Drivetrain Hose came away from CAI - would this cause problems?
Old Feb 9, 2008 | 04:17 AM
roofaS's Avatar
roofaS
Just noticed that the hose had come away from my GTT CAI (don't know how long it's been that way), reattched it with some zip ties as the OEM hose clip was a bit too large. After I started the engine and revved it, quite a lot of smoke has come from the exhaust - is this to be expected or should I be worrying about something having gone wrong with the engine?
Old Feb 9, 2008 | 04:46 AM
HighLife4136's Avatar
HighLife4136
Depends on how long and the conditions (dusty or wet). Excessive dust/dirt/bird feathers/any thing that can fit through the throttle body will scratch the cylinder walls/pistons. I don't know what to tell you to do other than maybe do an oil/filter change or two
...have you been driving the car lately? You made it sound like this is the first time you had the smoke coming out the exhaust.
Old Feb 9, 2008 | 07:46 AM
roofaS's Avatar
roofaS
Smokes seems to have disappeared after a run - it's my daily driver but the first time I had noticed any smoke and quite a strong effluent-ish smell.
Old Feb 9, 2008 | 09:54 AM
Ryephile's Avatar
Ryephile
The throttle body inlet hose - the one that goes from the CAI to the TB? ...or do you mean the PCV hose to the throttle body inlet hose?
Old Feb 10, 2008 | 12:17 AM
roofaS's Avatar
roofaS
errmm, the big black one? Sorry, not too mechanically minded
Old Feb 10, 2008 | 05:15 AM
Bahamabart's Avatar
Bahamabart
Whats done is done - so don't overly fret, just get the hose back on. Chances are you have just sucked in some very minor particles of dirt. Unless you know something you are not sharing .
If that hose pops you should know that it did by the increase SC whine - it should be significantly louder over whatever air intake you have.
You could remove the IC and take a look at the SC side to see if there is anything there but it would have to be decent size debris.
As to the smoke no way to diagnose - cold morning?, do you run the car?, ecty, ect, ect........................
Old Feb 10, 2008 | 10:00 AM
Ryephile's Avatar
Ryephile
Yea sounds like the air filter was disconnected for a bit. Unless you drove through some exceptionally dirty areas I wouldn't worry about it unless the smoking continues. My guess is you stepped on it when the engine was cold and saw a bit of oil blow-by. Wait until the engine is warm before giving it "the boot".
Old Feb 10, 2008 | 11:22 AM
roofaS's Avatar
roofaS
Thanks guys
The smoking has gone but the pipe keeps slipping off and I can't seem to tie it tight enough to stay so I'll probably go back to the stock airbox and flog the CAI
Old Feb 10, 2008 | 11:50 AM
Fatherdeth's Avatar
Fatherdeth
No need to write off the intake yet. Go to Autozone and get tthe t style hose clamps. They have a latch style to them and will allow you to clamp anything tight. They are adjustable as well.
Old Feb 10, 2008 | 12:08 PM
roofaS's Avatar
roofaS
Ahh, thanks fatherdeath. I'm in the UK so a trip to Autozone may be a tad expensive but I know what type of clip thing you mean - I think it's called a jubilee clip here.
Old Feb 10, 2008 | 12:38 PM
SteveS's Avatar
SteveS
I have Alta intake. The filter slips onto a flange on the inside of the airbox. I found it difficult to keep on. If you search on site you will find posts of various techniques to keep the filter on. Some tried putting a piece of coat hanger over the sides of the box to support the cantelevered air filter.
I took a different approach. Using a small crescent wrench (4"?) I went around the perimeter of the flanges to slightly bend the flange outward. This made the air filter stay on when I tightened the hose clamp. This works for metal Alta airbox.
Old Feb 10, 2008 | 04:52 PM
Fatherdeth's Avatar
Fatherdeth
Ooops!!! Had I read your profile, I would have known this. Sorry, and good luck. I think you'll be alright if you can find one of those clamps. Keep us posted.
Kimolaoha
Jul 5, 2023 01:04 PM
Mini7
Feb 2, 2016 07:52 PM
KrisMiss
Jan 3, 2016 02:02 PM
tr3y003
Oct 22, 2015 10:48 AM
Camaro108
Aug 25, 2015 02:44 PM
