Drivetrain Replacing Motor Mount??
Old Apr 18, 2008 | 08:47 PM
EDM's Avatar
EDM
So I have a 04 CooperS with the new style motor mount, which does as good of a job and a ham sandwich in my engine bay, and it decided to take a leak all of the place.
Has anyone had to replace this themselves?
What kind of labor is involved?
How much is this god forsaken chunk of poor engineering going to run me?
Thanks in advance.
Old Apr 18, 2008 | 10:56 PM
UKSUV's Avatar
UKSUV
Well my friend...you can swap it to the other style motor mount....and its easy enough YOU can do it... . There has to be a DIY somewhere but my lazy fat butt is too drunk to look....Happy huntings...
Old Apr 19, 2008 | 01:00 AM
daflake's Avatar
daflake
Drinking and posting do not mix....
The new style mount runs less that 100 dollars and is fairly easy to do yourself. You will basically follow the pulley swap install instructions to get the engine off the mount and then remove the mount itself and replace. You will need a E12 socket (I think that is the right number) bit to get the bottom bolt out of the mount. Do not try to use a regular socket as you can strip the bolt. Took me about 2 hours total to do.
Old Apr 19, 2008 | 01:57 AM
loesches's Avatar
loesches
I miss the autobahn!
Daflake, I might hit you up for a hand when I get back. My mount went out right before I left and I need to replace it. I will shoot you an email when I get back.
Old Apr 19, 2008 | 06:18 AM
EDM's Avatar
EDM
Fantastico! Thanks guys!
UKSUV, when you sober up send me that link!
Old Apr 19, 2008 | 06:54 AM
daflake's Avatar
daflake
No problem...
I will be installing some new rotors and pads as well as a new sway bar hopefully sometime this week. Gotta keep my skills up.
Old Apr 19, 2008 | 07:00 AM
daflake's Avatar
daflake
EDM,
Here is a link to the pulley install. The idea is to get the engine lifted off the mount for removal. After you have it off, you take one bolt off in the engine compartment that holds the mount and the other is from underneath near the right front wheel skirt. Hope this helps....
http://www.mini-madness.com/pdf_file...EY_INSTALL.pdf
Old Apr 19, 2008 | 07:54 AM
richplay69's Avatar
richplay69
I'm going to be replacing my motor mount today on my 03 MCS... yeah thats right, even the earlier mounts are crap too... just not quite as bad as the canister style that you have. I'm doing this along with some new urethane bushings from Ireland Engineering in the other motor mounts I'll let you know later tonight how it all goes.
Old Apr 19, 2008 | 09:12 AM
bolar's Avatar
bolar
Where did you guys get your new mount?
Old Apr 19, 2008 | 11:19 AM
daflake's Avatar
daflake
I bought mine from BMW... However, I do know that Custom MINI shop has them. I would give Brad a shout.
www.customminishop.com
Old Apr 19, 2008 | 01:45 PM
richplay69's Avatar
richplay69
OK... I just finished up with everything about an hour ago. It only took me about 30 min to do the hydraulic motor mount (the one that leaks) then about another hour or so to do the upper and lower polyurethane inserts for the other motor mounts. Really, this is not hard to do at all. Just take your time and don't rush, cuz it won't take that long anyways. The hardest part about the hydraulic mount is getting some of those damn plastic screws on the fender off they want to keep spinning around in there instead threading out... I ended up only taking just enough out so I could pull the fender back a little to get in there with a wrench. Another thing that sux is I had to go buy an entire set of torx sockets just to get the E12 socket I needed... and it cost me $20 from sears. I'll probably never need those things again either so... I think I'm going to take them back and say it didn't have the size I needed
Old May 22, 2008 | 08:59 PM
03StuckInAustin's Avatar
03StuckInAustin
What procedure did you use to replace the motor mounts? I have on 03 MC and have the same problem. I can not find a DYI to remove and install new mounts
Old May 22, 2008 | 10:43 PM
k-huevo's Avatar
k-huevo
How-to, but I would support the engine and remove the engine mount bracket rather than lifting the motor if doing it again.
silence2-38554
Nov 12, 2015 09:39 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
