Drivetrain One ball mod
Old Jan 16, 2009 | 05:45 PM
  #51
overheadcam11's Avatar
overheadcam11
Do you have to take this into a muffler only shop, or can a mechanic type shop do this mod?
Old Jan 16, 2009 | 05:47 PM
  #52
overheadcam11
Do you have to get this done at muffler shop, or can a mechanic type shop do this mod?
Old Jan 16, 2009 | 06:18 PM
  #53
FranticFreddy's Avatar
FranticFreddy
A good welder should be able to do this. Provided they know what they are doing. Mine was done at the dealers during an oil change visit.
Old Jan 17, 2009 | 11:02 AM
  #54
Dr Obnxs's Avatar
Dr Obnxs
Post your experiences here!
https://www.northamericanmotoring.co...duct/47/cat/31
Matt
Old Feb 19, 2009 | 03:38 PM
  #55
DeanoTX's Avatar
DeanoTX
anyone in the Dallas/Ft. Worth aree have this done? Im looking for a rec on a good shop...
Old Apr 27, 2009 | 12:29 PM
  #56
ScottSellersUNR's Avatar
ScottSellersUNR
Im not really finding anyone who has done the one ball set up but changed the muffler to a magnaflow or borla or similar..... Anyone with any luck going that route? I figured run that but keep it on the passenger side for better weight distribution with a driver in the car.
Old Apr 27, 2009 | 12:46 PM
  #57
Bahamabart's Avatar
Bahamabart
your talking about a single sided system, just reusing the stock pipes.
Old Apr 27, 2009 | 01:20 PM
  #58
ScottSellersUNR
yeah, i just cant find any info on it.. on how loud to expect it to be.
Old Apr 27, 2009 | 01:43 PM
  #59
topsider's Avatar
topsider
I did the one ball Mod now maybe a year ago. kept the stock "ball". I have had experience with Borla and MagnaFlow but not on the mini. Both companies make different muffler models for different applications. I am sure you could call them and they can help you find something in the sound range you are looking for.
If you get one made for a different car just make sure the dimensions will be right but in the end you will be doing more welding than it's likely worth right? You will need the tail weld for exit, a hangar, and the inlet weld. One ball stock rocks but I am waiting for the dreaded drooping I have read about w/o that second hangar support. I'll ride it 'til it drops...
Old Apr 28, 2009 | 07:35 AM
  #60
rl48mini's Avatar
rl48mini
for a different spin on the one-ball, I upgraded the pipe from the cat all the way back with 2.5" ss. Installed a OBX header and a Magnaflow 2.5" cat. Still used a stock muffler on the left side. It's been a little over a year now and still sounds good.
Old Apr 30, 2009 | 10:37 PM
  #61
ScottSellersUNR
I got a 2.5" Borla Pro XS in the mail today, monday im gonna cut the stock system off in front of the first muffler and adapt it to 2.5 and just put a turn down at the end of the muffler.. guessing itll be LOUD but hopefully a nice deep tone.
Old May 8, 2009 | 07:24 AM
  #62
luvlee's Avatar
luvlee
I got this mod done yesterday and I'm very satisfied with the results.
BUT, exhaust tip is shifted to the left side...I think it's because the weight of the right ball is gone.
I've looked under the car and noticed that I can't do much because the left ball is just hanging there with a rubber attachment. I can't center the exhaust just by pushing it because it just returns because it's just hanging there.
Anybody else notice this problem? If so how did you fix it? How WOULD you fix it?
Old May 8, 2009 | 07:28 AM
  #63
Bigshot's Avatar
Bigshot
Sounds like the shop didn't quite get it back together right.
Old May 8, 2009 | 07:32 AM
  #64
rl48mini's Avatar
rl48mini
Is your new pipe elbow bolted in with clamps or welded? If clamped, maybe one of the 'legs' of the pipe is a little long. You might be able to loosen the clamps and adjust it. If welded, you might be stuck unless you want to cut one weld and adjust it. Obviously, center the tips and hold in place before re-tightening the clamps or re-welding.
Old May 9, 2009 | 07:50 AM
  #65
luvlee's Avatar
luvlee
Are you asking me if the new pipe is welding or bolted to the body or to the rest of exhaust? I'll have to go check
Old May 9, 2009 | 08:19 PM
  #66
paul_'s Avatar
paul_
Seriously considering this... I wonder if Helix has a mandrel bender?
Old May 10, 2009 | 05:50 AM
  #67
C-Lop's Avatar
C-Lop
I don't have that problem take it back to the shop and tell them to correct it...
I wouldn't even worry about it. It is a cheap mod and it not being mandrel bent is not going to affect performance on your car.
Old May 10, 2009 | 10:17 AM
  #68
k-huevo's Avatar
k-huevo
Originally Posted by C-Lop
...It is a cheap mod and it not being mandrel bent is not going to affect performance on your car.
A poor bend and offset transitions can create more backpressure than removing the right side resonator reduces. I’ve seen some bad hack jobs that are not only restrictive, but sound terrible too, because of how the crimp alters tone (think can-of-bees). One of the main advantages of using the pre-fabricated MinSpeed resonator delete tube is flow-pleasing bends.
The one ball can become a better performer by replacing the OEM flange end piece,its tubing necks down to less than 2 inch ID 1.5 inch past the two-hole flange, a 2.25 ID section of tubing on an aftermarket flange is far less restrictive. For the daily driver, the sound is easier to live with if the replacement flange is incorporated with a resonator. The sound from a straight through perforated resonator and the chambered OE muffler is very nice.
Old May 10, 2009 | 05:26 PM
  #69
paul_'s Avatar
paul_
Huevo,
Can you elaborat e on your last post? I'm afraid I haven't understood what you said, but increasing flow is important.
Old May 10, 2009 | 05:38 PM
  #70
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by ThumperMCS
I had a one-ball and was always a fan of it. You cant beat how cheap it costs to do. Sounds great from the outside after I added an OBX header.
BUT...about 25k miles later, it began rattling really bad. The hanger was actually broken and the rubber mounts that hold the muffler up were shot. It is too much weight to have hanging from one side. Also, after I lowered my car, I noticed that it slanted slightly toward the drivers side (the side with the one-ball muffler). It baffled me as to why, thought the springs were installed incorrectly, but after many re-checks by various people...they were fine. When I installed my Invidia though...the slant was gone! It was caused by the weight of the one-ball all being on one side. Just something to keep in mind!
It should be noted for everyone doing a "One Ball Mod' that a hanger rod be fabricated on the passenger side to bring the pipes back to center, and to help support the system!!!!!!!!!!!!!!!!!
The resonator that was cut out of the system had one Only makes sense to put one back in yes ?
Old May 10, 2009 | 05:43 PM
  #71
-=gRaY rAvEn=-
Moderator
Huevo,
I believe he is speaking of the prefabricated pipe bends are "crinkled" at the elbows....as apposed to a piece of pipe bent in a machine......most shops like Meineke have the machine to bend pipes but some do have 90 degree pre bent sections which have the crinkle elbows which would be considered a "hack install".
Old May 10, 2009 | 09:30 PM
  #72
Longboard110's Avatar
Longboard110
never had this problem with mine. The 2 hangers on the single muffler is more than enough.
Old May 10, 2009 | 09:33 PM
  #73
k-huevo's Avatar
k-huevo
Minspeed resonator delete tube, a good bend.
New flange and resonator attached to one-ball.
Bad bend example in the attachement, that bend deforms to less than 2 inch OD.
Old May 11, 2009 | 07:29 AM
  #74
mdbsat's Avatar
mdbsat
Eeep. I cringe when I see my old exhaust. I hack job indeed, and the guy burned my heat shield with his torch to boot.
Old Aug 26, 2009 | 12:37 AM
  #75
mattsenpai's Avatar
mattsenpai
Can this be done on the r56?
