 2.0L stroker with 15% pulley
the temps are so low because the max boost on it is around 10psi
Old Oct 6, 2008 | 07:28 AM
  #309
Intense's Avatar
Intense
If I had a couple water to air systems I would have tested them. The problem is that they are expensive and more intensive to install. Its a bit harder for people to take one of and send to me for testing, and a vendor sending me a $2,000 brand new unit to run some tests on just wasn't happening.
Anyway, just to let everyone know what's up with me and the future possibility of more testing. I was laid off my job of 8 years a couple weeks ago. I have been scrambling trying to find work and exploring a few "work for myself" ideas. Its been a real trying time and it's far from over. Intercooler testing and most other things I do "for fun" have been put on hold for now.
I'm just hoping that I will be able to keep my things home, cars, assets. Its time like these when you realize how important family and friends are.
I'll tell you one person that has been a friend to me in a time of need. Mr. Jan Brueggaman, thanks for everything Jan. Thanks for your understanding, help and patients with me in a time of need. I really appreciate you and wanted to publicly thank you
Old Oct 6, 2008 | 07:37 AM
  #310
BlimeyCabrio
Cool... I can quit fixating on that now.
BTW - I'm LOVING the cam, Jan...
Old Oct 6, 2008 | 07:40 AM
  #311
wait til the header goes on and a reflash
thanks Intense.... it didn't need to be made public
but I do get a chuckle out of the raspy trombone
Old Oct 6, 2008 | 07:49 AM
  #312
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Anything less than 20F approach is good!
Here's a photo (made with my iPhone--aargh) just as I came off the freeway this morning, hence the low revs. I had to wait until I was on the off-ramp to get the snap. I was running 70+mph just before this.
The lower gauge reads airbox temp, above it the ScanGaugeII. A 10F approach is pretty common but I have done everything to lower it--probably to the exclusion of other objectives!
Old Oct 6, 2008 | 08:34 AM
  #313
BlimeyCabrio
Very cool - thanks Doc...
Also interesting how close the airbox temp is to the MINI-measured ambient in this particular case... I'm sure it's not always like that...
Old Oct 6, 2008 | 10:02 AM
  #314
DrPhilGandini
V...
I have seen the airbox temp -3F from ambient, due to evaporative cooling from the FAD ramming colder air into the box. At stoplights it will rise, and after sitting at the drive through it can get +20 or more. The thing then is rate of cooling--harder to take a still photo of, but video could help here. I'm not a videographer, so I'll leave that to someone else.
I also need to get a photo of what it looks like at 7000rpm. Maybe in a couple of weeks in Dallas...
Old Oct 6, 2008 | 08:03 PM
  #315
big howe's Avatar
big howe
The bottom line is top mount IC's are not your friend on the MINI. Unless you are above 100mph(adequate air flow) they are cookers. There are easier ways run near ambient IAT under load.
And by the way, the OBD IAT reading is not accurate, it can be off 30-40F or more at various times, even off 20F during transients at cruise.
P.S. Hang in there Intense, good luck, I'm sure you will land on your feet.
Old Oct 6, 2008 | 08:48 PM
  #316
Ryephile's Avatar
Ryephile
Big props to Intense for putting together this awesome thread!
This will help lots of MINIacs find the best intercooler for their needs.
Old Oct 6, 2008 | 08:55 PM
  #317
DrPhilGandini
Interesting. Any evidence to support this assertion? I believe it's your responsibility to provide it in this case, unless we are using political debating rules, then claims are taken are face value, regardless.
Given that the range of IATs falls within 20-280F (and I'm being very generous here), the errors you claim are very large. Are these instruments that poorly designed and calibrated? What is the accuracy? Does the manufacturer have a spec sheet?
Given my obsession with intake temperatures, I'm very interested in learning more about these issues. How would I independently measure IATs in the Mini?
Thanks for any information you can provide.
  #318
now that people are better informed............we have gobs of data to spring on the community for even more performance
Old Oct 6, 2008 | 09:01 PM
  #319
Big Howe is right, I have seen the logs and the equipment is top notch
I think people will be shocked when all of the data is presented
Old Oct 6, 2008 | 09:41 PM
  #320
big howe's Avatar
big howe
Doc Phil,
It has to do with the time-delay/averaging of the T-MAP. I have a type K tc(1/16" sheath, exposed junction) drilled right into the manifold next to the T-MAP, in addition to before and after the IC. After 30 seconds of cruising they will match, after that all bets are off.
I believe Dr.O has the model/specs of the T-MAP. If I remember right, he said something about 10-second averaging on the temp side, which is an eternity in this environment.
Once I finish this next round of tests, I will post data.
Old Oct 6, 2008 | 10:54 PM
  #321
BlueMax's Avatar
BlueMax
Hi Intense, very sorry to hear about your job loss! I can only sympathise with your situation and hope that you find a good means of generating income very soon.You did stunning work here with the IC testing and we would all like to see this continuing. All the best of luck!!
Old Oct 7, 2008 | 12:28 AM
  #322
Dr Obnxs's Avatar
Dr Obnxs
Next time you have a T-Map out...
take a look at it. The Tc junction is encapsulated in epoxy or something. This is why it's so slow. I did a bunch of research on automotive temp sensors, and thier specs are appalling. Now some of this can be corrected with good software, but the time constent in them is 10-20 sec depending on the manufacturer. There are several companies that make pretty much the same sensors.
One has to wonder what would happen if one were to dissolve off the encapsulation! Maybe it would be much faster but just not last as long? Any one with some acetone and some time on thier hands?
I think the design is for robustness, but the fact that the pressure side has ~20 millisecond time constant and the temp is about 1000x slower doesn't bode well for speed density systems. Maybe this is why the R56 has to have a MAF sensor to meet emissions....
Matt
Old Oct 7, 2008 | 04:51 AM
  #323
BlimeyCabrio
Verrrrrrry interesting...
Old Oct 7, 2008 | 05:11 AM
  #324
DrPhilGandini
Yes, all good stuff IMHO. Looks like I'll be drilling another hole in my intake system to install a better temp sensor... aargh. Blimey!
Old Oct 7, 2008 | 05:47 AM
  #325
PRattenbury's Avatar
PRattenbury
So is there just one maker of water to air intercoolers? Does anyone make a front mount? How about a front mount W2A? And would the money for such a creature be justified or would it be better spent on the likes of a Rotrex? Seems like the improvements in airflow made by the head, cam, CAI, header, cat-back and so on really have the stock SC out of its map.
