Drivetrain Engine Mod Advice
Old Mar 31, 2008 | 05:19 PM
deltarocketscientist's Avatar
Engine Mod Advice
Need some advice, I have a "lightly" modded 06 MCS. I have a 15% Alta, CAI, and I have a set of JCW injectors I want to install. I have been advised that I won't need an immediate re-map of the ECU, obviously that is the intent but I want to get something here in Cleveland and I have not been able to locate anyone. Any opinions? I am sure there are a few
Thanks in Advance
Ray
Old Mar 31, 2008 | 05:50 PM
ED955S's Avatar
ED955S
Those are good starting points. There are lots of thread about this, try searching. Get an exhaust or one -ball before ECU tune. I myself is only aiming to that stage. Please add also a 19mm sway bar (stiffest setting) and you'll be amazed how much handling will be improved. Happy motoring!
Old Mar 31, 2008 | 05:55 PM
Got a one ball from IE. I also have a big rear sway bar, adjustable upper and lower control arms, I have springs and I changed out the tires with non-run flats. I am just curious if I need to retune the ECU with installation of JCW injectors
Old Mar 31, 2008 | 07:34 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I think to see any benifit from the injectors, you'll need a tune. Else the computer wouldn't realize there is more capacity, right?
Seems to make sence.
Old Apr 1, 2008 | 05:42 AM
THE ITCH's Avatar
THE ITCH
Ray
See this thread
https://www.northamericanmotoring.co...43#post2131343
Steve
Thanks in Advance
Ray
Old Apr 1, 2008 | 08:11 AM
jaynicholson's Avatar
jaynicholson
Jan is coming to Rochester, NY. That's not too far from Cleveland
Old Apr 1, 2008 | 06:00 PM
Ok, looks like a consensus is a tune, I know Jan is going to be in Rochester, but anyone know if he is coming to OHIO, or if there is a good (not necessarily the best) tuner anywhere near Cleveland?
Ray
Old Apr 1, 2008 | 06:27 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
we also hope Jan is going to be back in Detroit in June, again very close to Cleveland.
But no, there is no one in Cleveland.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
sevin
May 2, 2026 06:11 AM
boostedhaze
Jan 2, 2018 07:26 PM
minipopkart
Aug 13, 2015 05:22 AM
massmini03
Aug 12, 2015 11:19 AM
