Drivetrain TwinCharged MCS From Istanbul/Turkey
Old May 15, 2008 | 11:34 AM
Gokhan_Dayı's Avatar
Gokhan_Dayı
Hi,
I'm from Turkey.. My name is Hakan Sinclair .. I'm 24 years old.. And living in Istanbul..
I want to share my cars pictures , modifications and dyno sheet..
I hope you will enjoy..
This car powered by Goofy Motorsport Istanbul
2004 year R53
Twincharged
On 1.75 bar it produces 364 Hp and 314 Nm Tork
I havent got a dyno sheet on 2.0 bar..
Modification list:
Garrett GT3071R turbo charger
Evc 6
Apexi S-AFC Select
Custom chip
Colombo&Bariani Camshaft
750cc injektor
HKS ignition plugs
MSD bobbin
MSD ignition cables
Spec Stage 2 clutch kit
Fidenza light volant
Wiseco Forged Piston
Pauter Forged connecting rod
Walbro fuel pump
Snow performans Water Injection System
Alta Top Mount Intercooler v1
Alta Polished Tubular Exhaust Manifold
Alta Polished Mandrel Bend Down-pipe
Alta %5 Supercharger pulley
Alta Polished Boost Tubes
HKS Blow Off Valve
HKS turbo timer 1
Perrin oil tank and water lines
Foam Filter Element
Silicone Intake Tube
M7 termostat
Alta cai
2x Hks exhausts
Swoosh EGT
Swoosh Bar
AEM wideband
AEM regulator
Eibach 3 cm coil springs
Koni sport shock absorbers
Wilwood Brake Kit (Front)
Omni competition brake disks Rear
17' Oz Racing Super Laggera Rims
215/40/17 Pirelli Zero Nero wheels
Jcw Front Bumper
Jcw Side skirts
Jcw grills
Sonar tail light
05' oem Front lights
Old May 20, 2008 | 12:02 AM
chuntington101's Avatar
chuntington101
Hakan, thats one nice car you have there! how much power did it make at 2.0bar??
be nice to see the intake temps to with the hot weather you guys get in turkey
Chris.
Old May 20, 2008 | 12:17 AM
Tüls's Avatar
Tüls
Turbius Maximus
Ha ha welcome fellow TCer!!
Old May 20, 2008 | 04:14 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Great job. Glad you joined us on here
Old May 20, 2008 | 05:58 AM
grillhands's Avatar
grillhands
Correct me if i'm wrong but isn't 2bar 28psi? If so Thats alot of Boost!
Old May 20, 2008 | 06:08 AM
checkmate2006's Avatar
checkmate2006
Thats in the Boost Ballpark Tuls is running.
Old May 20, 2008 | 06:17 AM
Guest's Avatar
Guest
When I talked to him I thought he said he was running closer to 35...
Old May 20, 2008 | 06:29 AM
Malcon's Avatar
Malcon
very very nice!
Old May 20, 2008 | 06:30 AM
checkmate2006
Yeah I was giving general answer because for Tuls it was altitude that bumped the boost up.
Old May 20, 2008 | 06:35 AM
Guest's Avatar
Guest
Those twincharged guys are a whole different breed. Serious cahones to be running nearly 4x the stock boost through that little motor...
Old May 20, 2008 | 06:44 AM
MINIFVR's Avatar
MINIFVR
I like that this MINI is understated as well...talk about a sleeper. Some of those rice burners out there better pick their matches wisely.
Old May 20, 2008 | 06:58 AM
hemiheaded18's Avatar
hemiheaded18
It must sound like a Peterbilt passing you on the highway.
Old May 20, 2008 | 07:05 AM
checkmate2006
Don't forget the turbo-only guys they are even more SILLY.
Old May 20, 2008 | 07:19 AM
Wake|MCS's Avatar
Wake|MCS
Nice ride, love the wheels. Good numbers too!
Turbo > Supercharger
Old May 20, 2008 | 08:53 AM
Tüls's Avatar
Tüls
Turbius Maximus
turbo only can run almost 10 lbs LESS boost to make the same power... there for... TC get's the cahones granted.... IF you have turbo only and turn it up.... yeah.. that'll win... LOL
Old May 20, 2008 | 10:02 AM
checkmate2006
Yeah thats about right because TC guys have so much STUFF spinning around at WARP 6,000 its just scary to think if something came loose at WOT it would be like a real life case of Tony Stark getting shrapnel from his own bombs.
Old May 20, 2008 | 10:28 AM
Bang110's Avatar
Bang110
Istanbul was Constantinople
Old May 20, 2008 | 11:24 AM
Guest's Avatar
Guest
If you want 3600 RPM's of ridiculous power (4k RPM's to 7600 RPM's) and the rest of it you have no power, sure, go Turbo. Twincharge or Supercharged only is ALWAYS going to be more fun to drive on the street.
Old May 20, 2008 | 11:26 AM
Guest's Avatar
Guest
The R56 does with that stupid DIY intake! One of my friends passed me on the freeway on the way home from Bimmerfest and I swear I thought a semi was trying to pass me.
I've never heard Tuls' car, so I'm not sure!
Old May 20, 2008 | 12:42 PM
ThumperMCS's Avatar
ThumperMCS
hahaha . Dunno who that was! I'm putting it back on think...
Old May 20, 2008 | 04:43 PM
SteveS's Avatar
SteveS
Niiiice!!
Stock head? No porting?
ARP head bolts?
what size valves?
Quaife?
Old May 21, 2008 | 12:24 AM
chuntington101
hakan, also is there any reason you mounted the meth spray so closed to the throttle body?? surelyit would have more time to evaperate and cooler the air from the turbo if it was mounted closer to the trubo??
Cheers
Chris.
Old May 21, 2008 | 06:28 AM
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
That's a sweet looking ride. How's the ride/performance? Nice work mang!
Old May 21, 2008 | 11:27 AM
joshK's Avatar
joshK
now it's Istanbul NOT Constantinople
Old May 23, 2008 | 07:01 AM
Gokhan_Dayı
I was waiting for the reply message from the Forums.. Sorry for the late message..
I forgot to put the dyno sheets.. Now it's here..
In this sheet, car don't have Light volant and spec clutch kit.. The stock volant and the orijinal clutch :
I'm from Turkey/ Istanbul... Not constantinapolis or ETC.. Just Istanbul.
Thank you very much for your answers/replies and thoughts..
I will upload some videos later.. When car is 300 hp and rolling with Corvette C5.. You will enjoy
Someone ask , what power at 2.0 bar.. We havent got a dyno at this power, i think that will be between 390-405 hp... But the best way is to go to the dyno
