Drivetrain Fully MODed MINI place 3rd in Car and Driver's front drive t
Old Aug 13, 2003 | 05:58 PM
chrisfb1's Avatar
chrisfb1
3rd Place
2002 Mini Madness Mini Cooper S
Street drivability:
1/4-mile: 15.7 sec @ 97 mph
Road course: 65.7 sec
130-to-0-mph braking: 554 feet
Total course time: 137.3 sec
Mini madness is not just the phenomenal acceptance of the Cooper over the past year. It's also the name of an outfit based in Portland, Oregon, that hops up the English wonders. Madness president George Mehallick showed up with a Cooper S fitted with just about every part in the company's catalog.
Under its stubby hood, the Madness Mini had a supercharger drive pulley that upped the blower speed by 15 percent, raising boost from 11.6 to 15.0 psi. Further mods include a ported and polished Madness Stage 3 head with big valves and a Schrick cam, a throttle body bored out from 58 millimeters to 63, a header, and a Borla exhaust system. Larger injectors and a modified ECU added fuel to match the engine's deeper breathing.
Mehallick credits the modified engine with 245 horsepower at 7100 rpm and 198 pound-feet of torque at 4000 rpm. To transmit this big twist to the wheels, the Madness Mini came with a modified flywheel and clutch, as well as a Quaife limited-slip differential.
The extra power comes with a comprehensively reworked suspension, including KW adjustable coil-over shocks at each corner that increase ride rates and lower the car nearly two inches. Several major components are adjustable, including the rear anti-roll bar, the rear lower-control arms, and the front camber plates. Big StopTech front brakes and upgraded rear discs shed speed when necessary.
On the street, this muscular Mini's powertrain felt solid and robust. The clutch engagement was smooth and progressive, the power curve was glitch-free, and the car suffered amazingly little torque steer, even at full throttle in first gear.
The chassis was a bit more demanding for street use, with a stiff ride that provoked a squeak or two in this car with 14,000 miles on the odo. And the modified exhaust would bore a large hole in your brain over a long trip. But the steering and the brakes were fluid and natural.
On the track, the firm chassis paid off with the best road-course time—by 1.5 seconds—among the front-drivers, as well as the best stop in the class from 130 mph at 534 feet. By employing these strengths, the Madness Mini turned the third-best overall time for front-drivers, despite acceleration that trailed the pack in almost every category.
In search of more power, Mehallick is working on an air-to-liquid intercooler to replace the stock air-to-air unit. For now, the Mini Madness Mini nicely amplifies the agility and maneuverability of the stocker. —Csaba Csere
Vehicle type: front-engine, 2+2-passenger, 3-door coupe
Price as tested: $44,260 (base price*: $38,250)
Engine type: supercharged and intercooled SOHC 16-valve 4-in-line, iron block and aluminum head, Siemens/Evotech engine-control system with port fuel injection
MODS engine/transmission: $8800; suspension: $3800; brakes: $3100; wheels/tires: $3000; body/interior: $5000
Displacement 97 cu in, 1598cc
Power (mfr's claim) 245 bhp @ 7100 rpm
Torque (mfr's claim) 198 lb-ft @ 4000 rpm
Transmission 6-speed manua
l Front brakes StopTech 12.9 x 1.1-in vented, grooved disc; StopTech 4-piston caliper
Rear brakes Powerslot 10.2 x 0.4-in grooved disc; 1-piston caliper
Brake-pad material, front carbon-metallic
rear carbon-metallic
Wheelbase 97.1 in
Length 143.9 in
Curb weight 2618 lb
Weight distribution, front/rear 61.9/38.1%
*Base price includes all performance-enhancing options.
Old Aug 13, 2003 | 06:05 PM
jimmer0's Avatar
jimmer0
245 HP...makes me wonder what took 1st and 2nd??
Old Aug 13, 2003 | 06:16 PM
mobygjc's Avatar
mobygjc
https://www.northamericanmotoring.co...mp;topic=14604
Old Aug 13, 2003 | 06:19 PM
BlueMCS's Avatar
BlueMCS
>>lower the car nearly two inches<<
Slam city!! Streetable, yea right. He must have fun with potholes and speedbumps.
Shoulda talked to JLM about a couple of spacers.
Old Aug 13, 2003 | 06:25 PM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
We need more torque. Ratio of HP and torque to the drive wheels needs to be balanced to give the best performance. This to me will bring MINI to the top of the list, where lots of people think HP itself will make this a faster car.
Old Aug 13, 2003 | 06:31 PM
jlm's Avatar
jlm
he did have one of my throttle bodies...I guess that ends the debate over whether 61 or 63mm works.
Old Aug 13, 2003 | 06:38 PM
Antranik's Avatar
Antranik
>>Curb weight 2618 lb
End Result:
I'm confused. Can somebody clear up this 15.7s figure for me? The specs just don't add up, even with the fact that the 6-speed isn't geared for 0-60. Right?
Old Aug 13, 2003 | 06:46 PM
greatgro's Avatar
greatgro
How come the 15.7sec 1/4 mile with all that power AND a LSD???
It just doesn't add up! Andy's got a database that shows 18 people with a lot less power getting a much better time!
Andy's 1/4 mile MINI page
Old Aug 13, 2003 | 07:05 PM
nfo's Avatar
nfo
i saw the show with this race..
i heard that there was some really bad wind and all the cars times were bad!
Old Aug 13, 2003 | 07:23 PM
mobygjc's Avatar
mobygjc
yes it does not add up, because if you go to http://www.caranddriver.com/article....page_number=16 and see this WRX. A friend of mine has a WRX with 400hp and he gets low 12's for a fact! This car should be in the 11's close to high 10's with 450hp. While a STOCK Mini, will get 15.7 and I have seen some with really good drivers get 15.5 in a stock MCS. Those winds must of been 50 mph!! Why didnt' they just pick another day....to do this.
_________________
I am the Question Man!
Old Aug 13, 2003 | 10:25 PM
weaverpsu's Avatar
weaverpsu
they were driving into a massive headwind.
Jimmer at 240 hp it was the lowest in the challenge. The highest was 450 which finished 2nd in rwd/awd class.
Old Aug 14, 2003 | 07:59 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
97 mph trap speed is pretty impressive.
Old Aug 14, 2003 | 10:41 AM
mobygjc's Avatar
mobygjc
I would say if the weather was right, with 245hp in a MCS, with the right driver should get high 13's or mid 13 in a 1/4 mile. What you guyz think?????
Old Aug 14, 2003 | 10:51 AM
mobygjc's Avatar
mobygjc
Old Aug 14, 2003 | 10:53 AM
Rocketboy_X's Avatar
Rocketboy_X
I'm just wondering how they did the ranking... They were 3rd in the article (but not the 3rd fastes) and on the TV show they were 8th... Color me confused... but congrats... I can't wait to see what's going to happen in the future...
Rocketboy_X
Old Aug 14, 2003 | 10:59 AM
Davbret's Avatar
Davbret
>>Rocketboy_X
The magazine article splits the contenders into FWD and AWD/RWD categories. As such, the MINI finished 3rd in FWD and 9th overall. The TV show grouped everyone together, no seperation for drive class.
R
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
xpunisherx
Aug 10, 2015 10:50 PM
tippin
Aug 5, 2015 08:43 AM
