Drivetrain New Voltage CAI!
Old Mar 8, 2008 | 08:32 PM
Longboard Mini's Avatar
Longboard Mini
New Voltage CAI!
Hi,
Dale from Voltage stopped by today and installed his new CAI on my car .
The box is hand formed fiberglass (no heat soak) with a molded in velocity stack for the UNI filter to connect to. The fit was perfect and the custom paint job is just awesome . Thank you Dale for adding a work of art under my hood.
Old Mar 8, 2008 | 08:38 PM
joshamman's Avatar
joshamman
looks very nice.
your intercooler is insane
Old Mar 8, 2008 | 08:39 PM
Longboard Mini
Here are couple other pics.
Old Mar 8, 2008 | 08:42 PM
Johan's Avatar
Johan
Nice intake...just like you say, no heat soak!
Old Mar 8, 2008 | 08:54 PM
mcs22004's Avatar
mcs22004
Originally Posted by Longboard Mini
Hi,
What did he have to remove to get it installed other than the stock airbox? It appears to replace the plastic partition behind the stock airbox.
Old Mar 8, 2008 | 08:59 PM
Longboard Mini
It mounts perfectly to bottom of the stock air box. Yes, it does replace the back partition. Very easy install. The back of the box is open.
Longboard
Old Mar 8, 2008 | 09:00 PM
mcs22004's Avatar
mcs22004
Hi,
Other than the paint job, how is this different from your old Voltage CAI, assuming this one was yours:
Old Mar 8, 2008 | 09:06 PM
Longboard Mini
That isn't mine. I had a Alta on before. Any one want an Alta cheap?
Longboard
Old Mar 8, 2008 | 10:57 PM
Some Guy's Avatar
Some Guy
How does it sound? Similar to the Alta?
Old Mar 8, 2008 | 11:12 PM
trackster's Avatar
trackster
Nice looking piece . Do they offer it with a larger size filter ?
Old Mar 9, 2008 | 12:46 AM
verveAbsolut's Avatar
verveAbsolut
I would have bought one of these in lieu of the DDM had it been available when I made the purchase.
Where the hell is their website/ordering? This intake seems to crop up occasionally, but with no info on means of purchasing.
- Matt
Old Mar 9, 2008 | 06:03 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Yeh, but it ain't fitting your stock SC anytime soon! I'm sure it hides a multitude of sins under that enormous size...like a Rotrex SC.
That's one scary looking engine bay, Longboard.
Old Mar 9, 2008 | 08:47 AM
evilduck's Avatar
evilduck
I'd be interested to learn where to purchase too.
Thanks Longboard!!
Old Mar 9, 2008 | 09:20 AM
shooler's Avatar
shooler
Thanks Longboard!!
+1. looks like a nice piece.
Old Mar 9, 2008 | 10:40 AM
Longboard Mini
You can contact Dale at voltageproducts@aol.com . Don't look for a website any time soon. Dale likes things simple.
Longboard
Old Mar 9, 2008 | 10:41 AM
Longboard Mini
Why . Whats the longer filter going to do?
Longboard
Old Mar 9, 2008 | 12:47 PM
Bahamabart's Avatar
Bahamabart
Longboard
A longer filter will require less cleaning (longer cycle) and provide a longer "peak performance period".
Old Mar 9, 2008 | 12:54 PM
Bahamabart's Avatar
Bahamabart
(no heat soak)
How can you say that ? Perhaps "low" heat soak compared to metal BUT even the stock box has a degree of "heat soak" for it does absorb some heat. This is fiberglass, so I will assume it absorbs less heat than metal BUT less than stock box, JCW or Dinan?
what ya got to back it up
Old Mar 9, 2008 | 01:58 PM
Longboard Mini
Stop with the tough questions Bart I can't take the pressure .
Yes you are correct, It does retain some heat but nothing compared to the metal boxes.
I drove in Dales car which was a trip because I forgot how the Eaton sounded. It sounds more subdued then say the Alta driving mellow around town. When pushed it sounds great.
On my car it sounds little different .
LB
Old Mar 9, 2008 | 02:03 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You should redo some of those tubes on the left side in red to balance out and continue the color theme.
Old Mar 10, 2008 | 09:56 AM
Bahamabart's Avatar
Bahamabart
just keeping you honest
I really wonder how important the material is for a CAI? I run a metal box and it never really gets hot w/ the exception of turning off the car and letting it sit but then everything gets hot when you do that.
If I've been driving, stop and pop the hood to hand check the horns, IC and CAI box - they are all relatively cool to the touch. I did insulate the box on the outside to hopefully improve it but I can't really say if it does or how much it does.
It would appear that the design is not real filter access friendly ?
Old Mar 10, 2008 | 10:03 AM
rocksurfer's Avatar
rocksurfer
its easy to clean the filter,and they way that its designed the filter doesnt get as dirty as quick as say the alta with the open top.
Old Mar 10, 2008 | 10:22 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Nice addition to the engine bay Longboard That CAI is trick for sure. Nice to see your car coming together.
Old Mar 10, 2008 | 02:09 PM
k_h_d's Avatar
k_h_d
How much is it?
Old Mar 10, 2008 | 03:33 PM
RussellCory's Avatar
RussellCory
Originally Posted by k_h_d
How much is it?
+1
