Drivetrain Need Clutch help ???
Old Jun 6, 2008 | 05:52 AM
Luys's Avatar
Luys
Hi NAM members,
Once I put the car on dyno I smiled clutch burning and the performance shop told me your clutch may need to change. I took appointment with the service and they will check it.
What is the best clutch for 200 WHP ? I have browsed www.revolutionmini.com and www.minicorsa.com site I could not understand which one is the best for my car
Can anybody show to me the installation for the clutch ?
Thanks.
Luys
Old Jun 6, 2008 | 06:23 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
ACT HD Street Clutch
There is an article in MC2 Magazine, January February 2008 issue, that covers this subject. Mat Richer aka Dr. Obnxs replaced his clutch with a ACT HD clutch,flywheel and pressure plate kit. I know he has upwards of 200 horse power in his mimi. The article is on pages 60 through 63.
Old Jun 6, 2008 | 08:14 AM
spdfreak's Avatar
spdfreak
I have a Clutch Masters FX-300 w/lightweight flywheel and I love this set-up. Jan of RMW recommended this combo for higher horsepower mini's
Old Jun 6, 2008 | 08:54 AM
Luys's Avatar
Luys
What about the installation was it easy to install ?
Old Jun 6, 2008 | 08:57 AM
roggenmini's Avatar
roggenmini
If you think ripping the whole front end of your car out "Easy" then yes. You have to pull the forward subframe and front clip then the tranny! Lot's involved!
Old Jun 6, 2008 | 12:01 PM
spdfreak's Avatar
spdfreak
I personally wouldn't say it was hard, just time consuming. It also helps having a mechanic for a friend. I found the worst part of the job was bleeding the clutch, we tried the bently method with no luck. Onasled was kind enough to give me a new method which worked perfectly. Do a search there are two excellent how-to's on the subject.
Old Jun 6, 2008 | 12:07 PM
roggenmini's Avatar
roggenmini
I agree that it is not hard. Very time consuming. Make sure you know where every bolt goes back in! You don't want to end up with extra parts!
Old Jun 6, 2008 | 03:49 PM
spdfreak's Avatar
spdfreak
I agree, spare parts are always a bad thing.
Old Jun 6, 2008 | 04:46 PM
jhiggs26's Avatar
jhiggs26
Here's a fabulous how-to by K-huevo:
https://www.northamericanmotoring.co...52#post1451152
Here's my experience with the install:
https://www.northamericanmotoring.co...t=obx+atb+diff
Here's one more fun read:
http://engr.smu.edu/rcam/cpm3v/minic...niclutch01.htm
Jeremy
Old Jun 6, 2008 | 10:14 PM
Luys's Avatar
Luys
Which spare parts ?
Old Jun 6, 2008 | 10:48 PM
jhiggs26's Avatar
jhiggs26
Parts(I think he meant hardware) that never found there way home.
I mixed up the M6 bolts for the SC inlet duct with the exhaust manifold heat shield. I quickly noticed they were not in there proper holes. So yeah, the best method is to bag and tag all the hardware.
Jeremy
Old Jun 6, 2008 | 11:10 PM
Dr Obnxs's Avatar
Dr Obnxs
Really, you want to look at torque capacities
HP isn't what's relevant for clutches.... The ACT is a good set up, but they don't have all the "flavors" that clutchmasters offers. Give any of the good shops a call and see what they say about where your car is at, where it will be (in terms of ultimate mods) and how you drive, and they will steer you well...
Matt
Old Jun 7, 2008 | 12:49 AM
Luys's Avatar
Luys
Jeremy
Thanks Jermy I think the installation was very difficult
Have you felt the flywheel + clutch is better than the original one ?
Old Jun 7, 2008 | 01:04 AM
Luys's Avatar
Luys
What is the best for me just racing once a week flywheel + clutch is it stage 1,2 or 3 ?
Do I need to change the flywheel with the clutch ? because i want to change the clutch only.
Old Jun 7, 2008 | 04:31 AM
spdfreak's Avatar
spdfreak
It really just depends on your long term goals for the car, I knew I wanted a RMW set-up so I opted for the best street clutch I could get. Act, Spec and Clutchmasters were all in the running but I got the best deal through Jan on the Clutchmasters set-up. And as far as the flywheel, maybe I'm way wrong on this, but It was my understanding that anytime you replace a clutch you should have the mating surface of the flywheel machined. Again from what I've read, Mini flywheels cannot be machined due to thickness issues and so a new flywheel is required. I figured if I'm going to get a new one anyway I might as well get a lightweight one.
Old Jun 7, 2008 | 09:17 AM
jhiggs26's Avatar
jhiggs26
The installation is time consuming(for us 1st timers) but there's no real special tools or anything needed to expose the pressure plate, clutch disc and flywheel. You'll just need the usual assortment of sockets(E8 torx for pressure plate bolts) extensions, universal joints, torque wrenches, and smiles.
The CM flywheel and CM FX200 has been good to me. I'm 300 miles past the break in now and it has allowed the motor to become very rev responsive. FW mass going from 26-27 lbs down to 12-13lbs is such a great thing for our dinky little 1.6L motors. The CM FX200 solid kevlar disc is appropriate for what I do with my MINI(will autocross and track day a few times per year). All in all I'm a happy MCS driver.
Jeremy
Old Jun 7, 2008 | 09:20 AM
jhiggs26's Avatar
jhiggs26
What type of racing? Drag, autocross or track? If it's track you'll be more concerned about heat build up and may want to go for at least a stage 2 plus or stage 3(segmented or paddle disc arrangement). Have fun shopping!
Jeremy
Old Jun 7, 2008 | 10:42 PM
Luys's Avatar
Luys
Jeremy
No on the street here in turkey there is long way beside the sea and there happen competition between each other What is the difference between FX300 and 200 because it has the same price ?
Old Jun 7, 2008 | 11:19 PM
Guest's Avatar
Guest
I'd go with the FX300 too. I have the FX400 and it's a bit extreme for the street.
Old Jun 8, 2008 | 05:45 AM
spdfreak's Avatar
spdfreak
If I'm not mistaken, the FX 200 has less holding ability than the FX 300 however the FX 200 should be a little easier to drive on the street. I've found the FX 300 a little more difficult to drive on the street than the stock clutch, I'm not saying it's hard, just the engagement is very sharp and reqires a bit to get used to.
Old Jun 8, 2008 | 08:08 AM
Luys's Avatar
Luys
That mean FX200 is better for street ???
Old Jun 8, 2008 | 08:13 PM
jhiggs26's Avatar
jhiggs26
The FX200 should work fine for the street Luys. It's working out fine for me.
I would PM guys like Spdfreak and Rustyboy155 for more of their views on the FX300 and FX400 respectively.
Jeremy
Old Jun 8, 2008 | 08:24 PM
Guest's Avatar
Guest
Jeremy
E-Mail would be better. Given the recent events on NAM (a hair away from a complete dictatorship) I'm probably going to be taking a sabbatical from this site.
Old Jun 8, 2008 | 08:45 PM
Dr Obnxs's Avatar
Dr Obnxs
Why leave volentarily..
when you can earn your absence!
Matt
Old Jun 8, 2008 | 08:55 PM
Guest's Avatar
Guest
Matt
*Breaks out Kumbaya CD*
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
