Drivetrain RMW's "Guess what's in the box?"
Old Aug 26, 2008 | 06:11 PM
  #351
Revolution Mini Works's Avatar
Originally Posted by mbcoops
Yep, he'll be faster in the straights when he puts it on. I see your point; I just think if you give all of the credit to power and the car, if there's ever a day when the same car with less (or inferior) equipment is quicker at the track, then the answer will most likely be to blame driver skill. It sounds like a contradiction to me, that's all. Like I said - I think it's effective marketing, but I don't have to tell you that, do I!
For me, I'll spend my money on other stuff because at my very low level, I can still catch more powerful cars on the straights by simply exiting the last turn at a slightly higher speed.
mb
it's NOT about how much money you spend.... it's how you spend it
some parts are proven winners.... other's aren't so proven
for example Larry's car with a JCW pulley puts down more power than most competitors cars with cylinder heads , intercoolers, cams, header etc etc
I'm taking nothing away from Larry's driving ability because I know he has done SCCA in the past but at some point you still need power to keep up. I tuned his car and have seen the numbers. I have ridden in his car. It's a sleeper. Just think if he put the coilovers on it that I sold him about 8mo ago
Old Aug 26, 2008 | 06:44 PM
  #352
searocko's Avatar
searocko
Originally Posted by Revolution Mini Works
wheels.... Motegi Track Light 2.0s
Hoosier 225/40/17"s
No rubbing with that setup? 42mm offset?
p.s. When is that oil cooler going to be ready?
Old Aug 26, 2008 | 06:47 PM
  #353
sometimes when I hit hard in the chicane. You go slightly airborne at 110+mph Nothing where it ever ripped it up. I use custom built spacers to get everything square
Need to get the oil lines made for the kit. That's on the table for tomorrow
Old Aug 26, 2008 | 06:54 PM
  #354
searocko's Avatar
searocko
Thanks for the info.
Cool, I can't wait!
  #355
mbcoops's Avatar
mbcoops
No doubt - he definitely hustles that thing around. As my instructor said this weekend, "granted, HP will help you on every single track there is, but it's not the only way to go fast on some tracks." This is probably OT, but Thunderbolt was cool (to me) because it was lengthy but it really didn't favor the high HP cars.
And I'm trying to figure out HOW to spend the money I don't have. When push comes to shove, I always end up springing for the track time instead of the mods. Oh, and then I spring for new rotors because they constantly warp due to the heat and lack of direct cooling. Larry's got the right idea with his brake kit! Big, fat, vented rotors.
My intention was not to take this off the topic of your TVS SC - as I stated, I think you've got a real winner there for many people looking to replace and upgrade at the same time if it ends up that way.
mb
  #356
Cool, I can't wait!
I'll take some pictures tomorrow
Old Aug 26, 2008 | 06:58 PM
  #357
mb
get the brake duct kit.... it works wonders
Old Aug 26, 2008 | 08:07 PM
  #358
jhiggs26's Avatar
jhiggs26
Hoosier 225/40/17"s
NO WEIGHT REDUCTION.... all completely STOCK.....actually weighs more as I have a W2A in the car
when you have 262whp/234tq.... who needs to take out weight?
if you look at Madness's best time with a pro driver in their turbo car on the same track it put down 1:31
I ran the farthest you can around the track....1.8mi
on the last track day I ran 1:28xxx on 5 laps and multiple sub 1:30s
when you take out the warm up laps you can see every run was 1:30 or under
I did 1:28 in only 5 track days.... I went 1:30 in 2 track days.... go figure
here is the info from the Eurotuner GP event on the Madness car
2003 Mini Cooper SDriver: Brian Smith - World Challenge driver, former test driver with BFG/Michelin, runs national driving school
Dyno: 328.8hp, 237.4 lb/ft of torque (8th)
Quarter-mile: 13.86 @ 106.4mph (9th)
Lap time: 1:31.275 (4th)
Engine: 1.6 liter four cylinder with JE pistons, engine balanced and blueprinted, ported cylinder head with larger valves, Mad Dog GT28RS turbocharger, AEM engine management, Mini-Madness chargecooler, engine oil cooler and baffled oil pan, 3" exhaust with no cats
Driveline: six-speed manual with RPS lightweight flywheel, Spec clutch, Quaife limited-slip diff, short shifter
Suspension: Leda coilovers, H&R springs, Mini-Madness 22mm rear sway bar, tubular front control arms and adjustable rear control arms, poly suspension bushings, camber plates
Wheels & tires: 17x7" SSR Competition wheels, 225/40-17 Falken Azenis RT-615 tires
Brakes: Wilwood big brake kit, DS2500 pads, stainless steel lines
Exterior: OE Mini aero kit, carbon rear spoiler
Interior: OMP seats, five-point harness, welded-in rollcage, tachometer with shift light, Turbosmart boost control, oil pressure and water temp gauges
Sweet wheel/tire set with a wide stable stance you've got there Jan! Stock LSD or aftermarket LSD?
I saw some video of you in another section here on NAM. You car moves alright!
I hope to get some track experience next year at the earliest. My darn baby came out of my wife premature and nixed autocrossing/tracking for me this summer. He's doing swell now though.
And please keep the 'Guess what's in the box' blower bolt-on project moving along!
Jeremy
Old Aug 26, 2008 | 08:14 PM
  #359
Jeremy
STOCK DIFF
it does have a Clutchmasters stage 4 , 4puck....
I'll try and get better resolution on the film , it's actually very clear but the compression was bad.
Don't worry the blower is getting CAD drawings done as we speak
Old Aug 26, 2008 | 09:15 PM
  #360
jhiggs26's Avatar
jhiggs26
That's where you've got them-with your light weight stock diff! With all the grip vs torque output, how long will your diff pin and spider gears last?
Please upload higher quality film too!
I'm happy to see CAD progress!
Jeremy
Old Aug 26, 2008 | 09:22 PM
  #361
Jeremy
if you listen to the clip you will hear the tires boiling if I jump it hard out of the corners
Old Aug 28, 2008 | 10:16 AM
  #362
MINI-Madness's Avatar
MINI-Madness
Hoosier 225/40/17"s
A few things to note Jan, You were running Hoosiers, easily good for a few seconds more per lap especially when hot. The Falkens we were forced to run are basically garbage especially when they get hotter. They always do the actual timed runs in the afternoon when the track in the hottest and the tires are at their worst. Again your Hoosiers are good for an easy 2-3 second advantage.
Driver, we did use a pro driver like everyone else at the event. Our driver never ran on that track before so it was all new to him. I believe this is your home track Jan and you know it i[FONT=&quot]ntimately. During the competition we had one 20 minute testing session in the morning and 3 laps to get the best time in the hot afternoon. Morning practice lap times were easily a few seconds better for everyone. Again not bad for someone who has never driven the car or course before.
You also mentioned weight of the car. Ours probably weighed the same as yours in the end seeing as it has a full cage, massive fuel cell and was built up for endurance racing.
All in all we were very pleased with having the fastest and most reliable fwd car at this event and that car is still doing lapping days and competitions today.
Call it what you will Jan but after 2 Car and Driver Magazine Superfour Challenge Events and 3 Eurotuner GP Cups over the years we still seem to be the only MINI tuner invited to participate, I think that says a lot. Let us know when your invited to compete in something like this, we would love to come and watch you run.
Congratulations on your excellent lap times Jan, you sound very pleased with yourself
[/FONT]
Old Aug 28, 2008 | 10:19 AM
  #363
thanks George... want a rematch?
I have a total of 5 track days.... I ran 1:30 on the 2nd track day EVER....
you don't think a World Challenge driver is a better driver than me?
Old Aug 28, 2008 | 10:33 AM
  #364
MINI-Madness
Next time I'm down there your on!
Would be fun to throw down the modded R56 Vs modded R53
Old Aug 28, 2008 | 10:34 AM
  #365
sweet... someone with enough ***** to come to the track
Old Aug 28, 2008 | 10:45 AM
  #366
RedSkunk's Avatar
RedSkunk
There's an actual kit?
Old Aug 28, 2008 | 10:55 AM
  #367
JCW actually made one but the Way ones are much cheaper
Old Aug 28, 2008 | 11:09 AM
  #368
jollyroger927's Avatar
jollyroger927
Think this is what hes talking about, could be wrong tho...
http://new.minimania.com/web/Item/NMB4000/InvDetail.cfm
Old Aug 28, 2008 | 11:10 AM
  #369
Myke@RPI's Avatar
Myke@RPI
Woohoo! Is this a battle to the death? the only rules are whoever loses, dies...hahaha how about that for Darwinism... but in jans defense hes running the stock s/c, i think that makes up for the tires... R56 vs R53 sounds like a good matchup!
Old Aug 28, 2008 | 11:18 AM
  #370
LOL... we don't make excuses... Our pro driver went 1:27 on R compound street tires in a 1.6L with the RMW head, injectors and tune. Did I mention stock JCW pulley? The car is his every day car
I wonder what he would run with my car?
  #371
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I would pay to see you two go at it! We need more competition in our community Competition = better products = More 's
Old Aug 28, 2008 | 11:37 AM
  #372
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
I hope it happens. Whatever the outcome it'll be good. Time to start looking for a plane ticket.
...But seriously Jan, Shouldn't you be working on fitting the Super Charger to the R53's and grinding more heads and cams? Get back to work
I need more power
Your threads are always full of entertainment.
Old Aug 28, 2008 | 12:53 PM
  #373
newbs49's Avatar
newbs49
Damn
I've been away for a few days and missed all this stuff and even guys talking about my car (thanks mbcoops). So when is the shootout. That would be very cool.
Jan
Get the oil cooler done. Me want one bad.
And yes. I know. Get the damn coilovers in.
mbcoops. get your plan in order- Way's ducts are very nice from the guys I know who have them. Thicker rotors are also the ticket.
Old Aug 28, 2008 | 01:21 PM
  #374
SharoSC02's Avatar
SharoSC02
I honestly don't care who is the better driver although it makes a world of a difference. That being said I badly want you to beat the R56 car with your R53.
Old Aug 28, 2008 | 01:43 PM
  #375
BlimeyCabrio's Avatar
BlimeyCabrio
I think this needs to be for pinks.
