Drivetrain Questions before I start changing my MCS
Old Feb 25, 2008 | 05:49 AM
MJohnson81's Avatar
MJohnson81
My question is about setting off check engine lights (CEL) after moding the car. My previous car was a 2006 honda civic EX, which I put on a CAI and exhaust and it got to the point where if you would look at the car wrong it would set off the CEL. Will my MCS be the same way?
I know right now I want to put on a CAI and a 15% pulley on the charger and later maybe go with exhaust and manifold. Do I run the risk of setting off the CEL by doing these mods on my MCS? Also are there certain add ons that I should stay away from so I dont set off the CEL?
Any input would be helpful.
Old Feb 25, 2008 | 06:34 AM
MiniMacPR's Avatar
MiniMacPR
From my experience, the only one of those mods that may set off a CEL is the exhaust manifold (header) and only as it relates to the CAT. I have a 200 cel high flow cat on mine and have a CEL. There are other manifolds/cats out there that you can install that wont give you a CEL.
Old Feb 25, 2008 | 06:44 AM
jakay11's Avatar
jakay11
easiest thing to do is look and see what the factory did with the JCW package...
Pulley,
teflon coated SC (already from the factory that way on newer R53s)
ported-polished head
CAI
exhaust.
As long as you play after the cat on the exhasut, you won't throw a CEL...
Old Feb 25, 2008 | 06:58 AM
greengobln's Avatar
greengobln
the only time i've seen problems is when you play with the CAT. everyone else i think will tell you the same thing. have fun playing with it.
Old Feb 25, 2008 | 07:10 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
All suggestions so far spot on--but you never know what that crazy little computer in the Mini will do. I've set it off many times, and eventually bought a code reader/reseter. Worth the expense in the long run especially if you don't have a good relationship with a close by dealer.
Good luck.
Old Feb 25, 2008 | 07:28 AM
MJohnson81's Avatar
MJohnson81
Good luck.
Def a good suggestion. Thanks for all the help. Just to follow up on what someone said earlier...what year did they change to the teflon coated SC? I have a 2004, do you that has one.
Ive been reading as much as I can on the minis and this site has been a HUGE help.
Thanks to all
Old Feb 25, 2008 | 07:31 AM
naffets's Avatar
naffets
I've got JCW head/supercharger/pulley/exhaust set up and threw a lean code on cyl 2 once.
Hasn't happened again and I have the ScanGauge II. This was one of the best "mods" I think since it has saved me going to the dealer to find out what CEL was on for.
Old Feb 25, 2008 | 07:45 AM
ScottinBend's Avatar
ScottinBend
'05 sc are the same as JCW.
Old Feb 25, 2008 | 09:34 AM
charger's Avatar
charger
Does that apply to 2006 models as well?
Old Feb 25, 2008 | 12:38 PM
D-MAN's Avatar
D-MAN
Does the RMW header cause codes????
Old Feb 25, 2008 | 12:51 PM
MiniMacPR's Avatar
MiniMacPR
Yes, except for the pulley size of the JCW the '05 & '06 models (and '07/'08 convertibles) have the same charger as the JCW.
Old Feb 25, 2008 | 12:54 PM
MiniMacPR's Avatar
MiniMacPR
Don't know, I don't have the pleasure of owning one. If it comes w/out a cat I would imagine so. I'm not sure, however, if you can tune the car to not throw that specific code. It's worth asking if you are planning to go that route.
Old Feb 25, 2008 | 01:01 PM
MJohnson81's Avatar
MJohnson81
But not the 04?
Old Feb 25, 2008 | 03:36 PM
MiniMacPR's Avatar
MiniMacPR
Sorry but the 2004 MINI S did not include the Teflon coatings on the supercharger.
Old Feb 25, 2008 | 05:38 PM
ScottinBend
Old Feb 26, 2008 | 12:13 PM
charger's Avatar
charger
Glad i bought my 2006 over the JCW 2003!
Old Feb 26, 2008 | 04:26 PM
ScottinBend
All JCW sc's were the same.
sprp85
Aug 22, 2015 06:16 AM
elightbo
Aug 17, 2015 01:50 PM
FLYM1N1
Aug 16, 2015 01:17 PM
clintmeister
Aug 12, 2015 11:11 AM
nomar116
Aug 10, 2015 11:24 PM
