Drivetrain How To Choose Good Engine Oil for My 06 Mini?
Old Mar 30, 2008 | 01:34 AM
Marwan's Avatar
Marwan
Hi guys, I'm confused on which oil brand and type shall I use? I'm in Saudi where in summer it reaches 50 degrees. I'm running Mobile 1 as per the dealer recommendation. Please suggest if you thing there's a better oil brand and oil formula. I'm running in high temp area and needing extreme street performance.
Old Mar 30, 2008 | 01:41 AM
ChiliWORKs's Avatar
ChiliWORKs
If you can get OEM BMW branded Castrol oil 5w-30, you will have one of the best oils out there for you MINI. This OEM Castrol oil is NOT THE SAME as the Castrol Syntec 5w-30 you buy from the store. This has been discussed in BobIsTheOilGuy forums.
Old Mar 30, 2008 | 01:45 AM
Marwan's Avatar
Marwan
and how do I get that? By going to the dealer?
Old Mar 30, 2008 | 02:22 AM
ChiliWORKs's Avatar
ChiliWORKs
Yeah, and it should look like this or something similar to it if it only comes in gallon sizes.
Old Mar 30, 2008 | 02:34 AM
Marwan's Avatar
Marwan
Below is the description of a 5W-30 oil and please see the bold:
Provides the quickest starts and fastest oil pressure rise. Will reduce turbo lag and provides more power and best economy in an engine in good condition. Replacement for OE factory-fill oils in passenger cars and most light trucks, including most new GM cars and trucks. Thicker oil film at operating temperature than a petroleum 10W-40. Best choice for engines operated in extreme cold weather.
Old Mar 30, 2008 | 05:17 PM
ninjlao's Avatar
ninjlao
Ninja Mini
Neo Synthetic oil is also a very high quality oil you can use in the mini.
Old Mar 30, 2008 | 05:33 PM
cooper8168's Avatar
cooper8168
After running Mobil 1 in my Porsche (as they recommend), I started running it in the Mini (5w-30) and it's been just fine for me. I may try the BMW-branded Castrol next time, though I have no real reason to do so. I'm in Southern California, but I frequently run through the desert in similar temps to yours.
Old Mar 30, 2008 | 06:31 PM
verveAbsolut's Avatar
verveAbsolut
I think a better idea than everyone posting what brand they use or what recommendations are on the containers would be for everyone to head on over to bobistheoilguy.com and learn a little about the important aspects of oil...kinematic viscosities, flash points, contamination, wear numbers, shearing, etc.
Unless these things are elaborated upon, no new information is gained...rather, these threads simply become a survey of preferences.
- Matt
Old Mar 30, 2008 | 06:36 PM
minimarks's Avatar
minimarks
Royal Purple
Old Apr 1, 2008 | 04:54 PM
checkmate2006's Avatar
checkmate2006
Quaker State Q Horsepower Full Synthetic is what I use and I just completed a trip to and from Las Vegas AMVIV with no oil associated problems
TREX
Nov 2, 2019 07:31 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
M7Speed
Aug 6, 2015 01:48 PM
