Drivetrain Coated vs. non-coated supercharger - how to tell?
Old Jun 18, 2008 | 10:35 AM
jblow's Avatar
jblow
Is there a way to visually tell between an early (non-coated) and later or JCW coated vane supercharger for the Mini? Based on pics, some have a grey/black finish on the vanes that is slightly rough while some are light grey and more smooth.
In addition; assume that any of these would be interchangeable across production years - any insight?
Thanks in advance!
Old Jun 18, 2008 | 11:14 AM
gnatster's Avatar
gnatster
They are all interchangeable across all the supercharged years.
Coated vanes are have the grey/black finish.
Coating started on the JCW S/C's and from 05 on was extended to all.
Old Jun 18, 2008 | 01:23 PM
Silent1's Avatar
Silent1
All facelift 'S have a teflon cated supercharger, but i thought the JCW changed at the same time as well?
The way to tell is it's black and not quite as smooth, if it's grey it's pre-facelift.
Old Jun 18, 2008 | 01:41 PM
Nitrominis's Avatar
Nitrominis
The SC rotors are aluminum. If it is coated it will be grey or dark grey or almost black. This is what a SC looks like with coating coming off and going through the engine. This is off an 05.
I have never noticed a difference in smooth or not? I have seen both in the same year mini? what made the difference?
+ 1 on the interchangeability.
Old Jun 18, 2008 | 02:39 PM
jblow's Avatar
jblow
So, if it's dark grey or black, it's a coated unit (regardless of manufacture date)? Does this appear to be a coated model?
Old Jun 18, 2008 | 03:48 PM
jollyroger927's Avatar
jollyroger927
Id say Yes.
Old Jun 18, 2008 | 04:03 PM
Nitrominis's Avatar
Nitrominis
I guess color is in the eyes of... But yes that is an uncoated SC
Old Jun 18, 2008 | 07:11 PM
jblow's Avatar
jblow
This one looks darker than some other early builds I'd seen - is the consensus then that this one is uncoated? What are some things to be aware of / look for (other than the obvious leaks, free spinning, no clear evidence of rotor damage? Anything look awry on this one - here's another image:
Old Jun 19, 2008 | 03:11 AM
Larry Clemens's Avatar
Larry Clemens
2005 model year or 2005 build date? I have a 2005 MCS with a late 2004 build date. Thanks
Old Jun 20, 2008 | 06:01 AM
jblow's Avatar
jblow
bump - wanted check other perspectives prior to making a purchase decision on this used unit
Old Jun 20, 2008 | 01:31 PM
billzcat1's Avatar
billzcat1
While I don't have any direct experience with the Mini-iteration of the M45, all other Eaton blowers I've had my grubby little fingers on have had smooth, machine-finished aluminum rotors... not slightly textured black rotors. I'd put my money on coated.
Old Aug 27, 2013 | 03:00 PM
CORNERS's Avatar
CORNERS
I just replaced my supercharger on my 2004 with a post facelift unit. Both have coatings. The old supercharger had a medium to light grey coating that looks exactly like teflon on a frying pan, maybe a tad smoother. The coating was coming off and getting stuck in my intake. I got a good deal on a post-facelift supercharger so I replaced for that.
The post-facelift coating is almost completely black and has a rougher feel to it, almost fuzzy. I understand that this wears down as needed to reach essentially zero tolerance.
The coating has almost an anodized look to it, so I suspect it will be more durable than the pre-facelift coating which almost looks like a thick coat of paint on top of the aluminum.
Greezyman
12
Sep 18, 2015 05:47 PM
SneedSpeed
Sep 10, 2015 07:22 AM
sempaipaul
Sep 9, 2015 05:55 PM
Sep 3, 2015 03:01 PM
