Drivetrain Pulley Weight (steel vs. aluminum)
Old Mar 19, 2008 | 11:35 AM
bhardy's Avatar
bhardy
SC Pulley Weight (steel vs. aluminum)
What are some of (if any) the advantages or disadvantages between an aluminum pulley at 8 ounces and a steel pulley at 15.5 ounces? I've read some things about the lower inertial mass, but how significant is it? Is there a reliability issue? Or is it something you'd even notice during day-to-day driving?
Thanks.
Old Mar 19, 2008 | 12:23 PM
Crashton's Avatar
Crashton
Is this for a crank pulley or a supercharger pulley?
My thinking is the difference between a steel & aluminum flywheel is huge. The difference between a steel & aluminum crank pulley wouldn't be to much. It's a very small diameter & the difference in rotational mass wouldn't gain you much. If it is for a supercharger pulley then the difference would be minuscule.
Lots of folks believe in those light weight pulleys. Me no so much.
Old Mar 19, 2008 | 12:29 PM
eager2own's Avatar
eager2own
If it ain't titanium, it ain't s---!
http://1346843.estore.networksolutio...tail.bok?no=99
Old Mar 19, 2008 | 12:34 PM
Bahamabart's Avatar
Bahamabart
an leave out TITANIUM ?
UBER explains all.
Old Mar 19, 2008 | 12:36 PM
TurboMini's Avatar
TurboMini
^ 800 BUX!?
Old Mar 19, 2008 | 12:39 PM
bhardy's Avatar
bhardy
Thanks! Yeah, it's for the supercharger pulley. I have a 15.5 ounce 2-piece design thats about to go in. While I just can't see 8 ounces making that big of a difference, given that these thing spin at a really high rate I want to be sure...
Old Mar 19, 2008 | 01:23 PM
afinley's Avatar
afinley
$800!?! But then again, it is weapons grade titanium
Old Mar 19, 2008 | 01:26 PM
BlimeyCabrio's Avatar
BlimeyCabrio
And you have no idea the personal risk to life and limb that the artist had to go through to secure that block of weapons grade titanium from a fabled industrial military complex hidden deep in the desert... it's a bargain when you consider that.
Old Mar 19, 2008 | 01:44 PM
Guest's Avatar
Guest
Thanks.
You won't be able to tell the difference between 8 ounces of inertial mass on a supercharger pulley, trust me .
Old Mar 19, 2008 | 07:11 PM
bhardy's Avatar
bhardy
I figured as much... marketing! Thanks for the opinions.
Old Mar 19, 2008 | 08:13 PM
OldRick's Avatar
OldRick
It's such a small radius that you probably couldn't measure the difference in engine output.
Old Mar 19, 2008 | 09:21 PM
Guest's Avatar
Guest
Yup. A rotating mass in itself isn't a bad thing, it's when you move the weight outside of the point of rotation that it starts taking more and more power to start said rotation .
Old Mar 20, 2008 | 01:06 PM
MRmidge's Avatar
MRmidge
And for the SC pulley you have to consider thermal expansion. Aluminum expands at a different rate than steel. With an alum. pulley you can have slipping issues until all working metal parts have reached operating temperature. As well aluminum under stress has a property know as cold flow. The metal will move and change under stress. Which put simply allows the bolts clamping it in place to loosen over time. Causing massive slipping, ie: boost loss and coolant system temperatures to rise. Now as long as the alum. pulley has a steel hub it bolts to you'd be alright. But, I wouldn't waste my time with a full alum. pulley.
Old Mar 20, 2008 | 02:16 PM
OldRick's Avatar
OldRick
All of the theoretical considerations you cite are true, however, most of the aftermarket SC pulleys in use on MINIs are aluminum. They work fine, and I've never seen a post complaining that one has come loose - it's just not an issue, in practice.
If it concerns you, an alum. pulley with 6 bolts is probably better than one with only 4.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
eliseo1981
Sep 4, 2015 02:33 PM
