Drivetrain One ball mod
Old Aug 26, 2009 | 07:27 AM
  #76
Bigshot's Avatar
Bigshot
No, the R56 has a straight thru exhaust.
Old Jan 12, 2010 | 03:17 PM
  #77
miniwheels's Avatar
miniwheels
how about this?
has anyone ever tried just to join the pipes at the base of the T?
may take the tin sound out, the tailpipes will not move around, ![IMG][/IMG]
can call it the bypass mod.
Old Jan 12, 2010 | 03:22 PM
  #78
Bigshot's Avatar
Bigshot
That won't work as the exhaust runs thru the resonator on the right, exits out of it and goes to the muffler on the left and then exits the muffler with the twin tips.
The tips won't move around after doing the mod.
Old Jan 12, 2010 | 04:14 PM
  #79
glnr13's Avatar
glnr13
for reference to what bigshot is talking about:
it's cut up but you can see that a y-fitting isnt going to work from the center pipe.
Old Jan 12, 2010 | 04:35 PM
  #80
miniwheels's Avatar
miniwheels
its just i done this on my c5 corvette, at idle it was stock sounding, when you reved it up it was noticeable did this on both mufflers, on a mini just down the pipe further? just thinking out loud.
http://forums.corvetteforum.com/c5-z...post1572135319
Old Jan 12, 2010 | 04:39 PM
  #81
glnr13's Avatar
glnr13
i think you're missing it... the left side has an exit, the right side does not, it overflows into the left muffler.
Old Jan 12, 2010 | 04:45 PM
  #82
miniwheels's Avatar
miniwheels
what i am i thinking is bypass do not eliminate the muffler sort of like a silencer on a intake. just that i read the other responses and some wrote their pipes would move around and would not be straight, also that the sound was not deep, more higher pitched.
[IMG][/IMG]
Old Jan 12, 2010 | 05:03 PM
  #83
glnr13's Avatar
glnr13
i understand what youre saying but i think it's much more involved than you think. here's another photo without the shield in place:
so here's what you'd have to do:
seems like more work to do that than just buy a new exhaust or used exhaust that you know will work and fit.
also, keep in mind that the new muffler exit will not fit the way i even drew it because the battery box is in the way.
Old Jan 12, 2010 | 06:08 PM
  #84
miniwheels's Avatar
miniwheels
tried to upload a picture would not go, thanks for your input, do you have a cut open picture of left side muffler, can you go threw the shell with a crossover pipe to tips?
Old Jan 12, 2010 | 06:11 PM
  #85
glnr13's Avatar
glnr13
no idea, never cut one open and no pics in my search.
Old Jan 12, 2010 | 06:19 PM
  #86
miniwheels's Avatar
miniwheels
on the c6 corvettes they are boring holes threw the side and threw the cross over tubes then resealing the outer shell.
http://forums.corvetteforum.com/c6-c...er-mod-11.html
Old Jan 12, 2010 | 06:22 PM
  #87
miniwheels's Avatar
miniwheels
i might just give it a try, been trying to get in touch with 1 of the members here with dinan axle back muffler, just on a budget, just had to by snow tires and wheels for the mini.
Old Jan 13, 2010 | 07:19 AM
  #88
Bigshot's Avatar
Bigshot
The resonator is not a true "muffler". Has a completely different interior and packing. So the sound and performance would be different side to side.
Old Jan 20, 2010 | 07:37 AM
  #89
burley's Avatar
burley
Anyone in the Chicago area have the one ball so I can see what it sounds like in person? Also, anyone know of a local muffler shop that's done this on Minis before?
Old Jan 27, 2010 | 03:27 PM
  #90
Achilless's Avatar
Achilless
I just did the one ball mod. i have never done anything mechanical or of that sort before but this was sooo easy.
i was just sitting on my porch looking at my car in the drive way and decided to have some fun.
i put it up on some ramps (a lift would have made it ALOT easier)
cut, weld. done!
cheap, weight reduction, sounds even better! thanks DIY forums
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
WhinyR53
Sep 30, 2015 07:36 AM
