Drivetrain Helix Stepped Core Intercooler - Real testing, Real results
Old Jul 23, 2008 | 03:21 PM
Ralph@Helix's Avatar
Ralph@Helix
Updated initial post with more info
Originally Posted by Mark@Helix
Helix R56 Stepped Core Intercooler
Core Design
Prior to the 335i and the R56 Mini stepped core design you had the option to either go Taller or thicker with the cores. In my design process I measured the captive areas in the front of the bumper in both depth and height and went about designing an intercooler that took up all of this area. The end result is an intercooler with 53% more frontal area as well as 50% more core volume. now about the core, we were not constrained to an off the shelf core in regards to ambient and internal fin count as we custom spec'd the core to this application. the core in the Helix FMIC is a single unit stacked up to our specifications in regards to ambient and charge row height and internal and external fin count. since our core has more volume I could increase the internal fin count to remove more temperature and still meet the targeted air flow and pressure drop for this application. as you see by the AIT data logs the intercooler works amazingly well.
Endank design- all endtanks are not created equally, air likes to flow in a smooth curved radius as you can see the Helix FMIC has rounded endtanks that are cast.
Install:
Fits in stock location- YES
requires no cutting,removal and/or permanent modification- Yes
Design:
More core volume than stock- Yes 50%
More Ambient face than stock- Yes 53%
More charge rows than stock(5)- Yes 12
Bar and Plate construction- Yes
Performance:
STOCK turbo outlet temperature 245 degrees F(estimated using a 65 degree ambient and 65% compressor efficiency at 15 psi
Temp drop from 245f to 111f(peak temp) in 4th gear run = -134f degree drop
HELIX TEST turbo outlet temperature 253 degrees F(estimated using a 71 degree ambient and 65% compressor efficiency at 15 psi
Temp drop from 253f to 89f(peak) in 4th gear run = -164f degree drop, 21% better cooling than stock
AIT temp- 30 degree drop over stock
pre and post intercooler temp drop- 164 degrees F
Intercooler efficiency- 80% - 21% improvement in efficiency over stock(59%)
Core pressure drop spec is .5psi at 250hp(400cfm) airflow
Installed
Attached Thumbnails Helix Stepped Core Intercooler - Real testing, Real results-3rd-gear-temps-.jpg   Helix Stepped Core Intercooler - Real testing, Real results-4th-gear-temps.jpg
Last edited by Ralph@Helix; Jan 5, 2009 at 08:47 AM. Reason: Charts didn't show up 1st go-round...
Old Jul 23, 2008 | 04:02 PM
ThumperMCS's Avatar
ThumperMCS
Originally Posted by ralphHelix
The Helix Stepped Intercooler design has a bigger frontal ambient face combined with thicker-than-stock core that seals off to the radiator fan/shroud. The cast end tanks have factory mounting points and factory charge pipe angles. The core of the Helix Stepped Intercooler has increased fin density and will flow 250 horsepower with only a 0.5PSI pressure drop. That translates to cooler intake temperatures with a slight reduction in pressure.
Here are two graphs showing you the results from the data logging of our stock R56, then with only the Helix Stepped Intercooler installed. We think you will be impressed with the performance improvements!
Both graphs compare intake manifold temperatures between the stock intercooler (dang stock piece looks like a small toaster oven!) versus the Helix Stepped Intercooler (jumbo air-cooling surface area!). The first graph shows the intake air temperature changes as we performed a 3rd gear roll-on at wide-open-throttle. The second graph shows the intake air temperature changes as we performed a 4th gear roll-on at wide-open-throttle.
With this intercooler, under high-performance driving your R56 will be less prone to heat-soak, leading to increased performance and sustained power. The Helix Stepped Intercooler will be a perfect upgrade especially combined with a GIAC reflash.
Pricing??
Old Jul 23, 2008 | 04:21 PM
e30r56's Avatar
e30r56
Are there supposed to be pix and graphs in your post? I don't even see red x's.
Old Jul 23, 2008 | 07:16 PM
TBMINI's Avatar
TBMINI
i got the red x's
sounds interesting though
Old Jul 23, 2008 | 07:48 PM
SlowB00st's Avatar
SlowB00st
Originally Posted by TBMINI
i got the red x's
Same here with the red....XX
So form your post I gather there is no cutting involved just revome the stock and bolt the helix unit in.... Any dimensions on the core???
Old Jul 23, 2008 | 09:25 PM
fongaroos's Avatar
fongaroos
is the GIAC reflash even available yet? i skimmed through an old GIAC thread, but last time i checked it had not been released.
Old Jul 23, 2008 | 09:28 PM
fongaroos's Avatar
fongaroos
btw...
1/3 of the way down the page...
http://www.helix13.com/mini/products/engine-intake
Old Jul 24, 2008 | 08:08 AM
sfkarp's Avatar
sfkarp
Dos this translate to any HP increase with a stock car? Or is it for when you have raised the boost level?
Old Jul 24, 2008 | 08:15 AM
Ralph@Helix
Yes the reflash is available . It is $625. You can stop by the shop to get this done or if you're too far you can send in your DME. We have a 24hr turnaround time
Old Jul 24, 2008 | 08:43 AM
samroberto's Avatar
samroberto
625 for the GIAC ? How much for the intercooler ??
THANKS !!
Old Jul 24, 2008 | 09:14 AM
ThumperMCS's Avatar
ThumperMCS
Hmm intercoolers never get me excited, but I kinda like this....
Hope pricing is good.
Old Jul 24, 2008 | 11:54 AM
Rob@Helix's Avatar
Rob@Helix
Vendor
Reply to sizing and pricing
The Helix Stepped Intercooler is a direct fit bolt on - installation will involve removal of the R56's front air dam, then removal of stock intercooler. Next secure the new intercooler, and remount the front air dam. No cutting, drilling or other modifications needed. It's a clean fit. No ECU flags or error codes...just cooler intake air.
It gives a slick look too, whether you keep the stock lower air grill (just a slight hint of something lurking beneath your R56 MCS) or use an aftermarket one that shows more of the intercooler!
We did not dyno test, therefore don't have HP/Torque data...Our data did clearly show much cooler intake manifold air temperatures, especially from mid- to high-RPM ranges. The Helix Stepped Intercooler will make little HP difference as a single aftermarket improvement, but is valuable when adding increased boost pressure! Other valuable benefits from the extra cooling for your R56 include: experiencing less HP power-drain on hot days (summer), cooler engine temps, and improved cylinder detonation thresholds (meaning that the R56 ECU will not retard ignition timing as soon).
This was our final testing on the Helix Stepped Intercooler, and pricing will be available shortly...Look out for our next announcement! Thanks for checking it out!
Old Jul 24, 2008 | 01:29 PM
samroberto's Avatar
samroberto
can we hope to hit below the 700.xx mark ??? That would be a sure buy for me !
Old Jul 24, 2008 | 01:53 PM
dnor72's Avatar
dnor72
Is there a specific GIAC tune developed for a car with the intercooler or is the GIAC tune the same as would be flashed onto the car without the intercooler?
Old Jul 24, 2008 | 02:56 PM
minipete07's Avatar
minipete07
2ND THAT...
Old Jul 24, 2008 | 03:05 PM
e30r56's Avatar
e30r56
Any plans for a "stealth" black one?
Old Jul 24, 2008 | 03:32 PM
ukaussi's Avatar
ukaussi
Indeed, whereas I don't want to take away from the amount of time & resources (which add up to $$$) that were involved in developing this great FMIC, I am sure there are many of us that would give it a lot more consideration if it were priced more reasonably (<$500) than the others out there.
I would love to have a better flowing/cooling FMIC as (1) I live in NE TX so 90-100F right now (2) I have the Unichip so can take advantage of the better flow & cooling capabilities.
This is not a "bling" item for me, it is a functional item so must be worth buying.
At $700 a new FMIC is seriously overpriced and more for someone almost 1/2 my age with $$$ to burn on "bling"
Old Jul 24, 2008 | 03:59 PM
ThumperMCS's Avatar
ThumperMCS
I'm with you!
Never considered getting an intercooler, but like what Helix has done with this. If the price was cheaper than the other outrageously priced IC's...then you'd really have me on board.
Old Jul 28, 2008 | 08:37 PM
mnimule's Avatar
mnimule
I 2nd all that depending on the price im in!!! Do I smell a group buy forming here....?
Old Jul 28, 2008 | 09:04 PM
samroberto's Avatar
samroberto
I've never done a group buy before but if that means a bunch of us order at the same time or one person does and we all distribute from there, and then we get much better prices ? ... mm... might have to be in on that !
Old Jul 28, 2008 | 09:22 PM
mitemini's Avatar
mitemini
I think you guys are smoking serious crack if you think this is going to be under $700 even on a group buy. But I hope Helix proves me wrong.
Even on that note I'd love to see it FINALLY come out, I'd be in the market for one.
You gotta pay to play boys.
Old Jul 29, 2008 | 10:55 AM
mnimule's Avatar
mnimule
I want to know who and how many of you would be intrested in a group buy for this FMIC....? If we got a better price than retail....?
Old Jul 29, 2008 | 11:36 AM
samroberto's Avatar
samroberto
x1
Old Dec 18, 2008 | 06:27 AM
Ralph@Helix
The Helix Stepped Core Intercooler is now available folks!
No need for a group buy since we're offering it at an introductory price of $679
Old Dec 18, 2008 | 07:55 AM
chickenplucker's Avatar
chickenplucker
How about engineering data?
Real testing, real results - how abouts real specs?
