Drivetrain Magnaflow Exhaust Owners
Old Feb 3, 2008 | 11:41 AM
wzabrouski's Avatar
wzabrouski
I put my Magnaflow exhaust on Thursday evening. The trumpet tips are so close to the rear bumper valance, about 1/16 of an inch. After the install, I heard on occasion when the car is cold, what sounded like the tips rubbing against the bumper valance. I checked the clearance of the exhaust last night, and everything is perfect, but the clearance of the tips is where the occasional vibration is coming from. I tried to adjust the exhaust, but it appears that the tips need to be brought down about 1/4 of an inch to prevent this vibration. I believe the only way to adjust the exhaust hangers is to heat them, and slightly bent them so that I can adjust the tips. Has anyone else with a Magnaflow, or any exhaust had this problem?
Old Feb 3, 2008 | 12:16 PM
hamm's Avatar
hamm
Get some alum. strap,3/8x1 and cut to the length of the rubber hangers.Drill to match and install between hangers and floor. This should lower the exhaust just enough.
Old Feb 3, 2008 | 12:35 PM
dmevis's Avatar
dmevis
Go to a Muffler Shop
This problem is common, and easily solved. If you own an Oxy-Accetaline torch, you just heat the muffler hangers and move the tips where you want them. Since most people don't own a torch, just take it to a muffler shop and they will fix it in a few minutes.
Old Feb 3, 2008 | 03:29 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Also adjusting the middle section up will move your tips down. Loosen all the connectors and see what you can do.
Old Feb 3, 2008 | 03:38 PM
AstroBlackS's Avatar
AstroBlackS
+1. Try positioning the the tips yourself by playing with the exhaust connections first. If all else fails, you can take it to a shop.
sevin
May 2, 2026 06:11 AM
blacklistedmini
Oct 27, 2017 10:31 AM
JPMontes3
Aug 24, 2015 07:15 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
