Drivetrain How does overboost work?
Old Jan 22, 2008 | 05:05 PM
Terry @ BMS's Avatar
Terry @ BMS
Hey guys,
Soon to be R56 enthusiast here.
I have read about this temporary overboost feature, how does it work/feel? I know the normal boost level is around 14psi. What is the overboost level? 16psi?
Thanks,
Terry
Old Jan 22, 2008 | 05:17 PM
ghosthound's Avatar
ghosthound
all i know is it works, and it makes me smile!
Old Jan 22, 2008 | 05:35 PM
Ryephile's Avatar
Ryephile
Standard boost is actually about 10.5 PSI, and overboost is about 15.5 PSI. The way to induce it is not to just slowly put your foot to the floor, but SMASH the pedal to the floor as quickly as possible. It's quite a marked difference in torque between the two boost levels; going from "ok we're moving" to "oh wow it's getting out of its own way now!".
Old Jan 22, 2008 | 05:37 PM
Terry @ BMS
Interesting... how long does the over boost period last? So I take it most dynojet runs are with the overboost?
Old Jan 22, 2008 | 06:07 PM
Ryephile's Avatar
Ryephile
You can determine if you want the dyno pull to be in overboost or not. Incidentally peak power will be pretty much the same in overboost or not, just the torque curve is different. Overboost is only enacted below 4500 RPM. In my experience, it stays active as long as you are "totally on it". During my HPDE, the car felt like it was in overboost the entire 20 minute sessions. I think MINI says the overboost lasts for 15 seconds at a time, which means 15 seconds per full-throttle stab. Naturally that'll never happen on the track as you're shifting gears and going through corners.
$0.02,
Ryan
Old Jan 22, 2008 | 06:26 PM
scott48's Avatar
scott48
according to MINI, standard boost is 11.6psi and overboost is 13.6psi. going off my boost gauge, I've noticed standard boost as 12psi and overboost at up to 15psi.
Old Jan 22, 2008 | 07:23 PM
Ryephile's Avatar
Ryephile
Either MINI's disclosures aren't accurate or my R56 was a freak; I have the datalogs showing 10.5psi peak w/out overboost and up to 16.1psig in overboost when I installed my turbo-back exhaust! I wonder if the R56 has a sloppy boost controller or if exhausts, intakes, and "adaptive features" alter boost levels.
Old Jan 22, 2008 | 07:45 PM
Terry @ BMS
If its like the 335i boost will vary by altitude and ambient temperature, up to 3psi.
Old Jan 27, 2008 | 10:11 AM
kevinminict's Avatar
kevinminict
Does "overboost" happen when your first hit the accellerator OR when I'm driving down the road already moing and in 5th gear go into 4th and put the pedal all the way to the floor is that when I'll have overboost?
Old Jan 27, 2008 | 09:54 PM
danielo's Avatar
danielo
can't we just have over boost all the time???????
Old Jan 27, 2008 | 09:55 PM
ghosthound's Avatar
ghosthound
i wish there was some light or something that came on whenever you used overboost.
Old Jan 27, 2008 | 10:09 PM
scott48's Avatar
scott48
There is........the DSC light lights up, as it's trying to prevent wheelspin
Old Jan 27, 2008 | 10:22 PM
r56mini's Avatar
r56mini
In 4th or 5th the effect is less pronounced because of the gearing. In the low gears...... the tires smoke if you have the TC off.
Old Jan 28, 2008 | 12:49 PM
PaulCIssa's Avatar
PaulCIssa
Hehe.....tire smoke (in my best Muttly devious laugh impression)!!!!!!!!!!!!!!!
Old Jan 28, 2008 | 03:40 PM
ltjpunk7's Avatar
ltjpunk7
No, not overboost all the time, but someone (I think Candyman) has a how-to on rigging the ECU to have the Sport button constantly engaged so that you don't have to hit it every time you get in the car. Check the Electrical section.
Old Jan 31, 2008 | 10:49 AM
Terry @ BMS
Just floor the car all the time.
Old Jan 31, 2008 | 10:53 AM
lxjose9xl's Avatar
lxjose9xl
if that's the case then my overboost has been overworked
Old Feb 2, 2008 | 06:41 PM
second to none's Avatar
second to none
maybe put the sport button where the throttle position sensor is
Old Feb 2, 2008 | 08:03 PM
a96bimmerm3's Avatar
a96bimmerm3
overboost turns off after 15 seconds like Ryphile said.
Terry, I don't mean to be a ****, but can you search for this stuff on this forum and motoringfile before you ask questions like this? They've been answered before.
Old Feb 3, 2008 | 12:57 AM
William Blake's Avatar
William Blake
I have wheelspin all the way in first and slightly in second.
I does torque steer alot.
ebowling
90
Aug 4, 2019 09:15 AM
triple5soul
21
Jul 29, 2016 04:27 AM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
