Drivetrain 19% pulley gives 20psi!?
Old Feb 11, 2008 | 12:06 PM
grillhands's Avatar
grillhands
I was reading the classifieds and i came by a mini for sale. The guy said he is pushing 20psi with the 19% pulley. Is that normal or even possible? I did a search here but nothing really answered my question.
Old Feb 11, 2008 | 12:38 PM
verveAbsolut's Avatar
verveAbsolut
Believeable, but also understand that pressure includes both mass air and heat in the equation. After awhile, each extra PSI is due near entirely from excess heat and not more air.
Air = power, and heat just retards timing advance. Not a good thing.
- Matt
Old Feb 11, 2008 | 12:41 PM
grillhands's Avatar
grillhands
- Matt
How well do you think it'll work for me since i'm running the water/meth kit?
Old Feb 11, 2008 | 12:54 PM
verveAbsolut
Well I would say judging by your list of mods in your sig, you'll be running lean near redline regardless (unless you have/plan on getting injectors). Other than that, I'm not too keen on estimating for other people...hate to have "yer rong!" moments after the fact.
The water/meth injection does help quite a bit though.
- Matt
Old Feb 11, 2008 | 02:05 PM
grillhands's Avatar
grillhands
Thanks for your advice. The 380s are coming next.
Old Feb 11, 2008 | 02:43 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
What other mods are done to it?
Old Feb 11, 2008 | 04:14 PM
grillhands's Avatar
grillhands
I think he had just an exhaust.
Old Feb 11, 2008 | 05:05 PM
jhiggs26's Avatar
jhiggs26
Grillhands what water/methanol injection kit are you running? Is your kit progressive or just an on/off? Thanks!
Jeremy
Old Feb 11, 2008 | 05:24 PM
Ryephile's Avatar
Ryephile
The most I ever saw with my 19% was 19psig, but keep in mind it was a basically stock engine [read: restrictive] and made very little power considering the boost level.
Old Feb 11, 2008 | 05:38 PM
grillhands's Avatar
grillhands
I thought that too.How much restriction could there be to produce 20psi?
Old Feb 11, 2008 | 05:48 PM
grillhands's Avatar
grillhands
Jeremy
Its a cooling mist 1.5 gal trunk mount. It turns on at 10psi and stays on until it hit under 10psi.
Old Feb 11, 2008 | 06:10 PM
jhiggs26's Avatar
jhiggs26
Ok thanks Grillhands, but when does it turn off? I guess you just set the off point for a higher boost than the car will ever achieve.
Jeremy
Old Feb 11, 2008 | 06:21 PM
grillhands's Avatar
grillhands
It's pretty much as soon as you let off the gas it'll turn off.
Old Feb 11, 2008 | 06:35 PM
lanevomr's Avatar
lanevomr
I have 15% and my boost gauge reads 1.1Bar which converts to 15.95 psi. And before I install my 15% it reads around 10psi. I wonder if it reads normal?
Old Feb 11, 2008 | 07:22 PM
grillhands's Avatar
grillhands
That's about where i'm at around 6k rpm. It's hard to tell because i gotta watch the road.
Old Feb 11, 2008 | 07:28 PM
lanevomr's Avatar
lanevomr
yes that happend when i WOT. ok then it's normal.
Old Feb 11, 2008 | 08:15 PM
inimmini's Avatar
inimmini
When its cold out I'll hit 19 or even 20 psi with the 19% (at 20psi you're likely to get the P0108 high manifold pressure CEL, but at 19psi it'll just pop the traction control light). The outside temp is the main factor, though. At ~80F, I'll only see maybe 17psi, but at 20F, 19psi or even 20psi is possible.
Old Feb 12, 2008 | 03:36 AM
grillhands's Avatar
grillhands
Does the p0108 put the ecu in limp mode or does it still drive the same?
Old Feb 12, 2008 | 06:07 AM
inimmini's Avatar
inimmini
The few times I've gotten the p0108 CEL it has not gone into limp mode. Drives the same but with an annoying yellow light from the dash. I don't think you want to be hitting 20psi all the time ...
Old Feb 12, 2008 | 06:42 AM
grillhands's Avatar
grillhands
Very true
Old Feb 12, 2008 | 07:04 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
I hit the 20-22 psi all the time. i get the CEL light right around 6.4k and can rev to 7.2 before limiter. This is with mods listed below. With just the 19% pully the Cel would come on at 7k.
Old Feb 12, 2008 | 08:24 AM
grillhands's Avatar
grillhands
Did you ever get the car dynoed to see how much power you are making and where you a/f is?
Old Feb 12, 2008 | 09:29 AM
Big-Daddy-Blue
What belt are you running?
Old Feb 12, 2008 | 09:55 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
I get a cel around 6,700 rpm....What psi does it come on at signaling overboost? 17 psi correct?
Jack
Old Feb 12, 2008 | 02:34 PM
Big-Daddy-Blue
I have hit 18psi and no light at all. only the DSC blinks.
